one peice driveshaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rachelsdaddy, Jul 3, 2023.
  1. Jul 3, 2023 at 5:05 AM
    Rachelsdaddy
    Rachelsdaddy [OP] Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    has anyone attempted to eliminate the center support bearing and joint assembly on an ext cab with a simple single driveshaft? It couldnt be any longer than what was in my full size chevy, angle would be similar. I decided to hang on to this thing another few years....
  2. Jul 3, 2023 at 6:19 AM
    02hilux
    Planet: EARTH
    Depending on truck's configuration, it is not ideal to run a 1 piece shaft over 60 inches. And most shop will not built anything over that length due to vibration issue. A lot of people seemed to think the CSB is used to keep the shaft up at a higher angle based on designed and placement but the real function is to absorbed vibration.
    You can run a custom poly CSB to prolong the life. Met a dude on the trail that convert his and he's been running it for years with no issue.
    https://www.iedls.com/Our_Difference
    gearcruncher likes this.
  3. Jul 3, 2023 at 8:00 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    Call Tom Woods Drive Shaft- they used to sell a single piece shaft for these trucks.
    Rachelsdaddy[OP] likes this.
  4. Jul 3, 2023 at 8:10 AM
    02hilux
    Planet: EARTH
    Lol, not no more because it gave false hope so they discontinued it.
    maineah likes this.
  5. Jul 3, 2023 at 2:26 PM
    Rachelsdaddy
    Southern NH
    the driveshaft in an 85 chevy is longer than that....
  6. Jul 3, 2023 at 2:30 PM
    Rachelsdaddy
    Southern NH
    I didnt measure it but looked closely at it while dumping a case of fluid film under it, it appears the angle at the rear end will decrease, theres a reputable driveshaft shop in town, I will speak with them about it. Thanks
  7. Jul 3, 2023 at 2:41 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Years ago it was common for the lifts to to damage the long drive shafts with a frame lift so think off road over rocks.
  8. Jul 3, 2023 at 2:59 PM
    Rachelsdaddy
    Southern NH
    yeah, it never leaves the road and nobodys doing hole shots with it either
  9. Jul 4, 2023 at 9:18 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    What's the goal? Get a good OEM CSB and run that for another 50-100k miles. FWIW I run the 2 piece on my rock crawler that I drive to and from the trail with the pinion offset 3" to the pax side on my fj80 axle with no real issues with the factory type driveshaft provided I use an OEM CSB in it. If I put something cheap in there (timken, spicer, parts store) it eats the CSB in less than 5k miles.
    SH10151, Rachelsdaddy[OP] and 02hilux like this.
  10. Jul 4, 2023 at 9:43 AM
    02hilux
    Planet: EARTH
    Yep. I replaced mine like 6 years ago with a Toyota CSB and had no issue. I finally went to a 1 piece after extending the WB. I trail hard with 35s and crawlbox and see lots of mileage.
    slander[QUOTED] likes this.
  11. Jul 4, 2023 at 1:17 PM
    Rachelsdaddy
    Southern NH
    thats my problem, Im tired of changing the CSB, The Candone joint feels great, maybe its imbalanced but I cant be without it. No, you meatheads, I aint driving it in 4wd, dont go there. The parts companies are awfully proud of a new shaft... I was thinking outloud for a better alternative
  12. Jul 4, 2023 at 2:03 PM
    slander
    Hickory, NC
    Don't be a cheap ass and buy a Toyota CSB.
  13. Jul 7, 2023 at 12:00 AM
    Texasdynaryder
    Texasdynaryder Well-Known Member
    Chance
    Paris, Tx
    Kings Built Engine All the other small goodies
    I have went down this road before. Buy a used OEM drive shaft off of here and have it balance and rebuilt. It’s cheaper than a new OEM and you will be happy with your choice.
    The single piece drive shaft on our trucks is an absolute headache. I spent weeks trying to get the one I had built not to have vibrations at various speeds.
    I may even have a thread on it but I can’t remember.
    I searched, shimmed, tweaked, and finally went back to a two piece. I kept the driveshaft just as a reminder to leave well enough alone.
    That’s my $0.02
  14. Jul 7, 2023 at 6:53 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    Did that one piece use a double cardan?
  15. Jul 7, 2023 at 3:15 PM
    Texasdynaryder
    Chance
    Paris, Tx
    One in the front and then the slip yoke in the rear if I remember correctly.
