One wheel is harder to spin than the other
Discussion in '1st Gen. Tacomas (1995-2004)' started by YotaBro, Oct 20, 2024.
  1. Oct 20, 2024 at 3:40 PM
    YotaBro
    YotaBro [OP] Well-Known Member
    98 Tacoma
    I jacked my truck up to take the wheels off, and i noticed that my driver wheel spins freely, but my passenger requires more force to spin it. Any idea what this could mean?
    Black97v6MT likes this.
  2. Oct 20, 2024 at 3:45 PM
    Clearwater Bill
    Billy
    Largo Florida
    Often a dragging brake.
    Is this front or rear?
  3. Oct 20, 2024 at 3:49 PM
    YotaBro
    98 Tacoma
    Front. how do i fix that?
  4. Oct 20, 2024 at 4:03 PM
    Clearwater Bill
    Billy
    Largo Florida
    If you verify that's the problem, it may need a servicing of the caliper sliders to free them up, or it may need a new caliper.
    Often you'll have a pull to one side if that is a dragging side, as it will grab quicker. Sometimes that wheel will be loaded with more brake dust than the other side.
    When were the brakes last serviced?
    When last replaced? (different than serviced)
    It could be something else (like a bad wheel bearing) but it's always good to start simple.
    Extra Hard Taco likes this.
  5. Oct 20, 2024 at 4:26 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    If you are a 4x4, it could be a slight CV axle bind at full droop. If you raise that wheel a little bit, does it spin easier?
    Black97v6MT and Clearwater Bill like this.
  6. Oct 20, 2024 at 6:38 PM
    YotaBro
    98 Tacoma
    It doesnt pull, i just had it aligned as well. They test drove it and said the brakes were fine.
    It was happening on my last CV axles and I just put new CVS in and its still happening so i don't think it's the cvs. It is 4x4
  7. Oct 20, 2024 at 6:48 PM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    Just had this issue with another vehicle I own. Caliper was shot and not allowing part of the brake pad to fullly retract. Ended up replacing the caliper, rotor, and pads.
    YotaBro[OP] likes this.
  8. Oct 21, 2024 at 8:36 PM
    YotaBro
    98 Tacoma
    interesting, what do you mean by the caliper was shot? what did it look like? I'm trying to imagine how the caliper could effect the brake retracting
  9. Oct 21, 2024 at 8:50 PM
    henryp
    henryp Well-Known Member
    Henry
    Montana
    '17 GX 460 and '09 Boosted Taco
    Form follows function
    It could look like uneven brake pad wear (one pad worn out more then the other). A bad caliper would have a seized piston. You can always find a nice example on YouTube if you search for 1st gen Tacoma bad caliper.
    YotaBro[QUOTED][OP] likes this.
  10. Oct 22, 2024 at 2:54 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    ^this
    One piston was only somewhat retracted causing the brake pad to be in a permanent state against the rotor. The other piston functioned as normal for the most part. The pad had been worn down to where it looked like a wedge.
  11. Oct 22, 2024 at 2:55 AM
    Extra Hard Taco
    R.J.
    Devil's Island
    See the above post.
  12. Oct 22, 2024 at 1:57 PM
    YotaBro
    98 Tacoma
    sounds good, thanks. I'll check that out!
    henryp[QUOTED] likes this.
  13. Oct 22, 2024 at 8:55 PM
    YotaBro
    98 Tacoma
    FYI there are no relevant videos when I youtube that phrase
  14. Nov 21, 2024 at 2:08 PM
    YotaBro
    98 Tacoma
    Thinking of tackling this soon as i think it's causing me a hit in gas millage.
    Whats the proper course to diagnose it?
    I'm thinking the problem is either
    A.) a siezed caliper or
    B.) a bad wheel bearing.
    Caliper would be the easier fix. But i don't want to replace the caliper and have the problem exist if it's the wheel bearing
  15. Nov 21, 2024 at 2:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If it's the bearing, you could quickly and easily tell by grabbing the wheel at two ends and rocking it back and forth for play (12 and 6).
    Caliper you'll notice especially if you try re-seating the pistons after pulling it off.
    henryp and YotaBro[QUOTED][OP] like this.
  16. Nov 21, 2024 at 2:30 PM
    YotaBro
    98 Tacoma
    There was play 12-6 but that was the UBJ and I just replaced it, no play anymore, but there is some play if i do it at 3-9 still, could this still be the bearing? any other way to check caliper? or are you saying just to take the caliper off, and if it's hard to put back on (due to the pistons re-seating) then it's likely a problem with the caliper?
  17. Nov 27, 2024 at 1:01 PM
    YotaBro
    98 Tacoma
    so when i brake the truck pulls to the right (same side as the problem wheel), im guessing this mean it’s the caliper? or could it be something else?
  18. Nov 27, 2024 at 3:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sounds likely.
    Have you pulled the wheels?
    I'd inspect the brake pads and look for uneven wear, and go as far as pulling the caliper and see how hard it is to move back each piston.
    Is that one side hot after driving, compared to the other? Smell any burning?
  19. Nov 28, 2024 at 5:52 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Last time I had a locked up caliper…
    Was pulling hard to affected side….
    To confirm
    I used a laser temp thermometer and affected side was more than double the temp of the non affected side after 15m drive
    I’m sure that a feel test will work as well
    Just put some water on your hands so you don’t burn yourself
