One different wheel + tire
Discussion in 'Wheels & Tires' started by tacoma2005, Jul 1, 2009.
  1. Jul 1, 2009 at 9:05 AM
    tacoma2005
    tacoma2005 [OP] New Member
    I recently purchased a 2005 Tacoma. The back left wheel and tire are different from the other three on the truck. It seems like they may be from the spare, since that's no longer there under the truck.
    I love the truck, but it seems like this is causing it to pull to the right at highway speeds and also a slight vibration. The tire is the same size as the others, and the wheel seems to be the same as well.
    I'm wondering if y'all think a rotation/balance will correct this problem? If not, should I look into a new set of 4 tires (and maybe a replacement OEM wheel)? I don't really have any history on the current tires or what caused the wheel to be changed.
    Thanks!
  2. Jul 1, 2009 at 9:07 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I would definitely get a matching wheel and have the tire mounted on it. I am speaking out of my ass but unless the specs (weight, balancing, backspace, offset, etc) are exactly identical, I can't see any good coming from the situation
  3. Jul 1, 2009 at 9:08 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I think having them balanced would't hurt. If it doesn't fix things maybe go for a set of tires. Personally I couldn't handle having 2 different rims on 1 truck.
    Welcom to TW.
  4. Jul 1, 2009 at 9:40 AM
    tacoma2005
    Thanks a lot for the help. I'll probably end up getting new wheels and tires on all four.
  5. Jul 1, 2009 at 9:42 AM
    DanGer
    I am not sure if any harm could come of it, but getting 4 matching sounds like the safest and most aesthetically pleasing route. Where are you located?
  6. Jul 1, 2009 at 10:10 AM
    tacoma2005
    I'm in Austin, Texas. I'll probably be asking a lot of questions on this forum in the future. It's really nice to get such quick responses.
  7. Jul 1, 2009 at 10:13 AM
    DanGer
    Thats what its here for! Also try and browse around the wheel tire forum. Many MANY questions have been asked and issues have beet dealt with over and over again (including a few posts by me). Maybe you can get some questions answered before you even ask. And if not, ask away!
