One piece drive shaft woes...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacowarrior69, May 31, 2018.
  1. May 31, 2018 at 6:44 PM
    Tacowarrior69
    Tacowarrior69 [OP] Member
    Kevin
    08' Tacoma Access TRD Off-road
    Hi everyone!
    I drive an 08' Toyota Tacoma 4.0 V6 4x4 Off road ACLB, been having the dreaded hummmmm since i've owned the truck. Since then, I've done the ECGS Needle bearing.. 5100's w/ Eibachs..Wheelers off road progressive 3 leaf...rebuilt my 2 piece drive shaft (new u joints, carrier bearing) and to no avail have not solved my vibes.
    I was getting the take off shudder, the rumble strip feeling when breaking and the 55-60 mph droning noise. So I decided to bite the bullet and have a one piece shaft made. I tossed the idea around going the TW route or go local, So i went local. I got the double cardon input joint (1310 series u joints) and slip joint @ the rear (1330 U joint). The shop used 3" tube to make it (not sure of wall thickness) and I called TW to get a 2nd opinion. They said 3" is too small and to go 3.5" or 4" which ive read other members have done here.
    The shop owner built it, said there was 0 run out and it balanced like a dream. Balanced to 3000 RPM. I got home, bolted it up to the truck and took it for a test drive and was EXTREMELY disappointed. Vibes from 25mph on up constantly. I couldn't go over 75mph. Got back home, pulled the shaft back out and double checked the Tcase & pinion flange angles and they were parallel as they should be. Since I pulled the shaft, I rotated it 180 degrees and mounted it back up and still the same results. Vibes everywhere.
    I would mount my 2 piece back up in the mean-time...but they stole the pinion flange off that to put on the 1 piece. Did i mention i paid $646 for the 1 piece? So I'm not gonna flip my S*** yet because I did talk to the shop owner and he said if I had problems to call him immediately so ill get on that tomorrow.
    So any input would be appreciated from the vibe/driveline gurus.......THANKS!
    scottalot likes this.
  2. May 31, 2018 at 6:52 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Have you tried angled shims under the rear leaf springs. General recommendation I was told is 1 degree per inch of rear lift. Has to do with the angle of the rear dif in relation to the rest of the drive train.
    DrFunker and outlawtacoma like this.
  3. Jun 1, 2018 at 3:31 AM
    Tacowarrior69
    Kevin
    I have not tried shims yet. I see no need to if the tcase & pinion flange are parallel to one another like I mentioned above
  4. Jun 1, 2018 at 3:47 AM
    AaronNY
    AaronNY Well-Known Member
    Syracuse NY
    2011 MGM 4x4
    Bilstien 5100s Hella 500s and 700s
    This post is discouraging. Hope ya get it figured out. I also have the front end vibration after lifting my truck.
  5. Jun 1, 2018 at 8:28 AM
    crolison
    crolison Well-Known Member
    Ar vah da, CO
    POS
    That’s your needle bearing
  6. Jun 1, 2018 at 8:33 AM
    crolison
    Ar vah da, CO
    POS
    I would go back to the shop who built It and complain, I’m betting it’s the wrong size tube. At 75mph and a stock size tire your nearly at 3k rpms driveshaft speed.
    To solve my problems I did a two piece driveshaft with a dc joint in it (like first gen Tacoma’s).
    DoulosXP, MTopp, EDDO and 2 others like this.
  7. Jun 1, 2018 at 8:39 AM
    09TRDSport4x4
    09TRDSport4x4 OCD Approved!
    Nick
    Southwest Ohio
    Wow man, I’m sorry to hear you’re having so much trouble with your one piece rear driveshaft. I just had one built locally for $450 and my truck has never been smoother. I had tried everything to get rid of my take off shudder and the vibrations upon slowing down but it wasn’t until my OEM CB crapped the bed that I decided to pull the trigger on the one piece. And I don’t know if it will help you but mine is a 3.5” tube with the OEM slip yoke and flanges.
  8. Jun 1, 2018 at 10:40 AM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Any reason you didn't try shimming the axle before having the 1 piece made? Seems to help a lot of people, I'll be shimming off the bat when I install my Dakars in a couple weeks.
  9. Jun 1, 2018 at 10:48 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I had a 1pc DS made for my conversion without the cardon joints and mine is smooth as can be. You think the cardon joint might be causing the problem?
  10. Jun 1, 2018 at 11:15 AM
    09TRDSport4x4
    Nick
    Southwest Ohio
    I tried everything, including shims and I could never get rid of the vibrations. I documented everything I went through after I installed my lift here.
  11. Jun 1, 2018 at 3:29 PM
    Tacowarrior69
    Kevin
    I did call them this morning and they did offer my $$ back. I do believe it's vibrating due to the 3" tube, I called Tom Woods and they said that was too small and to go 4".
    ? For those w/ a 4" diameter driveshaft---Have you had to chop that carrier bearing cross member? Will it clear?
    The local shop said for them to build the 4" shaft it would be $800+ "highly custom" they said and Tom Woods quoted me $579 + shipping.
  12. Jun 1, 2018 at 3:32 PM
    Tacowarrior69
    Kevin
    I had that thought....When reading the write up for the 1 piece conversion, they said the double-cardon joint was "essential" to eliminate vibrations. but if both flanges on the truck are parallel, then a conventional 2 joint shaft should work in theory.
  13. Jun 1, 2018 at 3:34 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
    Double cardan geometry wants to look like this:
    You might need to shim.
    Taco-Grinder and TireFire like this.
  14. Jun 1, 2018 at 3:36 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    How are they parallel? On my truck they sure ain't
  15. Jun 1, 2018 at 4:10 PM
    MA_TACO
    Wesley Chapel, FL
    My driveshaft is 3.6" in diameter and I have about 1/2" clearance on both sides of the carrier bearing bracket. 4" driveshaft is cutting it kinda close. You'll have to cut the bolt brackets off but not the whole thing.
  16. Jun 1, 2018 at 4:16 PM
    la0d0g
    running for the hills
    For crawling not hauling
    They shouldn't be. There is math that can figure out this dudes problem. Math camp! Let's all go!
    TireFire[QUOTED] likes this.
  17. Jun 1, 2018 at 5:23 PM
    PupuleUlua
    PupuleUlua Well-Known Member
    Rod
    Honolulu
    2011 MGM TRD Sport DCSB 4x4
    True but having a dcj eliminates possible vibs
    I chopped mines. I have a TW's 4" shaft that was shipped out the next day after ordering. Awesome customer service.
  18. Jun 1, 2018 at 6:15 PM
    Tacowarrior69
    Kevin
    Thank you! I was thinking of aligning a 2 joint shaft with parallel flanges. I will need to shim to get my angles correct...my bad everyone!! I guess I was in denial.... lol Ill get out in the garage and measure the DS working angle in relation to the pinion flange to see how much I need to shim.
    Thanks for showing me the light!!
    EDDO[QUOTED] likes this.
  19. Jun 2, 2018 at 6:15 AM
    Tacowarrior69
    Kevin
    so the DS is @ a downward slope of 9* and pinion is pointed up 6*....so looks like ill be looking into a 3* pinion shim to make the angle 0* between the the pinion/DS
    EDDO likes this.
  20. Jun 2, 2018 at 6:18 AM
    Tacowarrior69
    Kevin
