Only got 2 qts out of transmission drain??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco Dad, Mar 19, 2015.
  1. Mar 19, 2015 at 4:12 PM
    Taco Dad
    Taco Dad [OP] New Member
    Alabama
    07 Tacoma PreRunner
    Long time lurker to the forum,
    I drained the ATF out of my son's 07 Tacoma PreRunner.
    Only 2 quarts total drained out. After filling it back with 2 quarts of WS fluid I noticed the pan angles down to the front of the vehicle. To get the much noted 4 quart drain is everyone jacking up the front of the truck?
    http://www.toyotatundraforum.com/pdf/A750E.pdf
    shows a picture of the sloping pan away from the drain. I plan on changing the fluid again in a month when he returns from college and the 2 quarts have "mixed" with the old. Any info appreciated.
    Thanks,
  2. Mar 19, 2015 at 5:23 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    the pan only holds about 3 quarts. the system totals about 11-13 if i remember correctly. Check the sticky on how to properly do a full trans flush.
  3. Mar 19, 2015 at 6:10 PM
    docbrown
    docbrown Well-Known Member
    Tampa, FL
    05 Tacoma SR5 4X4
    Doug Thorley Long Tube Headers, Eclipse 6620 AVN GPS/DVD, K&N Drop-in Air Filter, Hose clamp mod, Redline Quick Lift Elites, Bilstein 5100's at .85, Firestone Ride Rite Air Bags, Weather Techs front and back, Bug Guard, and Factory Bull Bar, Wet Okole's up front, Bed Mat, LED interior lights, Fumoto Oil Valve
    Some of the transmissions came from the factory low on fluid. Your may be one of them, I know mine was. Follow the steps to check the level in the link DoorDing posted and I bet you will be a little low.
  4. Mar 20, 2015 at 6:09 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    My 1st Gen Tacoma drained more transmission fluid with the front elevated as high as a floor jack would take it.
    Drain it first on level ground; then measure what came out. Empty out the pan; then elevate truck to see if you get any additional fluid. Measure it as well to see what additional fluid(if any) came out.
    I see a lot of posts here with drain totals in the 1.5 to 3.0 qt. range. The transmissions are either low on fluid or the elevation drains more fluid.
  5. Mar 20, 2015 at 7:06 AM
    Toeb
    Toeb Well-Known Member
    Toby
    Nc
    Trd off road
    Spc uca and leveling kit, 17" drop star 645 265/70/17, n fab step rails.
    just changed min earlier this week and only got 2.5 out of it. it was level on a post lift. as stated some of these are coming from the factory low on fluid. i was advised from the local dealer to not change mine as i have over 150,000 miles on it i did it anyway no problems so far and drove it over an hour one way lastnight everything seems good
  6. Mar 20, 2015 at 12:47 PM
    Taco Dad
    Alabama
    07 Tacoma PreRunner
    After driving truck around 15 min before starting, I 1st loosened the overfill Allen bolt and fluid came out, about 4-6 oz. Then I drained the rest of the 2 quarts out the drain hole. I figured since fluid came out of the overfill hole to start with it was not low on fluid??? I will drain again in a month when I get the truck back home from college. Truck smarter than I am. Thanks for the replies so far.
  7. Mar 20, 2015 at 2:03 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Many trucks were underfilled from the factory, mine was low about 3/4 qt
