One Head Light Brighter
Discussion in 'Lighting' started by friction, Feb 24, 2015.
  1. Feb 24, 2015 at 5:40 AM
    friction
    friction [OP] Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    I recently replaced both headlight bulbs on my '08 with standard bulbs. One light was burnt out, so I thought I might as well put two new ones in.
    I just noticed one bulb (the passenger side) is much brighter when they are both on low beam, and when on bright they are the same intensity. Any suggestions? Electrical is not my forte, but could this be a fuse? It almost seems the passenger side is "stuck" on bright...
    Thanks in advance.
  2. Feb 24, 2015 at 5:42 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you buy single pack bulbs or a dual pack of bulbs
  3. Feb 24, 2015 at 6:03 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    I bought 2 packs, but I'm certain the part # was the same. Are you thinking one was the wrong bulb?
  4. Feb 24, 2015 at 6:05 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I don't know if it makes a difference one bulb could have just been sitting on the shelf for a while. They are both the correct bulb number correct?
  5. Feb 24, 2015 at 6:15 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    As far as I know. They were in identical packaging (#s too), but it has been a month or so and I've already discarded the containers. I don't know which is the correct intensity, but I suspect the passenger side is off as it is almost blinding on low.
    Perhaps I should just change that one again and see what happens.
  6. Feb 24, 2015 at 6:17 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes do you have other bulbs to switch out to, to see if there is a difference?
  7. Feb 24, 2015 at 6:27 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    No, I'll have to buy one (should have kept a spare!). It is sort of a PITA to get to as I have to remove the windshield washer reservoir to get my hand in there. I'll start with a replacement this weekend.
  8. Feb 24, 2015 at 8:41 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Take the bright bulb out and swap it to the other head light to see if it's still brighter than the other.
  9. Feb 24, 2015 at 8:50 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Now you're talking. Thanks for the suggestion. Old age is eliminating any pragmatism I had left.
  10. Feb 24, 2015 at 8:52 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Wow what a dope, never even thought about that.
  11. Feb 24, 2015 at 8:57 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    That makes two of us.
  12. Feb 24, 2015 at 9:06 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Lol it happens. Doing that you can at least see if its the bulb or wiring/fuse related on one headlight side.
  13. Feb 24, 2015 at 9:10 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    could be corrosion in the bulb connector as well, limiting the current to the dimmer bulb. Also aim of the headlights may make one headlight seem brighter when just looking at it if it's aim is way off compared to the other.
  14. Feb 24, 2015 at 9:12 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Thanks everyone. I had them adjusted at the dealership when I added 5100s up front and haven't touched the adjustment since. Perhaps this was an ongoing issue, but it was only reported to me (twice) the first week I replaced the bulbs...I'll report back.
    Thanks again guys.
  15. Mar 6, 2015 at 9:32 AM
    friction
    Charleston, SC
    '08 4X4 RC SR5
    Turns out the dim bulb is me. I finally took a look yesterday and I must have knocked loose the wire clamp that secures the bulb when I reinstalled the rubber boot. The bulb was just not secure so it was at an angle and, therefore, shining brighter.
