One Piece Driveshaft
Discussion in '1st Gen. Tacomas (1995-2004)' started by xcmtb83, May 12, 2016.
  1. May 12, 2016 at 8:40 PM
    xcmtb83
    xcmtb83 [OP] Well-Known Member
    Iowa
    I am wondering if any 1st gen extended cab or double cab guys have converted to a one piece driveshaft. If so are there any clearance issues? e.g. gas tank, etc.
    It seems a few 2nd gen guys have converted to a one piece in an effort to combat vibrations post suspension lift kit install. I don't have vibration issues but rather a lot of backlash in the drivetrain, a problem that is exasperated by a manual transmission. My carrier bearing may have seen better days and puts a lot of slop into the drivetrain that I dislike. I have already threw in a "newused" third member because the original one howled pretty bad after 195,000 miles. I suspect the extended cabs with manual trans are harder on third members, especially if there is vertical play/slop in the carrier bearing which contributes to a lot dynamic loading on the pinion bearing and ring and pinion.
    I also own a V6 manual trans regular cab 1st gen Tacoma. The regular cab has a factory one piece driveshaft and it doesn't have the annoying backlash like my extended cab does. I realize I could "probably" replace the carrier bearing to improve things OR put that money towards a naturally lighter weight one piece driveshaft and be done with it. I don't wheel this vehicle so I don't need the maximum ground clearance that a two piece driveshaft affords.
    Thoughts?
  2. May 13, 2016 at 3:05 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Cant remember the manufacturer but there are a few fellas on here that run those nice aluminum one piecers. Someone outta pop in soon and throw out the maker of those things..
  3. May 13, 2016 at 9:08 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Tom Woods does the driveshafts that everyone is dropping in. They are very nice, I had one for a bit, but the d-shaft wasn't the source of my vibes. I would say fix the center support bearing. Is the truck lifted?
  4. May 13, 2016 at 11:30 AM
    bry838
    oregon
    Yip^^^thats the maker i was thinking of!!
  5. May 13, 2016 at 1:16 PM
    xcmtb83
    Iowa
    Mild...1.25" in front, 2" in the rear.
    Those are spendy driveshafts. I would go to a self serve yard for a two piece donor out of a 3rd gen 4Runner or a Tacoma and then take it to an automotive machine shop and pay them to weld on ends to a shaft and balance it.
  6. May 13, 2016 at 7:59 PM
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    It would definitely be nice to run a one piece. I hate the factory shafts with the yokes that fling grease all over the underside of my truck! Get them for both if it's possible to eliminate this annoyance. Also, sealed u-joints as well so there's no more greasing to worry about. It's the 21st century, Toyota and GM are the only 2 trucks left that still use grease zerks on their drivetrain components that I'm aware of, time to catch up with the times there guys!
  7. May 14, 2016 at 12:41 AM
    bry838
    oregon
    Man id much rather run a greaseable joint over those non serviceable ones.
    40950, COMAtized99 and TrdSurgie like this.
  8. May 14, 2016 at 9:11 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    Very true bry.
    Yah,,sooo much fun pressing those cups out, just to put a blob of grease in there and reassemble, and take the chance of damaging driveshaft ends. Repeat after about 10000 miles or sooner if severe duty/dusty/bigger HP. I run non-greasable 1350's on my 56 chev,,but I slap it with 650 hp and good track bite on occasion,,so I don't want that grease zerk there, because it makes a weak spot. Rack style Arbor press gets the job done on servicing this custom gig.
    Yes, yes, yes,,the non-greasables last a lifetime and umpteen gazzillion miles,,but once they do dry out of grease on a low power daily driver,,shit happens fast, furious and inconveniently. I think Ford started pouring liquid plastic waay back in the day in around the bearing cups,,to hold them to the shaft. What a nightmare on some. Cutting torch to change out non greasable u-joints if you didn't have a 30 ton step down press.
  9. May 17, 2016 at 7:04 AM
    2scars
    Brandon
    RVA
    I was going to do the same, but by the time I had done all that, it wasn't going to save me much, especially not time. If you aren't running some weird lift that would benefit from the one-piece, or chasing some vibration, I would just knock out the the center bearing. My automatic gives me a weird unloading of the d-shaft when I stop and start, apparently due to the trans still giving some rotational force when coming to a stop and binding up the shaft. Never got that with my '04 5-speed.
  10. May 20, 2016 at 6:50 PM
    xcmtb83
    Iowa
    No need anymore. I disassembled my carrier bearing assembly today and put a PVC shim around the rubber. It is working great so far.
