only blowing hot air.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by GreggyG, Aug 7, 2023.
  1. Aug 7, 2023 at 5:34 PM
    GreggyG
    GreggyG [OP] Well-Known Member
    On my son's 2011, he was just using the AC, then turned it off and went to heat to defrost window, now it won't go back to cold. The AC compressor is turning on, the fuses and relays look good, the refrigerant pipes are cold, there's plenty of coolant in the system. It just seems that it's simply just blowing hot and the control knob is not working to switch is back to cold. Moving from hot to cold yields the same temp, if I turn it all the way to AC, the AC light will turn on and the compressor engages but the temp of the air won't change. What else could it be? Thank you.
  2. Aug 7, 2023 at 6:01 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    blend door(s)
    CrazyCrewChief likes this.
  3. Aug 7, 2023 at 6:04 PM
    GreggyG
    thank you, where is the blender door located?
  4. Aug 7, 2023 at 6:10 PM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  5. Aug 7, 2023 at 6:13 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
  6. Aug 7, 2023 at 6:34 PM
    GreggyG
    The issue is that the temp control knob won’t change the temp at all, even without the ac on, it’s just kind of stuff on full hot, not even ambient temperature will come through
  7. Aug 7, 2023 at 6:39 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Check the blend door actuators as outlined in the post I linked to above.
  8. Aug 7, 2023 at 7:13 PM
    GreggyG
    Got it working everyone, thank you. The door was stuck
    CrazyCrewChief, CraigF and jdg like this.
