One Piece Driveshaft
Discussion in '2nd Gen. Tacomas (2005-2015)' started by KColoTaco, Mar 28, 2011.
  1. Mar 28, 2011 at 12:40 PM
    KColoTaco
    KColoTaco [OP] Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    Hey all I am having problems with driveline vibration. I only have a 2.5" lift but can't seem to remedy it. I have a lot of play in my center support bearing and was going to replace it. But found out they are $200.... Now I am questioning if it will really cure my vibration problem.
    I would like to hear from the people running a one piece and if they like them. How many miles do you have on them? Would you recomend it?
    Thanks!
  2. Mar 29, 2011 at 9:44 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    day two bump, just seeing if there is any response out there....
  3. Mar 29, 2011 at 10:15 AM
    Deathbeard
    Deathbeard Well-Known Member
    Yorba Linda, CA
    Prerunner Regular cab
    Camburg Spindles, Camburg 1.25" UCA, All pro expedition rear 3" leaf, 5100 all around, 17x9 raceleline renegade 6, 33's
    After I lifted my truck I noticed the vibes were getting worse and worse..felt like the truck was going to split apart..Turned out the driveshaft was coming out of the tranny housing..ultimately I had to extend my drive shaft 2.5 inches to keep it fully housed in the tranny, now she rides smooth..My rear lift is comprised of allpro expedition leafs and 1" block thinking the pinion angle was too extreme
  4. Mar 29, 2011 at 10:18 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    I am unfamilur with the prerunner, does the splined slip joint slide into the transmission on those? The slip joint on mine is behind the carrier bearing.
  5. Mar 30, 2011 at 8:02 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    I do realize that the purpose of the rubber mount is flex but controlled flex. Mine moves with little to force applied...
  6. Mar 30, 2011 at 8:15 AM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    1 piece driveshaft will help but doesnt completely eliminate the vibes. My truck (as with all reg cabs) come standard with a 1 piece drive shaft and we still experience vibes. For a 2 piece, a carrier bearing drop will help and axle shims will help too.
  7. Mar 30, 2011 at 8:20 AM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    I replaced my with a Tom Wood's one piece double cardan driveshaft. I would never go back to a split driveshaft and a carrier bearing.
  8. Mar 30, 2011 at 8:22 AM
    Slapps74
    Slapps74 Well-Known Member
    Thornton
    2014 FJC
    Bone stock for now!
    I have a custom 1 piece and a 6 inch lift and my truck is a DC. It took some doing and was hard to find someone to build it. I had one guy build it and another had to rebalance and fix it, but 75-80 mph its as smooth as it ever was. If the problem wasent there before the carrier bearing started to wear I would just replace the carrier bearing and call it good. Your looking at about $450 or more for a one piece.
  9. Mar 30, 2011 at 8:32 AM
    beans20
    beans20 Well-Known Member
    Will
    Pontotoc, MS
    A Bad MotherF***er!!!
    Soon to come 6" procomp lift Stage I 18x9.5 Black Rhino Sidewinders Kenwood DNX6960 Head Unit and 35x12.50 Toyo Open Country MT's JDM black head and tail lights and more!!!!
    Sorry OP not tryin to take your thread over but have a question is yours a DBLCB or Reg or other cause i want a tom woods but what are the specs to get it done and how much was the cost!!
    Thanks,
    Will
  10. Apr 4, 2011 at 10:41 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    My truck is a DC short bed.
    Looks like the beaing from toyota is $200+ from the dealer, and a one piece is about $300 from the local driveline guys. So I'm gonna give it a go on the on piece sriveshaft, I really hope it fixes my problem.
  11. Apr 4, 2011 at 11:09 AM
    kd8awe
    Rocky
    Ohio
    4x4 TRD Off Road
    I have a 2007 TRD Access Cab
  12. Apr 4, 2011 at 12:21 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    i have a 07 access cab with a Tom Woods Drive Shaft too and i pull 18" of travel in the rear with no problem, no vibes or anything, great investment
  13. Apr 5, 2011 at 4:41 PM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    So I heard some stuff about a one piece driveshaft increasing stress loads on the yokes and t-case (or transmission in your case). I take it since your long travel you would have to say that it's not been a problem. Correct?
    Nice truck!
  14. Apr 5, 2011 at 4:43 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    my tranny has a flange for some reason
  15. Apr 5, 2011 at 4:46 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    i have mine for sale
  16. Nov 5, 2017 at 5:45 AM
    ShuggieTaco
    ShuggieTaco Well-Known Member
    2011 Tacoma
    1.5" level front
    Did you have a one piece on a double cab?
  17. Nov 5, 2017 at 6:03 AM
    Drtnap19
    Drtnap19 Active Member
    Bluegrass
    2011 DC Tacoma 4x4
    I did it on a double cab. Very smooth
  18. Nov 5, 2017 at 8:01 AM
    ShuggieTaco
    2011 Tacoma
    1.5" level front
    Did you have he bump after stop issue or just vibes?
  19. Nov 5, 2017 at 1:09 PM
    Drtnap19
    Bluegrass
    2011 DC Tacoma 4x4
    Just vibes at every speed. Dana shaft and Spicer double cardan flanges completely eliminated the vibe. My driveline shop stressed the double cardan joint was key to it working like it should. I never had the bump after stopping.
  20. Nov 5, 2017 at 1:23 PM
    ovrlndkull
    ovrlndkull Well-Known Member
    Skip
    Burlington, NC
    2005 DCLB Silver
    Bilstein 6112, Deavers, Method Standards, GDYR DuraTracs
    I haven't noticed any vibes after my lift. I did the carrier bearing drop with the lift. I am going to measure to make sure that all the angles are good and get a shim if needed. Excess or mismatched angles in the driveline can cause vibrations and/or premature u-joint wear. I will be replacing all the U-joints F & R and the carrier bearing soon just for maint. They are wear items and need replaced from time to time. I haven't even had vibes from front diff needle bearing.
