once you go synthetic can you ever go back
Discussion in '2nd Gen. Tacomas (2005-2015)' started by luk8272, May 15, 2008.
  1. May 15, 2008 at 3:22 PM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    I have heard talk over the years that once you change to synthetic you have to stay with it. I don't see why. I can understand that if you have an older vehicle your seals will be worn so you can't switch to synthetic with high mileage or an old vehicle. If you start new with syn. then can you switch back in later years. Just wanting to pic yalls brains.
  2. May 15, 2008 at 3:37 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    yes, check out mobil1 site for info.
  3. May 15, 2008 at 3:59 PM
    BLOCKADE
    BLOCKADE Well-Known Member
    TRD Off Road
    Weather Tech Floor Liners, Front Bed D-Rings...
    When synthetic first came out it was formulated in such a way that if you used it, you had to keep using it. If I remember correctly, its chemical composition would effect the seals in such a way that if you put it in and then took it out the seals would crack and dry up. But they have gotten better at making synthetic in the last five years or so.
  4. May 15, 2008 at 6:15 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    I've never seen any proof that that is the case. If there's a scientific test that some how proves this, I'd be surprised. But, you can go to bobistheoilguy.com and peruse their forums. Tons of info there.
  5. May 16, 2008 at 5:12 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    Thanks guys I hang around with alot of much older guys ang hot rodders and they aren't nearly as right as they think they are. I never really thought much of it but wanted to see what some of yall thought. Thanks
  6. May 16, 2008 at 7:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    But why would you go back to regular oil?
  7. May 16, 2008 at 8:27 AM
    luk8272
    luk8272 [OP] Poodoo
    Lucas
    Southern Louisiana
    I wouldn't. I was just curious and sitting around at work with nothing to do.
  8. May 16, 2008 at 11:04 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    also, how do they make those semi-synthetic oils....i think that right there definitely answers your question...!
  9. May 16, 2008 at 5:28 PM
    wawireguy
    wawireguy Well-Known Member
    You can mix synth and normal oil.. They are interchangeable and mixable.
  10. May 16, 2008 at 9:05 PM
    RememberMorrison
    RememberMorrison Yeah, I'm that Guy
    Atlanta
    08 Silver DC SB TRD OR TOW PKG
    Thats the rumors. I wouldn't recommend going back from syn to regular dino oil.
