? On Transmission Fluid(manual)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by danteisme, Dec 10, 2010.
  1. Dec 10, 2010 at 6:56 AM
    danteisme
    danteisme [OP] Well-Known Member
    Vandergrift, PA
    06 DCSB Sport, 96 Integra GSR
    so now that its cold again, my truck shifts like hell. i hate this, in the summer, my truck drives like a dream, in the winter i have to fight with it. my truck has 66K miles on it, i ve owned it since 40K so there is about 13-14K miles on the 75 90 synthetic gear oil i used in the tranny. like butter in the summer, like trying to shift through gravel in the winter. anyone else have this problem, or anything i can do to make it shift better? its usually pretty good once it gets up to operating temps but in this weather that usually doesnt happen until i get to work.
  2. Dec 10, 2010 at 7:02 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    had the same problem on my 96, and it seems to be happening on my 08 now that temps have dropped. I am not sure if there is really anything to do besides fighting it until things warm up. mostly sucks when u can't hit first gear.
  3. Dec 10, 2010 at 7:03 AM
    danteisme
    Vandergrift, PA
    exactly! i hate coming to a stop at a stop sign from like 2nd or 3rd gear, and then having to fight to get back into first gear.
  4. Dec 10, 2010 at 7:37 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Strange that you have problem with Synthethic. Sometimes takes two changes to get rid of old regular oil. Plus you can always try adding some Friction modifier to help.
    I did not have this problem in my 1gen Toyota but my VW needed friction modifier in manuall tranny to work normally
  5. Dec 10, 2010 at 7:48 AM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I do notice it gets stiff on those cold mornings. In 1st you really have to come to a complete stop. But beyond that I have no trouble getting into 1st. I have stock fluid and 48,000 mi. Interested to hear what others say.
  6. Dec 10, 2010 at 7:49 AM
    danteisme
    Vandergrift, PA
    yeah i used friction modifier in my integra, the pennzoil synchromesh. but that tranny had 175K miles on it haha
    once the weather breaks, i'll try swapping out the fluid one more time to see how it works. i'll also ask the dealer if friction modifier in the fluid will do any harm to these transmissions
  7. Dec 11, 2010 at 4:03 AM
    reg boulette
    reg boulette Well-Known Member
    Using GL 4 instead of GL 5 synthetic might make a small difference. Manual specifies either, but the 4 is preferred for transmission type gearing.
  8. Dec 11, 2010 at 5:12 AM
    Tckwarrior
    Tckwarrior Well-Known Member
    Aaron
    Damascus OR
    08 RegCab Superwhite
    3 inch revtek lift,American Eagle 197 Black Wheels 17x9 Boltpattern 6x5.5 , 285/70/17's with BFG km2s U-haul class 3 tow hitch, Better built toolbox. Trail-gear 58 inch Rock-sliders
    I had this problem when I used royal purple synthetic fluid in my tranny. I thought there was something wrong with my transmission so I decided to switch it back to regular valvoline synthetic and it performs fine now.
  9. Dec 11, 2010 at 7:02 AM
    Ocean's
    Ocean's Well-Known Member
    That's the same thing my girl says...:rolleyes:
