One fog light brighter than other... Put in new 9145's (didn't help)?
Discussion in '4 Cylinder' started by litegide24, Dec 3, 2012.
  1. Dec 3, 2012 at 6:05 PM
    litegide24
    litegide24 [OP] Well-Known Member
  2. Dec 3, 2012 at 6:08 PM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Prolly need to align the light bulb
  3. Dec 3, 2012 at 6:12 PM
    LDurchy
    LDurchy Well-Known Member
    Cedar Falls, Iowa
    Perhaps a wire connector has some resistance due to rust or a poor connection.
  4. Dec 3, 2012 at 6:16 PM
    BradleyScottETC
    BradleyScottETC Class IV Category 8 Elite VIP Member (Only)
    Bradley
    Lake County, FL
    10 4.0 AC 4x4
    It could be the relay, if the contact points are corroded or making poor contact- I just don't see that your fogs would be on independent relays.
    It could be a poor connection, either + or -.
  5. Dec 3, 2012 at 6:31 PM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    Can you move the harness enough to plug one harness end to the other lamp and see if the brghtness changes? You mentioned using a generic harness, often that means too small of wire (resistance).
  6. Dec 4, 2012 at 4:56 AM
    wolftree
    Rick
    Ohio
    Try the swapping of the harness first to see if that makes a difference. You would need a very precise meter (very, very expensive) to read a difference in resistance in that short length of wire.
    I just had another thought. Compare both lamp housings to see if they are the same manufacturer. You mentioned you bought them used. Perhaps one is OEM Toyota and the other is a replacement.
  7. Dec 4, 2012 at 10:51 AM
    BamaToy1997
    Bill
    Navarre, FL
    Check for corrosion (As you mentioned you did) but include all connections, as well as the ground itself. Swap left bulb with right bulb. If the dimness stays where it was, you HAVE to have a poor connection or corrosion somewhere on that circuit.
  8. Dec 4, 2012 at 11:15 AM
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I had an intermittent problem with one of mine & it turned out to be the connector. I unplugged it & bent the metal tab on the inside so it would make better contact & haven't had a problem since.
  9. Dec 8, 2012 at 9:03 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    2020 Red SR 4x4 Taco
    "Access" Tonneau cover. Bed Mat. Hitch, Timbren SES
    Just a thought ...
    If It's possible to measure the voltage at both bulbs/connections when they are on?? Tthey should be the same. If not you have a voltage drop (i.e. resistance) on the lower voltage line. If So, continue to measure the voltage (with the bulb on) farther back on the circuit (i.e. each prior connector, the relay , etc.) until they do measure the same. The problem will be between the last good/bad point measured. This way you only need a fairly cheapie volt meter.
    Hope this helps ...
