One Ton Tacoma.... Come and see!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chilic82, May 9, 2010.
  1. May 9, 2010 at 6:13 AM
    chilic82
    chilic82 [OP] Well-Known Member
    TX
    07 DC PreRunner SR5
    Well, I had to do a little yard work yesterday. So, I went down to a friend of mine's land and picked up some sod for my yard. I don't have a trailer so I had to put it in the back of the truck. My DC does have the LS TSB done and I was curious to see how it would handle it. The bump stops were about a half inch from touching the frame, but it handled it pretty good. I ran about 55- 60 home and didn't have much difficulty. So, here's what 2,000 lbs of sod looks like in the back of a Tacoma.
  2. May 9, 2010 at 6:46 AM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    Impressive. I would have thought it would have been sagging more than that.
  3. May 9, 2010 at 6:53 AM
    Jigzor
    Jigzor Well-Known Member
    Pennsylvania
    17 DCSB Silver Sky
    Yeah, that's not bad at all.
  4. May 9, 2010 at 6:54 AM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    Impressive load right there.
  5. May 9, 2010 at 7:09 AM
    SlurpeeBlueMetallic
    SlurpeeBlueMetallic FFFFFFUUUUUUUUUUUUUUU...
    Nice! Seeing how much (little) it sagged makes me wonder if I was off on my weight estimation when I loaded up on landscaping bricks and dirt:
  6. May 9, 2010 at 7:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    Glad you made it home safely and without doing any immediate damage. Overloading like that over-stresses the leaf packs and will wear them out early. Hope a pretty lawn is worth it.
  7. May 9, 2010 at 7:12 AM
    Jimmyjohn
    Jimmyjohn Well-Known Member
    Jim
    Big Sky Country Montana
    06 SR5 4x4 DLB CAB
    Smitty Blt Bull Bar& Skid Plate, PIAA 525SMR lights
    That was really a full load. I don't think you could have gone with much more.
  8. May 9, 2010 at 7:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Keep an ey eon your axel seals.....They may start to leak in a day or 2.
  9. May 9, 2010 at 7:37 AM
    chilic82
    TX
    07 DC PreRunner SR5
    Really? Why?
  10. May 9, 2010 at 7:39 AM
    chilic82
    TX
    07 DC PreRunner SR5
    I kinda hoped it would break the TSB packs in. They ride a little stiff to me and hoped this would soften them up. It seems to be OK. I won't be doing this again as I have all I need. Also, I only drove about 8 miles like this.
  11. May 9, 2010 at 7:50 AM
    Brunes
    Brunes abides.
    Rotorhead
    Because of the extra pressure caused by overloading your truck by 200-800 lbs (I don't know what a DC is rated for..but my guess is it's in the range of 1200-1300 lbs.) will blow seals out pretty easily.
    That is the trade off in getting the TSB....I hope it worked out to do what you wanted without limiting the life of your springs...
  12. May 9, 2010 at 7:53 AM
    w8n4mud
    w8n4mud There's a mod for that!
    Albert
    San Diego, CA
    2015 Subaru WRX
    Bilsteins 5100's (Front & Rear), GrillCraft, Line-X'ed Skid Plate & Bumper Valence, Blacked out hood scoop, Avid Light Bar and much more.
    :rasta: That's a lot of grass. :rolleyes:
  13. May 9, 2010 at 8:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Because you overloaded the truck. The axel isnt designed to carry that much weight over it.
  14. May 9, 2010 at 9:15 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    It took that very nicely! Doesnt look like the saggy Tacomas that roll around here with a big piece of furniture....Like mine
  15. May 9, 2010 at 9:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Looks like hes on the bump stops.
  16. May 9, 2010 at 9:36 AM
    Lentsnh
    OP Post said his bump stops were half an inch from the frame, but no one will really know until we get pictures of the actual parts.
  17. May 9, 2010 at 10:14 AM
    09TRDSpt
    09TRDSpt African Light Infantry
    Atlanta, GA
    09 TRD Sport DC 4x4
    I don't buy this at all, an axle is not pressurized.. Extra load isn't going to increase pressures at all. It is vented, not a sealed space anyhow. A load could increase heat in the oil due to additional friction. But the only axle seals I have ever seen blow were due to outer bearing failure, bent axleshafts or grit chewing up the rubber seal.
  18. May 9, 2010 at 10:29 AM
    branct06
    branct06 Well-Known Member
    Thomas
    norcross Ga. and High Point Nc.
    05 4x4 black sr5 long bed trd sport
    super 40 flowmaster turned down before rear axle, k&n intake, ipod interface, 20% 3m tint all the way around, grill craft mx series grill with 2 hella 500 behind the grill, 2 55 watt halogens mounted on uws black low profile toolbox, 3'' toytec ultimate lift kit sitting on black xd monsters and 285/65/18 BFG A/T, HID headlight kit
    i did this with my truck last summer no problems...
  19. May 9, 2010 at 10:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The axel carries the weight of the truck. A Floating axel does not. Being as the Tacoma uses a "Semi-Floating" axel, weight is beared on it. When a load exceeds the rating by too much, The axel in the axels housing can put stress on the seals, thus causing a leak. I dont know what you were reading in this thread, in which internal pressure is increased....
  20. May 9, 2010 at 10:51 AM
    1TUFFTRD
    1TUFFTRD WTF
    out and about building powerlines
    06 AC with a skewp
    06 With a Skewp.
    Holy hell. That's a lot of weight
