One high powered 8 inch sub
Discussion in 'Audio & Video' started by Rockoma5, Feb 13, 2020.
  1. Feb 13, 2020 at 8:53 AM
    Rockoma5
    Rockoma5 [OP] Well-Known Member
    St Louis
    2019 TRD Sport Lifted
  2. Feb 13, 2020 at 11:12 AM
    Deacon Blues
    Deacon Blues Well-Known Member
    Colorado
    2017 SR5
    I played around with a much cheaper Skar 8 in a ported box getting around 500W. In our little truck cabin it gets super low and borderline painful real quick.
    1000W and the right box, those subs you posted would start flexing panels i have no doubt.
    But of course it's a trade off, tight and punchy or big and boomy, tough to find a common ground.
    Rockoma5[OP] likes this.
  3. Feb 13, 2020 at 11:20 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    No.
    I got an 8" underseat Powered Sub.
  4. Feb 13, 2020 at 8:44 PM
    Rockoma5
    St Louis
    I emailed massive audio and they said 5.4 is mounting depth for the Hippo xl84r which is 900 watts rms. I have a Fosgate BD1000 and it would be perfect for this and a custom ported box. I though about JL dual micro sub 8 but I’m afraid of overloading the W3 8 inch subs
  5. Feb 14, 2020 at 11:16 AM
    lsukevinc
    lsukevinc Well-Known Member
    Kevin
    2019 cement limited
    i have the skar 8" as well. although i need to re think my box it sounds decent for $69. Heck anything was better than the stock JBL
  6. Feb 15, 2020 at 8:10 AM
    Rockoma5
    St Louis
    I looked at the Skar also. Leaning toward massive audio xl84r since mounting depth is 5.4 and the watts are 900 rms. I emailed them for the stats and they are super nice and responsive. I have an older Rockford Fosgate BD1000.1 which is about 1100 rms in birth sheet into 2 ohms
    FEATURES:
    • Heavy Duty, Rugged Industrial Textured Cast Aluminum Basket
    • High Energy Double Stack Strontium Magnet Structure
    • Dual Impedance High Temp Aluminum 2.5” Voice Coil Former with Kevlar Spunlace
    • Kevlar Fiber Reinforced Non-Pressed Paper Cone with Industrial Textured Finish
    • Red Stitched Edge to the Cone’s Edge for Added Strength
    • Over Sized Mirror Image Dual Poly / Nomex Spiders
    • Black Anodized One Piece Pole-Plate for Added Motor Force
    • Heavy Duty Direct Input Wires Connection to Voice Coils
    • Reinforced Fiberglass Woven Dust cap for High Power Applications
    • Custom Tooled Rubber Gasket and Magnet Boot
    SPECIFICATIONS:
    Size 8"
    Peak Watts 1800
    RMS Watts 900
    Cone Non-Pressed Paper
    Voice Coil 2.5" Dual 4 Ohm
    Surround Tall and Narrow Foam
    Magnet 120oz Strontium
    Terminals Heavy Duty Direct Input Wires Connection
    Basket Cast Aluminum
    Tinsel Leads Heavy Duty Triple
    X-Max 15mm peak to peak
    SPL 78.58dB
    Ported Box 12"H x 11"D x 11"W (Round Port 3" x 8")
    Sealed Box 1.1 ft3
  7. Feb 15, 2020 at 12:38 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Back in 2002 I ran 4 JBL gtx8 subs in my car. 600 watts from a ppi pc2150 and they made your eyes vibrate till you couldnt see.
    A single high output 8 can be a beast in a good box
  8. Feb 16, 2020 at 7:29 PM
    revin9k
    revin9k Well-Known Member
    Save up and grab a stealth of by JL. Best hands down
  9. Feb 17, 2020 at 2:02 PM
    Rockoma5
    St Louis
    Looked into those....a lot of coin there and it is not a ported box. I also have a Rockford Fosgate BD1000.1 which is way more than those JL's can handle.
  10. Feb 19, 2020 at 10:50 PM
    Sandlyfe73
    Sandlyfe73 Well-Known Member
    Vegas / Henderson
    2017 TRD SPT
    Haha I had similar set up but 4 Orion xtr 8’s and 2125 Hcca red amp, and yeah they were tight and loud for sure. Just depends on how you like your sub set up honestly and preferences in music
  11. Feb 23, 2020 at 1:30 PM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    Anyone have any experience with the Memphis mojo 8s 2ohm? Thinking about doing 4 behind the back seats on a Skar rp4500. Would be cool to have them in a ported box where they can breathe and hit lows better, but I’ll probably be forced to do sealed because of the volume available behind the DC back seats.
  12. Feb 24, 2020 at 8:08 AM
    Rockoma5
    St Louis
    I am looking at the Mojo 8 but dual 4 ohm or Massive Audio's new Hippo XL84R. Both seam pretty comparable on basic specs.... I am doing ported as well. 4 would be awesome
    Corny Taco[QUOTED] likes this.
  13. Feb 27, 2020 at 6:06 AM
    shonuff
    shonuff Well-Known Member
    07 DCab 4x4
    It seems like every couple years (or if a good deal comes up) I swap out my sub/s. I hate mainstream brands also so all of them except for an old school JL8w3 v1 have been "outside the norm" brands. I built a center console ported enclosed with the sub firing at the rearview mirror. Off the top of my head I've had Soundqubed, American Bass VFL, DC M3, and JLW3 V1. All in 8 inch. At the moment I'm running their newest CT Sounds Meso. Its the hardest hitting one I've tried so far. it gets down but its power hungry and pretty expensive. Next one I really want to try is the F8L sub. Check out Sound Solutions Audio online. They have some fantastic sales right now for some amazing "off brand" company's you should def check out. I think I just may have to grab that F8L 8 since its a good price right now
  14. Feb 27, 2020 at 8:19 AM
    Rockoma5
    St Louis
    I looked at CT....the 6.6 inch on the meso 8 I am not positive will fit with a box behind my double cab seat.
  15. Feb 27, 2020 at 1:52 PM
    shonuff
    07 DCab 4x4
    I have no clue if it'll fit behind the seats with the Ct Meso. Its got a huge triple stacked motor and the surround sticks out pretty far as well. If it'll even fit there's a good chance it'll hit the back of the seat when it flexes
  16. Mar 14, 2022 at 11:01 AM
    taco caeden
    taco caeden Member
    15 year old with 2016 toyota tacoma bought byself
    has anyone done 4 8s behind seat yet?
  17. Mar 14, 2022 at 6:35 PM
    ZMan2k2
    ZMan2k2 “Hold my beer and watch this!”
    Richard
    Under a tinfoil hat
    ‘25 SS Red Sport Prem.
  18. Mar 14, 2022 at 6:42 PM
    soggyBottom
    soggyBottom Well-Known Member
    In the right box is key. Back around 2002 maybe 2003, I tried an Alpine type x 10" in a sealed box. The box was 1" thick MDF. I don't remember what amp it was but it was well over 1000w RMS. I don't remember it being anything special.
  19. Mar 15, 2022 at 7:03 AM
    ZMan2k2
    Richard
    Under a tinfoil hat
