One last issue: Brake "ping" noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nighthawk87, Jun 20, 2010.
  1. Jun 20, 2010 at 5:08 PM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    When I first hit the brakes after initially moving and the truck sat for a while, I hear a "clank" or "ping" noise from the front. It almost sounds like I drove over a sewer lid or something but didn't.
    Does anyone know what the problem could be?
    *I check the brakes and they "look" OK, pads are decent still. I did notice that there is a metal wire thing on side of the caliber.....but it looks like its supposed to be there cause its like that on both sides.
    Anyone have any ideas? It was like this prior to installing the lift and its still there...
  2. Jun 20, 2010 at 5:09 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    i have the same damn thing....
  3. Jun 20, 2010 at 5:11 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Happens to me to
  4. Jun 20, 2010 at 5:13 PM
    kinkrider101
    santa barbara
    wheels and tires
    i hear it on every tacoma aparently its the brake pad float, and it is harmless.
  5. Jun 20, 2010 at 5:20 PM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    yep....once the pads are half way down it happens.
  6. Jun 20, 2010 at 5:22 PM
    nighthawk87
    Damn, Maybe I'll just buy new pads...that sounds like it could be right. Is it easy to change pads on the taco?
  7. Jun 20, 2010 at 6:40 PM
    SManZ
    SManZ Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
  8. Jun 20, 2010 at 7:23 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    x2. Totally normal. It's the front brake design on our trucks. There's too much play in the pads where the pins slide through them, or you could say too much play in the pins themselves...depending on how you look at it. The pads will slide up or down and slam against the pins the first time you apply brakes after traveling in the opposite direction (going forward, stopping, putting it in reverse, then hitting the brakes for the first time in reverse will cause the clunk/ting/ding whatever you want to call it. Same then happens after going in reverse, then traveling forward and hitting the brakes the first time.).
