One time long tow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cantwells, May 22, 2024.
  1. May 22, 2024 at 10:41 AM
    cantwells
    cantwells [OP] Member
    2009 Tacoma TRD Sport 4 Door Long Bed
    None...yet
    Hello everyone,
    I have a 2009 Dbl cab, 2wd, V6, AT, with towing package, 40k on odometer.
    Next month I plan to tow a 6x12 single axle trailer from Sacramento CA to Lincoln NE. The trailer, when loaded will weigh +/- 3000 lbs. The trailer does NOT have brakes. Opinions regarding whether or not I should install electric brakes on the trailer. All use of this trailer after this trip will involve substantially less weight.
    this link is to the brake kit I would be considering...
    https://thetrailerpartsoutlet.com/p...J_-uEXTyP1-CZU__KfxXEg5Qn4j6YgghoCEsoQAvD_BwE
    knottyrope likes this.
  2. May 22, 2024 at 10:56 AM
    pdenajim
    pdenajim Well-Known Member
    Jim
    Pasadena, MD
    2017 Inferno Tacoma TRD OR DCSB
    Black MBRP dual exhaust, aftermarket TRD Pro grille, AVS dark smoke hood deflector & dark smoke vent visors, BedRug, BAK Industries Revolver X2 bed cover, aftermarket TRD Pro Tail light assemblies (DEPO), orange vinyl decals on engine cover, door sills, and glove box, LED headlights & fog lights, KICKER speakers, piano black tailgate TACOMA inserts, center console organizer tray, black stainless steel licence plate frames, smoked license plate "protectors", ME-SO Customs Ultimate LED mirror turn signals, Ultimate Dome Light, V2 Map Lights & coin holder, Toyota bed extender, Pop & Lock Power Tailgate Lock, Fortin EVO ALL Plug & Play Remote Start, TRD PRO headlights, Redline Hood Struts, FJ Cruiser 2007-2014 TRD Pro SEMA 17" MATTE GRAY Alloy Rims, COOPER DISCOVERER S/T MAXX 255/80-17 Tires LR E, Gen 2 TRD Pro Suspension, 2" AAL, TRD Pro CAI, Mobtown sliders and full aluminum skids, ARB Safari snorkel. On deck waiting installation: under hood LED lights, bed, U-Bolt flip, Sport Hood, passenger door touch sensitive door handle. Future Mods: "Always On" console USB power mod, "Default On" ECT Power mod, LED lights strips inside the bed, diff vent extension
    You may need these as well [​IMG] [​IMG]
  3. May 22, 2024 at 11:01 AM
    ucdbiendog
    ucdbiendog Well-Known Member
    Reno, NV
    2014 DCSB TRD OR
    Bilstein 6112 + 5160 + Dakar MD, Stubbs HD-SKO sliders, BAMF skids, BAMF front bumper, Relentless Rear
    correct, you'll need the brake controller kit for the truck as well. it's pre-wired behind the dash so install should be straight forward. i would highly recommend brakes - my travel trailer is around the same weight (litttttttle bit more), and there have been times that ive noticed brake fade on long downhills even with electric brakes on the trailer. and you'll have to go over two major mountain ranges so i wouldn't risk it. good luck!
  4. May 22, 2024 at 11:13 AM
    risethewake
    risethewake Well-Known Member
    Will
    '15 MGM Sport AC
    Basics. Tires, painted headlighes, UHLM, baby winch in the bed, and heated mirrors :)
    It's really never NOT a good idea to add brakes to a trailer you own and plan on using. Especially considering you'll be going up and down mountains on your trip, waay better to have every bit of braking authority available to you. Though the taco tow package is rated for 6500lb, dragging 1.5 tons downhill behind your presumably fully loaded midsize pickup is nothing to sneeze at.
    And even if you don't plan on towing heavy after your "big haul", it's still objectively better to have trailer brakes than not. Really takes a lot of burden off your tow vehicle's braking system
    I unfortunately don't have any valuable input regarding which specific brake kits to install. But as others said you'll need a controller and Tekonshas are popular, and plug and play IIRC, truck is re-wired under the left kick panel
  5. May 22, 2024 at 12:22 PM
    545 Well-Known Member
    2015 Access Cab
    You’ll be fine without brakes. It will take longer to stop.
    Thechief86 likes this.
  6. May 22, 2024 at 3:28 PM
    Thechief86
    Thechief86 Well-Known Member
    Eric
    Middle TN
    Stock 2006 TRD OR, as well as some other junk...
