One front wheel not spinning freely
Discussion in 'Technical Chat' started by nh_yota, Oct 23, 2017.
  1. Oct 23, 2017 at 9:08 AM
    nh_yota
    nh_yota [OP] Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    I was working on my truck this morning and since the front end was up off the ground I decided to check the front wheel bearings for play and I noticed something odd. With the front of my truck up on a jack and the transfer case in 2WD, the passenger side front wheel spins easily by hand (as it should) but the driver side front wheel takes a good amount of force to spin it. The first thing I thought was that the driver side caliper was dragging so I checked the temperature of the caliper and rotor, and it wasn't hot or any warmer than the other side. I had been driving around running errands for a few hours so I figured the caliper would be hot if it was dragging.
    What might cause this? Bad wheel bearing? Transfer case issue?
  2. Oct 23, 2017 at 9:14 AM
    Clearwater Bill
    Billy
    Largo Florida
    Pull the wheel off and recheck the brakes. The rotor would get much hotter than the caliper in a light drag situation. It doesn't take much to make it hard to turn by hand.
    And the drag could have started at the end of your driving, thus no real heat.
    If all that looks ok, including fairly equal pad wear (inner and outer, and then compare to the other side) pull off the caliper and see how things rotate.
    If easy, it's brake related. If still hard, it's something deeper.
  3. Oct 23, 2017 at 9:31 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Depending on how much harder it is to spin, it might just be the drag of spinning the gears in the differential. The passenger side CV doesn't hook up until the front ADD is shifted when you put it in 4WD, but the drivers side always stays engaged with the diff gears. It will always be a little harder to turn than the passenger side, and you'll probably hear some additional noises of the gears turning when you spin it.
    ClassyTacos and Magiriano like this.
  4. Oct 26, 2024 at 9:49 PM
    Magiriano
    Magiriano Underdog by Doekter TUNED
    Alex
    Calgary, Alberta
    2022 4Runner TRD PRO 2023 Tacoma TRD PRO MT
    Westcott Front lift with Eibach Pro Coils, Icon AAL rear, 17" Rims on 285/70/17 Toyo Open Country AT3 Load Range E, Full PPF Clear Wrap, Diff breater relocation, Greenlane Offroad Stump Bumper, Greenlane Offroad full engine skidplate, Greenlane Offroad Transmission Skidplate, RA Motorsports Gas Tank Skidplate, DEFA Trickle Charger with Cab Heater, CBI DOM 120 Rock Sliders, Greenland Offroad cab height Box Rack, Sherpa Roof Rack with Baja Designs S8 Lightbar, Tailgate lock, Underdog Tune by Doekter TUNED
    Thanks for posting this.
    I was working on my 2022 4Runner today and experienced the same thing, passenger side wheel spins freely, while the driver's side goes than stops as if something is binding, takes quite a bit of effort to turn it past that spot then it turns again freely for a bit before again it stops.
    No v8bration while driving, no noise.
    I did replaced the CV inner boot a few months ago, and didn't marked it when I took it out so no idea if I put it back correctly...or it might be off by a few degrees.
    It doesn't feel like a warped disc, but I'll take the caliper off tomorrow and give it a try.
  5. Oct 27, 2024 at 9:16 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    If the suspension is fully drooped out the CV might be at the limit of its articulation, which will make it seem “sticky” in spots to rotate as well. There is no correct orientation or phasing for the CVs though, if they’re seated all the way in then you’re good. You could try putting it in 4wd, then both sides should have about the same amount of drag to rotate.
    I have a 2022 4runner as well, great truck.
    Magiriano[QUOTED] likes this.
  6. Oct 28, 2024 at 12:20 AM
    Magiriano
    Alex
    Calgary, Alberta
    Thanks for the reply.
    I was getting paranoid about not marking out the CV Axle and how it could be off by a few degrees, but yes, it feels like it's at its limit of articulation.
    I'll try the 4WD.
    I appreciate the reply.
    drr[QUOTED] likes this.
