Onboard Pressurized Water System for the 2005-Current Toyota Tacoma OBW
Discussion in 'Buy / Sell / Trade - Other' started by ProForce, Sep 26, 2016.
Overall Satisfaction w/ product and service? If you have received less than 5☆ service please PM me!
  1. 5 ☆☆☆☆☆ - Extremely Satisfied
    55 vote(s)
    84.6%
  2. 4 ☆☆☆☆ - Satisfied
    3 vote(s)
    4.6%
  3. 3 ☆☆☆ - Nuetral
    3 vote(s)
    4.6%
  4. 2 ☆☆ - Dissatisfied
    2 vote(s)
    3.1%
  5. 1 ☆ - Extremely Dissatisfied
    2 vote(s)
    3.1%
  1. Jul 15, 2018 at 8:42 AM
    #1101
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Interested
  2. Jul 17, 2018 at 6:19 AM
    #1102
    sd1uh8as
    sd1uh8as Well-Known Member
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
    Interested
  3. Jul 17, 2018 at 9:49 PM
    #1103
    regmilla31
    regmilla31 Well-Known Member
    Los Angeles, CA
    Interested!
  4. Jul 26, 2018 at 2:59 PM
    #1104
    chadtoks
    chadtoks Member
    Maui, Hawaii
    1998 TRD 4WD
    Interested
  5. Aug 1, 2018 at 3:36 PM
    #1105
    ProForce
    ProForce [OP] IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Looks like we have about 5... Anyone else?
    sd1uh8as likes this.
  6. Aug 1, 2018 at 6:30 PM
    #1106
    ProForce
    Anthony
    Alaska
    You guys still interested? I can make a run of 5 if all 5 are committed still.
    Pricing is $200 shipped and can be ready in a couple weeks. Payments required up front though.
    Please post if you're in or out. Thanks everyone
  7. Aug 1, 2018 at 6:46 PM
    #1107
    sd1uh8as
    Ivan
    Bay Area
    2018 Tacoma OR DCLB
  8. Aug 1, 2018 at 6:53 PM
    #1108
    Mrguitarguy01
    Mrguitarguy01 Well-Known Member
    I'm in.
  9. Aug 1, 2018 at 7:02 PM
    #1109
    ProForce
    Anthony
    Alaska
    Pretty sure @regmilla31 is also in based on a recent PM, so hopefully we can get the last 2.
  10. Aug 1, 2018 at 7:41 PM
    #1110
    Mrguitarguy01
    I have a first gen xtra cab. I was curious if you had a way to make a clean install like you did the 2nd gens.
  11. Aug 1, 2018 at 11:19 PM
    #1111
    ProForce
    Anthony
    Alaska
    Only done 1 first gen before and i remember it was pretty difficult to make clean. We ended up putting the pump under the bed exposed to all the elements and the connections on the rear bumper. Although he had a custom bumper though and we needed extended lines i think. Youd honestly have to wing it. If you are local in socal i can take a look at the truck and help come up with a custom design
  12. Aug 2, 2018 at 1:57 AM
    #1112
    regmilla31
    Los Angeles, CA
    Yup! I'm in!
  13. Aug 2, 2018 at 7:41 AM
    #1113
    emiliangrigore91
    emiliangrigore91 Well-Known Member
    Sorry I didnt read the 56 pages, but I was wondering. Are those connection compressed air quick disconnects? Im just thinking that if I get this and want to do some modifications in the future I may need couple more. But if they are regular compressed air connections I have some at home that I can use.
  14. Aug 2, 2018 at 8:56 AM
    #1114
    ProForce
    Anthony
    Alaska
    Yep, they are compressed air quick connects. Keep in mind that cheap ones will rust up inside so you need good connections preferably with stainless steel ball bearings inside
  15. Aug 2, 2018 at 9:03 AM
    #1115
    emiliangrigore91
    ok. Well, that would be down the line when I will add a water heater and stuff. but for now this will work. I am in if you still have a spot open
    ProForce[OP] likes this.
  16. Aug 2, 2018 at 9:23 AM
    #1116
    ProForce
    Anthony
    Alaska
  17. Aug 2, 2018 at 10:14 AM
    #1117
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Is there any concern about the lead in the fittings? Wouldn't this be better in stainless?
  18. Aug 2, 2018 at 10:22 AM
    #1118
    jmauvais
    NorCal
    ...stuff
    I’m in SoCal. How much for it if I pick it up?
    Also, I forgot. Isn’t there an option to leave the input and output in the cubby to avoid drilling the bed? I think I remember someone doing it that way.
  19. Aug 2, 2018 at 10:56 AM
    #1119
    ProForce
    Anthony
    Alaska
    Many if not all of these fittings cant be found in stainless. Brass is normal for water plumbing. Although brass does contain lead, California prop 65 helped reduce lead content in brass parts that come in contact with water. The large adapter from the hose to spray nozzle is lead free and the quick connects should contain extremely minimal lead content with not enough leaching to be of health concern. Also note that although the system contains food grade tubing, its not necessarily designed to be used for drinking water. This is meant for potable water to clean surf boards, camp dishes, etc. You can use it for drinking water, but it wouldnt make sense to pressurize your drinking water.
    I can reduce $15 for any local pickup. So $185 picked up
    tacofort[QUOTED] likes this.
  20. Aug 2, 2018 at 11:00 AM
    #1120
    ProForce
    Anthony
    Alaska
    And yes, you are welcome to install the connections inside the cubby to keep it contained. Many users have done it this way and i have installed several like that as well. Works great like that
