On the hook- Rear Break Seized
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EDJY, Jan 17, 2017.
  1. Jan 18, 2017 at 4:29 PM
    EDJY
    EDJY [OP] Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    The truck was being towed literally from that parking lot, across the street and into the Toyota dealer parking lot. I was literally looking at the Toyota dealer waiting for the tow truck. I called the service department at the dealership... apparently they cannot leave the premises. It pissed me off because they could have walked for 4 minutes and looked at the truck while I sat and waited for a tow truck.
    They figured out it wasn't the parking break causing the issue, its being caused by the actual foot pressure on the break. The first time I had all-ready pulled forward about 10 feet.
  2. Jan 18, 2017 at 4:38 PM
    SargeBSA
    SargeBSA With self-discipline most anything is possible.
    Cascade Mountains
    2021 SR5 Tundra 4x4
    TRD Offroad Wheels 265/75 18 General Grabber ATX's,
    I had the same problem in Florida if the truck wasn't moved for a period of time. Turns out the moisture in the air combined with the salinity caused the shoes to rust to the drum. I solved the problem by not using the parking brake.
  3. Jan 18, 2017 at 4:44 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Toyota is using really cheap shit if it is corroded after only one year!
    wilcam47 likes this.
  4. Jan 18, 2017 at 4:45 PM
    gpb
    gpb Well-Known Member
    Atlanta
    2017 White DCSB TRDOR 4x4
    What did they say caused your brake to break? Foot pressure sounds odd, what did they say that meant? Piston locked up, star adjuster messed up, shoes didn't disengage after you released the parking brake?
    Aviator6 likes this.
  5. Jan 18, 2017 at 4:47 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    The truck is only a year old, never been in the salt, the undercarrage looks clean and not rusty at all.
    Its hard not to use the parking brake in a stick shift...
    shakerhood[QUOTED] likes this.
  6. Jan 18, 2017 at 4:48 PM
    gpb
    Atlanta
    While rather soon, don't be so quick to jump to conclusions. These days it's tough to rule out some doofus getting a pressure washer where it needn't be whether owner or someone hired to detail.
    Moot anyway since OP says the parking brake wasn't the culprit.
  7. Jan 18, 2017 at 4:49 PM
    gpb
    Atlanta
    You should be able to use the parking brake. I always do so whether driving an AT or MT.
    wilcam47 and shakerhood like this.
  8. Jan 18, 2017 at 4:52 PM
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    About to leave to pick up the truck. They took the whole thing apart and decided it was all fine. They wont replace anything. :mad:
    I also mentioned my vibrating hood issue and totally brushed me off.
    If they have to tow me again because they didn't fix the issue they are going to took pretty dumb.
  9. Jan 18, 2017 at 4:54 PM
    gpb
    Atlanta
    Uggh, that sounds annoying. Any other dealer you can call if/when it happens again?
    shakerhood likes this.
  10. Jan 18, 2017 at 4:56 PM
    shakerhood
    Southern Ohio
    I wonder if a malfunction caused the Atrac to apply brake pressure to that back wheel and after time it bled off.
  11. Jan 18, 2017 at 4:58 PM
    gpb
    Atlanta
    Interesting. A negative battery terminal pull next time it seizes might help discern if it's the electronics or mechanical. Now if a mechanical bit in the ABS system is sticking and holding pressure that might not work.
  12. Jan 18, 2017 at 5:39 PM
    bucktowntaco
    bucktowntaco Well-Known Member
    New Orleans
    2017 MGM DCSB TRD Sport
    I agree! Toyota has them drinking the kool aid
  13. Jan 18, 2017 at 5:50 PM
    FiaCobra
    FiaCobra Well-Known Member
    You're right, the brakes should not lock up with "little water", and I'm not sure you missed the post where I mentioned the 65 degree temperature. We can both agree on that. When I said water, I was thinking back on the time I had a frozen rear wheel on a Ford Freestar. There was 12" of snow on the ground and the temps dropped to "just below freezing" so it was a big fluffy wet snow. Bride came home from work and parked the van. The rear wheel seized up because it was wet from driving and the temps dipped a bit and froze everything up. That was the first thing that entered my mind when the OP mentioned his problem. What really made me think it was frozen because I'm living in the NE and it's winter now !!!
  14. Jan 18, 2017 at 7:13 PM
    SargeBSA
    Cascade Mountains
    2021 SR5 Tundra 4x4
    As a manual transmission owner and new Californian I understand the need for the parking brake but in Florida it's flat so I could easily get away with it. Haha.
  15. Jan 18, 2017 at 10:54 PM
    #35
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    32k miles in 1 year!!!
    Garrett75x likes this.
  16. Jan 19, 2017 at 4:32 AM
    #36
    98tacoma27
    Ben
    Not Beech Creek
    You're not supposed to tow them with any wheels touching the ground. They are supposed to be towed via flat bed or on dollies. Good thing he was only across the street.
    scottalot likes this.
  17. Jan 19, 2017 at 4:35 AM
    #37
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    but did you get a cheesy potato burrito ? :notsure: sorry about the brake issue, hope Toyota steps up and does the right thing.
  18. Jan 19, 2017 at 4:36 AM
    #38
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    haha, I am at just under 70K (69500) on my 15, took delivery in Jan 15
  19. Jan 19, 2017 at 4:52 AM
    #39
    CJREX
    CJREX Well-Known Member
    Georgia
    Wow!
    That is almost 70 hours a month behind the wheel, almost 2 full work weeks.
    Is that just your commute or do you drive for your work?
    JimboAnz[QUOTED] likes this.
  20. Jan 19, 2017 at 4:55 AM
    #40
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Roll Back wrecker.