    Sparkly blue shift knob
    If you can afford to do it, and feel like it, go for it. With or without extra brakes, be aware of how much stopping distance you need, and plan for that. Stop early, and give yourself plenty of room behind the next car. It'll be fine either way. I've towed a 3k lb car over the mountains behind a Subaru with 300k miles, and although not ideal, neither me nor the car died.
  7. May 23, 2024 at 6:19 AM
    GorgeRunner
    GorgeRunner Out There
    2005 PreRunner
    And hope you have enough time to stop before you slam into the vehicle in front of you.
  8. May 23, 2024 at 10:53 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    There may be 2-3 states that require trailer brakes on sub-3000 lb GVW trailers. The rest of the country pulls them every day and never has a problem. Above 3000 lbs and brakes are required virtually everywhere.
    I've literally pulled my utility trailer from North GA as far south as Miami and as far north as Kokomo Indiana with about 3000 lbs and no brakes. Never knew it was back there. You'll be fine
    0xDEADBEEF and Thechief86 like this.
  9. May 23, 2024 at 11:02 AM
    TacoTuesday1
    SD CA
    up to you
    probably just pulled more than that without trailer brakes which wasn't even an option
    not uncommon
    left more stopping distance in front of me etc.
  10. May 23, 2024 at 11:22 AM
    skee
    skee Well-Known Member
    North Coast, CA
    2006 Tacoma TRD 4x4 Access Cab
    I would definitely recommend the brakes. I rebuilt an old 80’s utility trailer (with brakes) with a bunch of parts I ordered from etrailer and have had no issues for the last 4 years hauling gravel, firewood, soil, etc. I’ve always been happy to have the brakes as a little extra help. Yes, while you’re on the flatlands you won’t even know it’s there, but as soon as you need to slow down on a steep residential road, curvy mountain road, or long highway downgrade you will be glad to have trailer brakes helping you. I’ve never been too impressed with the stock Tacoma brakes.
  11. May 23, 2024 at 2:48 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    In California any trailer exceeding 1500 lbs requires brakes. Same for Nevada and Idaho. Other states are more, it varies by state. The problem is if you have an (injury) accident in one of those states while towing heavy without brakes you may be in deep shit. In addition that is a long trip, it would just be safer for you and your fellow drivers to have brakes. I have towed 3000+ loads w/o trailer brakes and you need much longer distances to stop, especially at highway speeds. Without brakes it may take a couple hundred extra feet to stop at highway speed. And going down a grade or hill , big problem. So yes get brakes.
    skee likes this.
  12. Jun 5, 2024 at 8:55 AM
    cantwells
    None...yet
    Thanks for all the input! I've gone ahead and installed brakes and a sway control bar.
    skee and Sprig like this.
  13. Jun 12, 2024 at 4:36 PM
    cantwells
    None...yet
    Hey everyone. once again, thanks for all the input. As I stated in my last post, I went ahead and added the swaybar control and trailer brakes. Just completed the 1500 mile Trek from the West Coast to the Midwest. I could not be happier with the decision to add those modifications. Coming down some of those grades may have gotten pretty squirrelly without the extra control.
    skee, risethewake and Sidney Vicious like this.
  14. Jun 13, 2024 at 5:08 AM
    risethewake
    Will
    '15 MGM Sport AC
    Glad it all worked out for ya. Again, extra stopping power (read: energy dissipation) is never a bad investment, especially over the mountains. Even with a lighter load in tow, it could very well mean the difference between brake fade and not. Aside from the controllability/handling aspect, once the brakes get hot enough to fade on a downhill, they’ll only get (much) worse until they cool off. Leaving you pretty much boned and out of options in the moments when you really need them.
  15. Jun 13, 2024 at 5:28 AM
    Squirt
    Squirt Samsung Aficionado!
    Ben
    Cornfields of Illinois
    2016 F150 Lariat with 3.5L of fury!!
    Rexing front and rear dash camera, some LEDs, Weathertech HP floor liners/vent shades/bug deflector/underseat storage bin, OEM Ford bed mat, Diode Dynamics SS3 Pros in selective yellow, Diode Dynamics 18" light bar in amber and universal Carhartt seat covers. Bak Revolver X4S tonneau cover. Android Auto USB plug upgrade! H11 to H9. Sound deadened/insulated floors and rear wall. VLED license plate reverse light. Yokohama GO15s. Rokblokz mud flaps. "Custom" 3in Flowmaster Super 50 Series cat back with a 3in Speedys Snap resonator. J&L catch can. AMP Powersteps
    It'll pull it with no issues but yes trailer brakes would be good! I pulled a 6x12 single axle with my 09 and it did great
