On the road after a month!TPS Question
Discussion in '1st Gen. Tacomas (1995-2004)' started by mrfixit4818, Dec 18, 2013.
  1. Dec 18, 2013 at 5:10 PM
    mrfixit4818
    mrfixit4818 [OP] Well-Known Member
    marietta GA.
    95 2wd
    Well I got my 2.4l 2wd Taco running good and on the road.Had the TPS out for inspection last week and put it back in but it looks adjustable.My scanner on live data says 9 percent running at idle.and about 75 wot(not running).It seems to be running good but its new to me so I don't know if its normal.Idle seems ok about 650ish.thanx
  2. Dec 18, 2013 at 5:56 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    If the tps is adjustable you will need an ohm meter and possibly a feeler gauge to properly adjust it. As well as the adjustment procedure instructions and specs. Is your truck a tacoma, or a pickup? they made both models that year.. I know the pickups 22re fps is adjustable. Throttle percentage is not actually measured in 1-100%. The lowest and highest numbers are different car to car, so thats nothing to worry about.
  3. Dec 18, 2013 at 6:22 PM
    mrfixit4818
    marietta GA.
    95 2wd
    Its a Tacoma.176k miles.
