*CLOSED* Onboard Pressurized Water System *Group Buy*
Discussion in 'Closed Group Buys' started by ProForce, Nov 1, 2016.
  1. Nov 1, 2016 at 11:26 PM
    ProForce
    ProForce [OP] IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    *** CLOSED ***
    WILL CONTINUE GROUP BUY IN THE SPRING
    **Group Buy Feeler**
    Hello TW! I am considering running a group sale on my new onboard pressurized water system for the 2005-2017 Tacoma.
    Product details here:
    www.tacomaworld.com/threads/new-onboard-pressurized-water-system-for-the-2005-2017-toyota-tacoma.453005/
    The discount would be as follow:
    Regular Price = $200
    15 buyers get 10% off ($180)
    25 buyers get 20% off ($160)
    Shipping remains a flat rate priority delivery for $10 to anywhere in the 50 states. That is 1-3 day delivery including HI and AK.
    Group buy would be capped at 30 units.
    The first 15 units would ship as soon as the group buy starts, the rest would have a 3-5 week turnaround time since I would need to build more kits and have to reorder all the parts.
    This is a feeler only. Pricing and quantities subject to change based on interest. This would be the last sale of the year and once sold out, will likely be the last batch of kits I make.
    If this goes live, I would require a $50 deposit from anyone in the 15+ batch who has to wait 3 to 5 weeks. This is secure your place in the GB.
    Please copy paste the list and add yourself to sign up.
    0uTkAsT and thebaker like this.
  2. Nov 1, 2016 at 11:26 PM
    ProForce
    Anthony
    Alaska
    1.
    2.
    3.
    4.
    5.
  3. Nov 1, 2016 at 11:52 PM
    thebaker
    thebaker Well-Known Member
    Byron
    NorCal
    Upgraded to a 3rd gen
    Never ending......$$$
    1.thebaker
    2.
    3.
    4.
    5.
    ProForce[OP] likes this.
  4. Nov 2, 2016 at 12:00 AM
    MTNHABITOVERLAND
    MTNHABITOVERLAND Well-Known Member
    2016 Tacoma Camper Build Instagram: @mountainhabit
    Vagabond Outdoors Camper
  5. Nov 2, 2016 at 6:51 PM
    hamiltonuh60
    hamiltonuh60 Well-Known Member
    Texas
    2016 DCSB TRD OR 4WD
    Frontrunner, CVT RTT, Foxwing, Switch Pros, OGE, Fox, ADS, TC UCA, Dakar, Superbumps, U bolt flip, blah blah blah
  6. Nov 2, 2016 at 8:05 PM
    MAV2
    MAV2 Overland Taco California Edition
    MITCH
    Bay Area, Californication
    Overland Tacoma
    Icon Stage 5.5 / Deaver Expedition Leaf Pack / Pelfrey Front Bumper / Smitty X20 Winch / Factor 55 Flatlink / Pelfrey Rear Bumper with tire carrier (on its way) / Frontrunner Slim II Roof Rack / Leitner Design Active Cargo System / Custom Grille / S-Pod with bluetooth / IBS Dual Battery Management System / ATO Dual battery Tray with Optima 34/78 / 2" Trimmed Fender for future 35" tire /
  7. Nov 3, 2016 at 6:07 AM
    WhiteNight
    WhiteNight Well-Known Member
    PDX
    13 DCLB SPORT
    Dynamat, Rigid E series 30", Rigid SR2 combo/Rigid grill, Redline elite hood struts, Clear Bra all over
    Hey there I have a question looked like your pump was lacking pressure when I watched the demo video is it even rewatching 50psi pressure? Ultimately this system leaves me concerned based on the need for power and I have been around pumps long enough to know how they do all eventually fail.
