One more reverse cam anytime thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PyroTaco, Sep 3, 2016.
  1. Sep 3, 2016 at 6:41 AM
    PyroTaco
    PyroTaco [OP] Well-Known Member
    2013 Reg Cab Tacoma
    Fat Bob's lift kit, 30's on stock steelies, lunchbox locker in the rear, and a ton of other general mods and additions to help the utility of the truck for my particular uses.
    Searching through existing reverse camera anytime mod threads I wasn't really finding the answer I was seeking. I installed a rostra rev cam kit with the harness that redirects the signal to the touch screen in my '13 base Tacoma. Simple install except for the bloody pin/wire you have to put into the existing clip on the radio. After much fussing with it, got it installed. However, prior to final placement, I noticed that if the wire that goes into pin 2 isn't there, the camera wouldn't be detected. So here's my question. Is that pin the one that carries the reverse 12v signal? And if so, shouldn't I be able to apply a 12v source through a switch and allow it to turn on? Appreciate any thoughts and help. Hopefully, I didn't miss the info elsewhere.
    -Pyrotaco
    The link below is to the install instructions. I'm referencing page 6.
    http://www.rostra.com/manuals/250-8403_Form5447A.pdf
