One map light working but not the other after changing to LED's
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wvdaveg, Jun 16, 2023.
  1. Jun 16, 2023 at 4:38 PM
    wvdaveg
    wvdaveg [OP] Member
    David
    Shepherdstown WV
    2021 Tacoma SR5 trail edition
    I changed the bulbs to LED in the map lights of my 2021 Tacoma SR5 Trail, and one bulb broke coming out and I had to fish it out and now that side doesn't work. Are there separate fuses for each side or is there something else wrong? The other side works fine.
  2. Jun 16, 2023 at 4:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^Did you try flipping the LED bulb around. Filament bulbs don't care about polarity. LEDs (light-emitting diodes) often work only in one direction.
  3. Jun 16, 2023 at 5:01 PM
    GeauxTacoma
    GeauxTacoma Well-Known Member
    Maryland
    2022 TRD Sport DCSB Lunar Rock
    Did you disconnect the negative battery terminal? Might have fried the board like many others here. Expensive mistake.
    Chew likes this.
  4. Jun 16, 2023 at 5:35 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    If you accidentally ground it out, fuse under the dash my have blown. For the map lights I found it a lot easier to just pull the whole thing down . It's 4 clips holding it in and you can get to the bulbs by twisting from the top of it.
    MannyS and wvdaveg[OP] like this.
  5. Jun 19, 2023 at 3:15 PM
    wvdaveg
    wvdaveg [OP] Member
    David
    Shepherdstown WV
    Thanks for the responses, it was just a fuse, didn't know there was a fuse box under the dash as well.
    3JOH22A likes this.
  6. Jun 19, 2023 at 3:22 PM
    DVR
    DVR Well-Known Member
    SC
    23 TRD Pro
    If you ever change them again...
    I grab them with a piece of duct tape. Make it into a "U" shape with sticky on inside. Grab the bulb so tape sticks to it and pull the tail of the tape to remove.
    3JOH22A likes this.
  7. Jun 19, 2023 at 3:32 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    This didn't work for me.
    It's MUCH easier to just grab the console and pull straight down and remove the bulbs from the back side.
    Stevie17 likes this.
  8. Jun 19, 2023 at 5:45 PM
    DVR
    SC
    23 TRD Pro
    It worked great for me... about 15x so far
  9. Jun 19, 2023 at 5:48 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    My local buddy said the same thing. But try my method, you wont go back to tape.
    Stevie17 and MannyS like this.
  10. Jun 19, 2023 at 5:56 PM
    DVR
    SC
    23 TRD Pro
    I'll try it next time.
    Should have a new 23 pro in mgm sooner or later.
