One of my HID's isn't working
Discussion in 'Lighting' started by dysfunctnlretard, Aug 21, 2009.
  1. Aug 21, 2009 at 11:29 PM
    dysfunctnlretard
    dysfunctnlretard [OP] Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    My left HID headlight (h4) works part-time, that is sometimes it comes on and sometimes it doesnt. I'm gonna try and switch bulbs and see if thats it but was wondering if anybody else had this problem or had an idea of whats wrong? Theyve been working fine all along (for a week) untill now. Checked the wiring and nothings frayed, cut, caught, or loose, and all connections are tight. Fried bulb maybe?
  2. Aug 21, 2009 at 11:36 PM
    Viet2100
    Viet2100 Well-Known Member
    Viet
    South Florida
    2016 Prius 4T
    If your HID kit is aftermarket, this is bound to happen to at least 90% of them.
  3. Aug 21, 2009 at 11:58 PM
    johnecon2001
    johnecon2001 Well-Known Member
    Phoenix, AZ
    2005 TRD Sport 4x4 Access Cab
    Downey front skid, Trail Gear U-Bolt flip, Toytec AAL, Total Chaos UCA's, Bilstein 5100's x4 + Eibach adjustable coils, Doug Thorley Long Tube Headers, Custom Rear bumper, TRD OffRoad front tow hook, TRD Trail Team wheels, Federal Couragia M/T 265's, ARB rear locker + on board air (CKMA12), TRD shift knob, Alpine W205, TRD seat covers, Tom Woods 1 Piece drive shaft, Powermaster D2700, Stubbs HD-SKO Sliders.
    Any sort of intermittent problem is usually the fault of the lamp or the relay. Thankfully, the relay is cheaper.
  4. Aug 22, 2009 at 12:09 AM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    Aren't all HID kits aftermarket? And why does it happen to all of them?
  5. Aug 22, 2009 at 12:10 AM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    lamp meaning bulb right? and my relay is attached to the hi/low controller which means I would pretty much just have to get a whole new h4 kit (w/o bulbs)?
  6. Aug 22, 2009 at 12:11 AM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    Wen I berly installed mine it would do that allso... then I found out it wasn't getting ground good... so maybe that's ur problem as well
  7. Aug 22, 2009 at 12:13 AM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    will try that tomorrow. thanks. hopefully it is that. these lights kick ass...that is, when they work.
  8. Aug 22, 2009 at 12:25 AM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    If thats not the problem then jus take everything off and put it bak on again lol
  9. Aug 22, 2009 at 12:25 AM
    WhatThePho?
    WhatThePho? Greg Graffin 2016
    Andre
    HCMC, VN
    2006 STi
    The things required to pull bitches
    Probably blown ballast. Most likely the ballast is bad.
  10. Aug 22, 2009 at 12:31 AM
    Robtrd
    Robtrd Member
    Robert
    Riverside, CA
    08 TRD SPORT
    I dought it cuzz he says the light turns on and sometimes it dosent... so if it was the ballast the light wouldn't turn on at all... but I could be wrong
  11. Aug 22, 2009 at 12:55 AM
    P. Bauer
    P. Bauer Well-Known Member
    San Jose
    08 Tacoma 4x4 TRD Off-Road
    TRD S/C :: Intake Camburg SwayAway Magnaflow American Racing Donahoe Racing Wheelers OffRoad
    scrape the paint if you have to, make sure the contact is good, not having a good ground is a real issue with aftermarket HID kits.
  12. Aug 22, 2009 at 10:26 PM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    I havent been able to make sure ground connections are good as Ive been hella busy but I got around to wondering, if the ground connection was bad/poor wouldnt both lights have problems? Because Ground---> HI/LOW Controlle---> 2 Lights, so technically the ground would affect both lights, no?
    Am I missing something here?
    And how do I know if my ground connection is "good"?
  13. Aug 22, 2009 at 10:48 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    get some extra length of wire, some solder, heat shrink tube, and a connector end that will fit around the bolt for your ground cable on the battery, and ground DIRECT to the battrey ground. should solve most if not all of your hid issues.
  14. Aug 23, 2009 at 5:10 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    No, mine aren't. I have Philips OEM bulbs and Denso ballasts.
    Not likely, the bulb is still getting power.
    Your ground is OK if the HID kit works. You are right, if the ground was bad, both of them would be on/off together. Try switching the bulbs and see if the problem follows the bulb.
  15. Aug 23, 2009 at 5:37 PM
    johnecon2001
    Phoenix, AZ
    Take the lamp from the other side that you know works and plug it into the side you're having problems with. If it fires fine, its a bad lamp, if it flickers its a bad relay.
    Everyone is making this way harder then it should be.
  16. Aug 23, 2009 at 5:55 PM
    Viet2100
    Viet
    South Florida
    2016 Prius 4T
    If it flickers, it's the bulb. Relays either work or they don't. There's no in between where they would cause the bulb to flicker. Even if it would, it would cause both to flicker. But, as I stated, the relay would not cause it to flicker.
  17. Aug 23, 2009 at 9:14 PM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    I pulled up behind another truck the other day and was flipping my lights on/off to see when it would turn on and I noticed it would always flicker, but only actually turn on sometimes. However, I switched the bulbs today and the problem did not follow the bulb. Im guessing its a faulty balast. Not transfering all the power needed maybe?
    I doubt it could be the relay b/c, like I said b4, relay is connected to HI/LOW controller which affects both sides, but my left side isnt being affected, only the right.
    Im gonna call DDM tuning tomorrow. Hopefully they dont give me a hard time about getting them to ship me a new one.
  18. Aug 23, 2009 at 10:44 PM
    johnecon2001
    Phoenix, AZ
    If it didn't follow the lamp.. its the lamp.. not the ballast.
  19. Aug 23, 2009 at 11:18 PM
    dysfunctnlretard
    Manny
    CA
    2010 FJC
    huh? Why would it be the lamp if the lamp works with the other ballast. Both lamps work perfectly fine, given that theyre plugged into my left ballast.
  20. Aug 23, 2009 at 11:21 PM
    deadbolt
    deadbolt do w3rk!
    Socal
    08 Dbl Cab 6spd 4x4 TRD Off Road
    Black Headlights, HIDs, Tinted Fogs, Powdercoated Black Wheels, 5100s @ 2.5", Diff drop, AFE Exhaust, AFE Stage 2 Intake, Black Emblems/Grille, LED Tail lights, 265/75/16s Good Year Duratracs
    I have HIDs too. For a while my right headlight was flickering and shaking. Haven't really noticed it lately.
