One Ton Master Cylinder Adapter Kit
Discussion in 'Solid Axle Suspension' started by SMKYTXN, Jun 12, 2018.
  1. Jan 10, 2019 at 10:00 AM
    SMKYTXN
    SMKYTXN [OP] If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    :woot: It's great to see more 2nd gens going the way of the wonton. :D
  2. Jan 10, 2019 at 10:01 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Around June or July I’ll be pulling my tacoma off the road and doing the swap.
    SMKYTXN[OP] likes this.
  3. May 4, 2019 at 4:09 PM
    Pinocho_76
    Pinocho_76 New Member
    Joaquin Saldaña Villa
    2009 tacoma pre runner
    Headers, catback, volant Air filter, sprint booster, High amp Alternator, High Performance maf,
    i just got the booster, master cylinder and the swap kit, i have on ly one question how did you conect the lines, are the front and rear lines in the tacoma the same as the new master cylinder, the first line near to the booster in the gm its for the front wheel and the other one fpr the rear line, and i have some daughts about if the tacoma distribution its the same, i read they work in the opositive near the booster for the rear line and the other one for the front line.
  4. May 6, 2019 at 7:53 PM
    canadian bum
    canadian bum Well-Known Member
    Alberta, Canada
    2005 SAC DCLB
    Spacer lift with 42s
    I just placed an order on this kit. Any approximation on when the machining will be completed?
    Thanks
  5. May 6, 2019 at 10:45 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    The rear connection on the master cylinder, closest to the firewall, is for the front brakes. That should be the same for the stock master as well.
    If you hook everything up and get really strong rear brakes that lock up before the fronts you'll know you have the lines swapped.
    The kits are in stock and will ship Saturday morning. Thank you for the order.
  6. May 6, 2019 at 10:58 PM
    canadian bum
    Alberta, Canada
    2005 SAC DCLB
    Awesome, thank you.
  7. May 7, 2019 at 6:59 AM
    Tacodriver08
    Tacodriver08 To have faith, is to trust yourself to the water
    Texas
    05 X-Cab 4x4
    Too many to list
    Picked mine up at Jambo last weekend, excited to make some more progress on the SAS! Thanks again @SMKYTXN
  8. Jun 27, 2019 at 3:38 PM
    Tacodriver08
    Texas
    05 X-Cab 4x4
    Too many to list
    @SMKYTXN on the fitting for the brake lines going into the MC, should the line be inverted flare or bubble flared?
  9. Jun 27, 2019 at 8:57 PM
    SMKYTXN
    Nathan
    Houston
    DCFB
    They're a standard inverted flare.
    05Taco4x4 likes this.
  10. May 3, 2020 at 10:25 AM
    sharky9
    sharky9 Active Member
    Larry
    2009 Tacoma TRD Sport
    Pro Comp 6" lift, ProRunner shocks front/back, 35x12.5R18 Pro Comp AT, Method NV 18x9 -12mm wheels, Raptor mesh LED grille, Bushwacker flares
    What is the purpose of the 'Plunger Adapter' in this kit? I am halfway done with putting this on my truck (booster mounted and connected to clevis and pedal) but I am having difficulty figuring out step 6B in the instructions. It says to make sure the aluminum adapter touches the Tundra plunger and the 'seat' of the MC. The adapter doesn't fit by any means, there is a small indention hole where it can touch the tip of the booster rod/plunger, but it certainly doesn't fit that well, and the moment I let go of it with my hand to focus on mounting the MC, it will most likely try to fall out and drop to the ground.....would have love to see this indention cutout of the adapter for the plunger tip to be about an inch deeper so the adapter could rest on it much easier. Is the 'seat' of the master cylinder just a fancy name for the opening of the MC?
    Also, I thought this kit was complete, but I don't see my brake lines connecting to this kit without buying some additional items from my local auto parts store. My brake lines connect on the OTHER side of the MC, not on the side pictured, so I'm sure I will have to come up with some extension lines to run underneath it like the picture in the beginning of this thread - hopefully the auto parts store has all of that. The tube nuts I haven't figured out yet either, no way my lines are connecting to them as they are in my engine bay right now......and the nuts are different sizes too where as my lines that I disconnected off of my MC appear to be the same size.
    Wish me luck, hope my auto parts store guys can help me out if I take them phone pictures of what I have got left to do......
    Hayrider likes this.
  11. May 3, 2020 at 5:58 PM
    sharky9
    Larry
    Never mind, this kit will not work with my Tacoma, completely anyway. The GM master cylinder is not going to fit unless I do something with my fuse box (not shown in the thread pic installed in the engine bay on page 1 of this thread - did he remove his?). This kit has 3/16 inch tube nuts which won't work with my stock 1/4 inch brake lines. It's just been one mess after another trying to get this to work, 5 different trips to different auto parts stores today. The booster kit parts definitely fit.....I will see about getting a Sequoia or Tundra MC tomorrow and finally getting everything done as planned, just will not use the plunger adapter since the original Tundra Booster I bought should mate up find with a Tundra MC. But warning, if you have a 2009 Tacoma TRD Sport like me, with 1/4-inch hard brake lines, and a fuse box on the drivers side of your engine bay, the GM master cylinder will NOT fit, it is just about about 2 inches too long!
    Hayrider and Redsyota like this.
  12. Feb 20, 2024 at 2:09 PM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    I need this for my 07 Taco. Does anybody how long the whole assembly is off the firewall? I have shock hoops for my coil overs. Not much room left...
  13. Apr 15, 2024 at 10:56 AM
    eWood97
    eWood97 New Member
    2007 Tacoma TRD sport
    Custom paint lower
    What are the two plug ins on the tundra booster for and the extension rod is to long for the set up. We left it out and the rod is 1/4in short but touches once pushed. Confused to that. Advice
  14. Apr 15, 2024 at 11:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
  15. Apr 17, 2024 at 5:31 PM
    #35
    allenfab
    allenfab I hate everything
    Todd
    Lakeland, FL
    08 5-lug on one tons
    There are variations in pushrod length throughout the years, some modification is assumed.
    1/4" of play? That pedal is going to feel like shit
  16. Apr 24, 2024 at 6:50 AM
    #36
    eWood97
    eWood97 New Member
    Custom paint lower
  17. Apr 24, 2024 at 6:58 AM
    #37
    eWood97
    eWood97 New Member
    Custom paint lower
    1/4 or less of a gap between the push rod and the pedal. Before it touches the MC. So as soon as you engage the pedal slowly you can hear the push rod touch the MC. It’s barely noticeable unless you’re gonna get a white lab coat on. That is the brake pedal-tundra booster-gm one ton. Using the parts as is hooked up.
  18. Apr 24, 2024 at 4:27 PM
    #38
    Timbo's Customs
    Timothy
    Lakeland FL
    Going to feel like shit like mentioned above with your method. Bolt your stock master to your booster and see the difference.
  19. Apr 24, 2024 at 4:45 PM
    #39
    eWood97
    eWood97 New Member
    Custom paint lower
    Defeats the point of the mod. If I put the oem mc back then I also would be putting the oem booster back. The pedal feels fine to me. Feels like a brake pedal
  20. Apr 24, 2024 at 9:54 PM
    #40
    Timbo's Customs
    Timothy
    Lakeland FL
    :bananadead:
