one time issue with not starting
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nomad, Nov 8, 2010.
  1. Nov 8, 2010 at 7:15 AM
    nomad
    nomad [OP] Well-Known Member
    I stopped for gas the other day... turned the truck off, filled up and turned the key to start it. The starter turned (strong) for a good 5 to 10 seconds and nothing happened. I took the key out, put it back in, turned it and it fired right up (like it normally does).
    I've owned the truck for 5 years now and that was the first and only time it's ever happened. I have a fairly new battery (Odyssey), new plugs (less than 5,00 miles on them). I'm wondering if the fuel pump might have had an issue. Any ideas on this one time hiccup?
  2. Nov 8, 2010 at 7:49 AM
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    Mine has been doing this since it was new, maybe once or twice a year.
  3. Nov 8, 2010 at 7:55 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    Extang Trifecta, LED Console lighting, VentShades
    My 2010 (2000 miles) has done it twice, randomly, not after filling up. It did it just yesterday. Funny thing is, I tried to do a search on this issue last nite and nothing came up.
    It acts as if its not getting fuel (or spark) on the first crank.
  4. Nov 8, 2010 at 8:00 AM
    OffroadToy
    OffroadToy This ain't Dodge City, and you ain't Bill Hickok
    4X4 Offroad
    snugtop, piaa, weathertech, westin, oem bed mat, trd seat covers, avs inchannel vent visors, 2" suspension lift, front diff drop, rear differential breather extension, oil filter drain hose, a/c drain hose extention & reroute, front window tint, cat theft protection plate, tailgate clamp mod, xpel headlight/foglight protecters, oem block heater, bfg 265/75R/16 a/t k/o's, cabin air rodent protection screen, rcbs illuminated 4X4 switch mod
    I know for a fact there's a tsb for this problem on the 07's. It's called the intermittant no start tsb. I had the issue a week after purchasing my truck and took it in for the fix...hasn't happened since.
  5. Nov 8, 2010 at 8:02 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
  6. Nov 8, 2010 at 8:07 AM
    OffroadToy
    4X4 Offroad
    Yep...that's the one I had done. They recalibrate the ecm.
  7. Nov 8, 2010 at 8:13 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    Does this TSB fix other TSB's that involve the ECM? I need to get the 1-2 shifting TSB done as well.
  8. Nov 8, 2010 at 8:26 AM
    OffroadToy
    4X4 Offroad
    I'm not sure if that tsb# applies to the 2010's...
  9. Nov 8, 2010 at 8:35 AM
    nomad
    EG011-07
    Anybody got a copy of this? I couldn't get the link under the TSB sticky to work for me.
  10. Nov 8, 2010 at 8:38 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    I'm not sure either. I'm having a hard time viewing/downloading the TSB to read it.
    I'll have to look into it further.
  11. Nov 10, 2010 at 6:46 AM
    nomad
    UPDATE:
    The local Toyota service department called and said they pulled some error code that shows what might be the cause of the "no start" problem I had. He said it had nothing to do with the ECU (or the TSB), but rather the sensor in the steering column that senses the key.
    He said that if you quickly stick the key in and turn it, it may not have time to disable the engine immobilizer (remember we have a chipped key). He said that by me taking the key out, then putting it back in and turning it again, it "reset" and accepted the key. He suggested to just keep an eye on it. He said that by giving the key a second to "sync" after inserting it, but before turning it should correct the problem (I like a cheap fix). :D
    He said that if it kept doing it, that the sensor (or a couple of other components) could be going bad and might need to be replaced, but he doubted that's the case.
  12. Nov 10, 2010 at 6:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    That would make sense since the immobilizer cuts the fuel
  13. Nov 10, 2010 at 7:17 AM
    Fagro
    Fagro Active Member
    RI
    10 DC LB SR5
    It does make sense.
    I will have to be more mindful when I get in the truck. Slowing down a bit could help in all sorts of ways.
  14. Nov 10, 2010 at 10:24 AM
    DriverSound
    DriverSound Señor Member
    SoCaca
    15 DCSB OR 4x4 & 17 AC SR 4x4
    Too few to list.
    It did this on my '09. Give it a two count before starting up.
  15. Nov 10, 2010 at 12:45 PM
    Gusaroo
    Gusaroo Member
    Joe
    Connecticut
    Mine 07 does it whenever Im parked on an incline. I assumed it was fuel draining out of the injection system.
  16. Nov 10, 2010 at 5:32 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, Sickspeed shift knob, mud flap delete, white lithium grease mod for creaky clutch pedal
    Interesting. Thanks for the info. My 2010 has done this a few times in the past year.
