on the fence
Discussion in 'Suspension' started by colinb17, Jan 8, 2010.
  1. Jan 8, 2010 at 5:20 PM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    so after searching and reading post for about an hour, i couldn't find a deffinate answer, so i'm going to have to ask...
    I'm going to left my 07 dbl cab. i want to do 2.5 in up front. what i couldn't figure out is at what point will i need an allignment. jsut got some new a/ts, and would hate to burn them down quickly. i know that a 3 in lift will require ucas, but will at 2.5? if so, i'll have to postpone the lift until i can afford the some TCs.
  2. Jan 8, 2010 at 5:21 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    It will need an alignment, then again after UCA's.
  3. Jan 8, 2010 at 5:22 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    You can use your stock UCA's with 2.5" of lift. If you change the height of your suspension you will need an alignment.
  4. Jan 8, 2010 at 5:25 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    thanks for the responses.
    sorry, i forgot to mention i knew i needed the alignment after the lift. just trying to confirm that the stock UCA's could be used and still aligned within spec.
    btw, what's a good price for an alignment? the last time i had it done, it was for free after the rear spring tsb.
  5. Jan 8, 2010 at 5:57 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    i'm a big believer in the whole you get what you pay for thing, that's why if needed i'd get the total chaos UCAs. they sound liek the best out there.
    where'd you go for the $40 alignment? everything i'm seeing is $80 and up
  6. Jan 8, 2010 at 5:58 PM
    1337Taco
    Kevin
    NorCal
    2015 4X4 Manual
    I got my alignment for $52 or something like that.
    You can get the alignment in spec with stock UCA's but it probably won't be perfect.
  7. Jan 8, 2010 at 6:00 PM
    4low2go
    Coatesville, PA
    10 RC 4x4 5sp MGM
    That exactly what I'm working on, doin' it all at the same time.
  8. Jan 8, 2010 at 6:12 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    well, to be fair, it's only online searching from the big chains. tomorow i'll be calling the local family owned shops, and i'm assuming they'll be cheaper...northern VA / Washington DC is just a stupid expensive place to live.
