One Piece Driveshaft for 150$!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Cheeto6182, Jun 14, 2010.
  1. Jun 14, 2010 at 11:21 AM
    Cheeto6182
    Cheeto6182 [OP] Cheeto
    Sean G
    Denver, Colorado
    05 Tacoma TRD Offroad DoubleCab
    JBA Headers, Custom Snorkel/Ram-Air Intake, Spal Electric Fan Conversion, TBS lol, Borla Exhaust, ToyTec Coilovers, Old Man Emu Rear Leafs, Bilstein 5100's, Alpine system (type R's), 4.56 Gearing, 285/75/R16, Bead Lock Rims, Bed Carpeting, SoftTopper, Ram Air intake Mod, URD MAF, Dash Dyno, One Piece Drive-Shaft Conversion, Bed Cubby Led Lights, 12,500 Lbs winch, Expediation bed racking system, Hella Lights, Custom front winch bumper
    I bent my rear driveshaft wheelin in the mountains this weekend. Called Tom Woods and got a quote for a replacement driveshaft that ranged from 370-480 depending on whether or not I went with the double cardan joints or stock joints, and they didn't guarantee it would be free of vibrations (understandable since it's an out of stater and they don't know the condition of my vehicle). So instead I went down to Ron @ Drive Line Services of Boulder (colorado). He's going to build me a one piece that eliminates that carrier bearing using the hardware from my stock driveshaft for 140-150$ with a dyno balance and he'll stand behind his work! My question is: what are the possible downsides? Ive been looking at going one piece for awhile anyways because my carrier bearing was showing wear, and I don't lose a lot of clearance having it solid because im only lifted about 1.5 in the rear. The carrier bearing itself is 160 not including the required pressing. Also Will I gain more torque having a solid driveshaft as well? Lol sorry for the lengthy post, I tend to ramble
  2. Jun 14, 2010 at 12:22 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4R MGM TRDOR Premium Daddy Wagon
    I want one! How much for shipping to 38058?
  3. Jun 14, 2010 at 12:37 PM
    Cheeto6182
    Sean G
    Denver, Colorado
    try this man, go down to a small driveshaft joint that has some good ole boys working in it, ask them how much they would charge to make one using your existing joints and slip yoke. chances are they will be close to this price. I think Tom Woods cost more because he gives all new hardware. I'd be cautious about shipping, because if it wobbles you cant go right back down to the shop and have them tune it. i just like that this is a cheaper solution than replacing that carrier bearing! ... anybody know why they used a 2 piece? the clearance isn't that big a difference
  4. Jun 14, 2010 at 12:45 PM
    outlawtacoma
    W. TN
    Thanks dude! I will. I have no idea why they use a 2 piece
  5. Jun 14, 2010 at 1:03 PM
    Cheeto6182
    Sean G
    Denver, Colorado
    Yea I don't blame him for not guaranteeing it. His reputation is one of the best out there, especially with the rock crawlers.
  6. Jun 14, 2010 at 1:33 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Wouldn't the 2 piece design have been more for additional clearance? (and additional shit to replace and give toyota more $)
    Anyway I doubt you'll see more torque. About all you can hope for is less or eliminated vibration and possibly some rotational mass loss if it's lighter (which I guess could ever so slightly bump your wheel rated torque up a tad).
  7. Jun 14, 2010 at 6:46 PM
    Cheeto6182
    Sean G
    Denver, Colorado
    I was concerned about the clearance till I crawled under there, due to the shaft running along the gas tank I'll loose a fraction of an inch. If I was lifted higher it might be more exposed, but my XJ rock crawler has a solid driveshaft and its never been an issue.
  8. Jun 14, 2010 at 7:38 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Debadged, GC Mesh Grill, Yellow Fogs, Color Matched Headlights w/ Retros, Diff Breather Mod; mickey thompson classic IIs, 5100s, toytec springs, Dakar Leaf pack, ss brake lines, Lots more...just check the build page.
    Just make sure they check the shaft angle. One-piece can be a nice way to lose weight from the driveline, shifting the hp/tq curve to the left and eliminating issues w/ the center support bearing. Downsides of one improperly installed would probably be some vibrations and potential early driveline wear.
  9. Jun 14, 2010 at 10:21 PM
    Manwithoutaplan
    ID
    Where would you go to get this done???
  10. Jun 14, 2010 at 10:28 PM
    Manwithoutaplan
    ID
    ok cool. thanks man
  11. Jun 15, 2010 at 4:07 AM
    Kelson
    Kelson My Truck is Cuter than Yours
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    i have a one piece! stock! bwahahaha
  12. Jun 15, 2010 at 3:53 PM
    DrRabbitFurHead
    DrRabbitFurHead Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Where do the shims go and what type of shims are you referring to? Axel shims? diffy shims? other?
  13. Jun 15, 2010 at 3:58 PM
    BigRedToy
    BigRedToy ¯\_(ツ)_/¯
    Colorado
    07 Regular Cab SR5 4x4
    I wonder what he would charge to lengthen and balance my stock shaft. There are a few post out there about the Regular cab trucks having vibes once lifted due to the drive shaft length.
  14. Jun 16, 2010 at 9:44 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    I put my one piece driveshaft on last night and I am very impressed. My carrier bearing was starting to wear and get slack in it. When I'd floor it I used to feel the two piece pop up a little bit (due to the bearing movement in its casing), with this one piece it feels more responsive and all my vibrations are gone.
  15. Jun 16, 2010 at 9:45 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    Not sure, I highly recommend his though (drive line services of boulder). I dropped the shaft off at 9 am, he had it ready for me at 2. He also repainted the whole thing, looks brand new lol
  16. Jun 16, 2010 at 10:59 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    thats what I told her
    :D
  17. Jun 16, 2010 at 11:09 AM
    cotruckin
    cotruckin Well-Known Member
    Westminster, CO.
    Lifted 06 TRD Sport
    Bilstein 5100 Lift with rear 1" blocks, ARE Z series topper with Yakima rack and Rola basket, some audio equipment, some more goodies
    Man, that sounds like a pretty good deal. What did the total cost end up being? Where exactly are they located? I may need to have him make me one.
  18. Jun 16, 2010 at 11:56 AM
    Cheeto6182
    Sean G
    Denver, Colorado
    Total cost was 149. He dyno tuned it and gave it a new paint job. Just came off the freeway and absolutely no vibrations! His location is in Boulder (2738 47th Street, Boulder, CO 80301-2317 (303) 447-1641).
  19. Feb 1, 2013 at 8:02 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    sub'd in market for shaft
