On the fence with purchase
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dutch45, Oct 18, 2018.
  1. Oct 18, 2018 at 3:34 PM
    dutch45
    dutch45 [OP] Member
    CT
    2011 Taco
    Hey guys. Im in the market for a new truck and have been considering another DCLB taco. I had a gen 2(2001) until I traded it for my f150. I ran the tacoma to 115k without an issue. Only complaint was the seat was tough on my knee if I drove for more then two hours. Unfortunately that is a common occurrence for me with my job. Anyway, I've been researching the gen 3 and I see a lot of negative feedback about the trans. Especially on the highway. That is 75% of my driving. I took a 2018 for a test drive and definitely noticed it was a bit sluggish and somewhat slow to react. However, it wasn't a long drive. Does this get worse with more milage? Maybe you guys can give me some more insight. Again I am mostly a highway driver but I need a bed to haul equipment.
    I married my tacoma likes this.
  2. Oct 18, 2018 at 3:37 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    They drive the same after a test drive.
  3. Oct 18, 2018 at 3:41 PM
    phsycle
    phsycle Well-Known Member
    CA
    Good dealerships will let you take the truck overnight. Go for a longer drive. Stock seats aren't that great for me. But not terrible.
    How they drive---it's a truck. It drives like one. Test drive all trim (Sport, SR5/OR). See what drives best for you.
  4. Oct 18, 2018 at 3:43 PM
    wahudiditagain
    wahudiditagain Well-Known Member
    Wes
    Central Ohio
    2017 TRD OR DC 4x4 Inferno
    It gets a little better with time, but the power curve is the biggest issue with 3rd gens. The power is there but it takes a lot more foot into the accelerator to find it. Some get used to it, some don't. Take a LONG test drive in city and highway and decide if you can live with it or not.
  5. Oct 18, 2018 at 3:46 PM
    STacoS
    STacoS Well-Known Member
    Loren
    Poulsbo, Washington
    2019 T4R OR
    Test drive a newer 2nd Gen like a 2015 too. I just traded my 2016 for a 2012 and I like it a lot better.
  6. Oct 18, 2018 at 3:47 PM
    jerryb1984
    jerryb1984 Well-Known Member
    Jerry
    2018 DCLB TRD OFF ROAD
    16x8 FUEL BEAST 265 75 16 FALKEN WILDPEAK AT3 Tyger step sides 20% tint front to match factory tint bilstein 5100s on third notch PRO grill
    Worse when using cruise control. It will slow down with adaptive cruise, then the space opens up and it downshifts and hurries to get back up to set speed versus gradual. Driving normal speeds with the ect button on seems to help as its not looking to upshift all the time, and then downshift at the slightest anything.
  7. Oct 18, 2018 at 3:49 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Sounds like you still need a bigger truck... :bucket:
  8. Oct 18, 2018 at 3:51 PM
    CJ_
    CJ_ Well-Known Member
    AZ
    17 Tacoma TRDOR 4x4
    Meh, I don’t think the trans is that bad at all. I drive around on flat highways 90% of the time. The trans struggles a little bit to find a gear sometimes, but not like some other cars I’ve driven.
    I imagine in the mountains it could get a little iffy, but I just plan to shift in sport mode then anyways
  9. Oct 18, 2018 at 4:00 PM
    BillW
    BillW Well-Known Member
    N. Phoenix
    2018 DCSB TRD OR MT
    You don't have to use adaptive, you can run "regular" cruise control. Hold the button down and you'll see the icon change on the instrument cluster.
    frodoz737 and StayinStock like this.
  10. Oct 18, 2018 at 4:28 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Get a manual trans, long bed only comes in access cab with MT
    oconnor, Mi2CaMatt and BillW like this.
  11. Oct 18, 2018 at 4:37 PM
    dutch45
    dutch45 [OP] Member
    CT
    2011 Taco
    Man if I could get a MT I probably wouldn't have posted. Problem is I work around NYC and the traffic is brutal. I need a long bed and auto. :turtleride: I do use CC a few times a week.
    phsycle likes this.
  12. Oct 18, 2018 at 4:43 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    test drive again, this time with the ECT button on..issue resolved..if you get one then get the ECT "on at start up" mod and you will be all set.
  13. Oct 18, 2018 at 4:51 PM
    GTS Bruce
    GTS Bruce Well-Known Member
    W
    Latest tsb fixes what some think is a responsiveness problem. If you are a dwarf and your foot doesn't reach the firewall or you are afraid of turning some rpm and staying in the powerband then this truck is not for you.
    Cudgel likes this.
  14. Oct 18, 2018 at 4:57 PM
    Grossomotto
    2017 4WDV6LB6MT
    I’d get a piece of shit truck driving around NYC it’ll just get banged up
  15. Oct 18, 2018 at 5:00 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    .. some guys have said their truck runs worse, or ran better for a short time then returned to “normal” and drivability suffered back to where it was prior to the TSB.
    So.. I think many would disagree with you.
    Tacoma2020 and shakerhood like this.
  16. Oct 18, 2018 at 5:09 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    I tend to drive w/ the ect button on all the time, imho that eliminates about 90% of the power/ transmission issues.
    kahanabob and dangeroso like this.
  17. Oct 18, 2018 at 5:13 PM
    Zona_tacoma
    Zona_tacoma Well-Known Member
    2018 Cement Tacoma Off Road
    Just my opinion but it's a great little truck but that's the thing, it's just that a little pickup truck. I've owned an f35, f150 and now have a 2018 off road. I have absolutely zero complaints with my Toyota in the 1500 miles I've put on it except the new desire to upgrade things I never even thought about. It shifts fine, goes fast enough and all that other shit I see people complain about. I pretty much putt around and drive it like a truck typically should be. If you wanna go fast buy something else. If you want a reliable small pickup that does fine on pavement and good enough in the dirt buy a tacoma offroad. Also, I am 6'4" and fit in the thing fine. Maybe I'm just a weirdo for not seeing these issues I read about
  18. Oct 18, 2018 at 5:21 PM
    Pirate1975
    Pirate1975 “What do you do with a drunken sailor...?”
    Steven
    Statesville, NC
    2017 Silver TRD Off-road
    3rd bedrail.32”duratrac tires.CaliRaised bed stiffeners,rear ditch bracket for cb antenna .SOS Concepts sliders,3skids,bedrails.curtis rack.cobra 75 cb.HAM license.887 coils,Bilstein 5100’s,medium Dakar leaf pack,extended rear brake lines,wheeler’s superbumps bumpstops.carrier bearing drop bracket.sway bar delete
    I really only have issues with my skinny pedal off-road. They do make a plug in module to help with the lag, and I also see some positive stuff with the ovtune thread. It does learn your driving after a bit, but the lag can still be there. I don’t run my ect all the time,just in the mountains. On the hills around here I just slap into sport mode and hold my gear on the incline..
  19. Oct 18, 2018 at 5:38 PM
    u wish u could ride
    u wish u could ride Well-Known Member
    put truck in s mode and either 5th or 6th then give it a good drive the tranny is much better!the d mode is for best fuel economy and shifts to lower revs whenever it can which is way to much.as the world is NOT flat!!
  20. Oct 18, 2018 at 7:41 PM
    dutch45
    dutch45 [OP] Member
    CT
    2011 Taco
    Thanks for the input so far. I will hit the dealer again tomorrow and see what comes up.
