"Onboard Air system"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by toku58, Jul 5, 2009.
  1. Jul 5, 2009 at 12:15 PM
    toku58
    toku58 [OP] Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    Here my onboard air system project.
    I purchased a MasterFlow 50 compressor from CostCo $49.
    Mounted it under the side compartment of the bed:
    Picked up a 9 gal air off Ebay, made custom brackets to bolt it up to my tow hitch. (I didn't want to drill anything)
    Wired it up and Mounted the fitting to the bumper and called it a day.
    Oh? I don't carry a spare so I had the room under there.:D
  2. Jul 5, 2009 at 12:20 PM
    Chad
    Chad Well-Known Member
    Chad
    Cary, NC
    09 V6 Access Cab TRD Sport
    Kenwood DMX-7704S Headunit -- Blackvue DR-470 Dashcam -- Pioneer TS-A1685R Speakers in Front -- Suntek CXP 40 Front Tint -- Access Vanish Roll-up Tonneau -- Wet Okole Seat Covers -- Fog Lights on Anytime -- PnL Powered Tailgate Lock -- DTRL "Stealth Mode" -- LED Footwell and Cup Holder Lights -- Map Lights ON with Dome Light -- Shorty Antenna -- AC Line Extension Mod -- Access Cab Rear Headrest Removal
    this is pretty sweet dude!
  3. Jul 5, 2009 at 12:34 PM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
    Didn't you do that a couple months ago? I remember seeing those exact same pictures...
  4. Jul 5, 2009 at 12:37 PM
    toku58
    Mall Crawler!
    Yeah I did all these mods a while ago. It was posted on another forum. I just figured people here might be interested.
    I sort of ran out of ideas for my truck? Haven't done any new mods lately.:(
  5. Jul 5, 2009 at 12:37 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    ^.....regardless if it was...still a very clean install with a good deal of attention to detail...has me thinking..
  6. Jul 5, 2009 at 12:40 PM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Yeah, I just didn't notice he was transferring his mods from TN to TW, but now I see... it was a brief moment of Deja Vu...
  7. Jul 5, 2009 at 12:42 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    id be worried about smashing the tank or the bracket on a rock
  8. Jul 5, 2009 at 12:43 PM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    Those must be some vicious malls you crawl!
  9. Jul 5, 2009 at 12:51 PM
    toku58
    Mall Crawler!
    yeah! Running over those soccer moms to fight for a parking is brutal!:D
    But as you can see the hitch is the lowest point of the rear, so that would drag before the tank hits.
  10. Jul 5, 2009 at 4:50 PM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    how long to fill your tire from 10psi? This compressor seems very slow, as soon as your tank is empty it must take forever to fill up.
    and this rear bracket would not hold for 10 minutes off roading!
  11. Jul 5, 2009 at 4:54 PM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    Do you have a check valve between the compressor and tank.
    I have had problems finding a check valve that works well with this compressor.
  12. Jul 5, 2009 at 8:37 PM
    toku58
    Mall Crawler!
    I'm not sure? Still never had to use it. But I'm sure since I mostly go fishing with my truck, and not looking for "BgiFoot" the brackets will last a very long time.
    I picked up the check valve from "Grainger" it's mounted next to the tank. Seems to work good so far?
  13. Jul 5, 2009 at 10:43 PM
    DDD
    Derek
    Santa Clarita, CA
    Interesting, I picked up this check valve from Grainger but I have been having problems with it. It holds pressure, but when I turn on the compressor the ball inside gets stuck in the open poisition allowing the air to excape through the compressor.
    It seams to me that this check valve is not rated correctly for the CFM that this compressor puts out. The ball is pressed too hard and gets stuck. I have been looking for a higher quality check valve that is the same size.
  14. Jul 5, 2009 at 11:35 PM
    toku58
    Mall Crawler!
    Wow! That the same valve I used. I haven't had any issue yet. I'll keep an eye on it.
  15. Jul 6, 2009 at 6:35 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    That has to be one of the best mods ever! Great work!
  16. Jul 6, 2009 at 6:37 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    Nice job. OBA is one of the best mods I've done. it's useful a lot more ways then just for tires.
  17. Jul 6, 2009 at 7:14 AM
    jla888
    jla888 Well-Known Member
    interesting thread here on that compressor.
  18. Jan 10, 2012 at 11:47 AM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
  19. Jan 10, 2012 at 11:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Don't expect many updates- This is 2+ years old...
  20. Jan 10, 2012 at 1:36 PM
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Nice! are there any more OBA set-ups around the forum? I searched, but came up with nothing.