  8. Nov 3, 2016 at 7:59 AM
    ProForce
    Anthony
    Alaska
    This pump only supplies 1.2 GPM @35 PSI. its not meant to be a garden hose, but i purposely went with a small pump in an effort to conserve water. Typically while camping, out on the trail, or really anywhere that this might be useful, youll likely have limited water supply, so going with something small and low pressure gives you just what you need to get the job done while preserving your water supply. in regards to the pump failing... This same pump is used on RVs, boats, and other applications every day. will it eventually fail? sure. everything eventually fails. Its lifespan will also be decreased with improper care and lack of maintenance, but i think that applies to just about every mechanical thing that exists. This pump is backed by a 4 year warranty which is pretty outstanding. If after that time the pump fails you, a direct replacement can be purchased for $30 online or any RV or Boat store and the rest of the system will still be good. You also mentioned your concern for it needing power... the good news is that since this is only a way for you deliver your water, but in the event of something catastrophic where you may become stranded or even just out camping and you have a pump failure or loss of power, your water source is still completely accessible and unrestricted, you just wont have a way to pressurize it, which isnt necessary. Compare that too something like the water port, which is also currently on GB. if the Valve breaks in that, or there is a small crack or failure in the design, your only water source is now trapped inside and unaccesable to you, which id bad news. and you are also limited to only 3.3 gallons that their system holds. I do understand many people would prefer not to deal with wiring, but, after much research, i decided that i would rather have
    A. any water source i ever wanted
    B. no limitations to my water supply
    C. unlimited pressure without worrying about using hand pumps to repressurize
    D. full access to my water in the even of failure.
    Other self contained systems without power require you to carry a large permanently mounted tank that get pressure from a garden hose, which will almost Never be available to you while out in the backcountry or camping, or require an air compressor or bicycle pump to make functional should you have to refill or even lose pressure on your original 3.3 gallons. I always welcome people to express their concerns because i put a lot of time and thought into designing this to eleviate just about every comcern possible. if anyone finds something that i dont have an answer or explanation for, then i will quickly learn what changes should be made to improve the product design. Please let me know if you have other concerns i can address for you.
  9. Nov 3, 2016 at 10:12 AM
    ProForce
    Anthony
    Alaska
    This Feeler will close on Sunday November 6th.
    More details to come as we get closer. Those who signed up already wont be left with nothing if we dont hit the stretch goal of 15 min. Keep an eye on your inbox this weekend ;)
  10. Nov 3, 2016 at 11:51 AM
    Kumunoy
    Kumunoy Well-Known Member
    Florida
    2016 TRD OR 4x4 DCSB
    I'm interested but want to read through all of your posts about this after work. Put me down as pending.
  11. Nov 3, 2016 at 12:39 PM
    WhiteNight
    PDX
    13 DCLB SPORT
    You mentioned something about a way to heat the water can you elaborate more? Maybe with specific cost or install procedure?
  12. Nov 3, 2016 at 12:53 PM
    WhiteNight
    PDX
    13 DCLB SPORT
    Another question sorry to be a bit of a burden by how is it attaching to the water supply. Just drop the clean water supply in to an opening and turn the pump on?
    fredgoodsell and ramonortiz55 like this.
  13. Nov 3, 2016 at 12:55 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    you're on a roll today.. :D
    WhiteNight[QUOTED] likes this.
  14. Nov 3, 2016 at 12:56 PM
    WhiteNight
    PDX
    13 DCLB SPORT
    I'm not too busy working haha just enough to keep the checks coming.
  15. Nov 3, 2016 at 2:18 PM
    ProForce
    Anthony
    Alaska
    Lol that emoji cracks me up every time
  16. Nov 3, 2016 at 2:20 PM
    ProForce
    Anthony
    Alaska
    Ill be stuck at work till about 9pm PST with no phone or public Internet access. ill address all these later tonighy for you :)
    There is a ton of good info in the original product post which will answer these for you. just follow the link in the OP and ill clarify more tonight
  17. Nov 3, 2016 at 4:36 PM
    Kumunoy
    Florida
    I'll probably pass on this one. Thanks though.
    ramonortiz55 likes this.
  18. Nov 3, 2016 at 8:20 PM
    ProForce
    Anthony
    Alaska
    No problem ^
  19. Nov 3, 2016 at 8:25 PM
    WhiteNight
    PDX
    13 DCLB SPORT
    Yeah I'm not sure I can get on board looks to be vastly more expensive and in depth.
  20. Nov 3, 2016 at 8:43 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    sub'd
