Only half my swapped speedo leds work. Need help with what went wrong on install.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tueton, Mar 20, 2016.
  1. Mar 20, 2016 at 1:39 AM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    05 tacoma 4dr 4.0L 6speed
    CAI, TBS, short throw, Retro projected painted headlights, mesh upper lower, leveler, flow dumped over rear axle with tip, painted perimeter of grille, double din deck, led speedo light change,
    When doing my speedo cluster swap my rpm circle lights up great with the new white smd leds i swapped but the mph and engine temp, gas circles dont light up at all. I was extremely green (new) when i tried doing this. My solder could of puddled and touched both positive and negative sides also i guess the solder has to be specifically for circuit boards etc etc. If anyone who has knowledge in this want to be pal and write up a proper "how to"with what not to do when doing led cluster swaps im sure alot of people will be greatly appreciative of your service. Thank you.
  2. Mar 20, 2016 at 2:22 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Led's have polarity. Did you solder them in reversed maybe?
    12TRDTacoma and Tueton[OP] like this.
  3. Mar 20, 2016 at 3:19 AM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    Checked that. Not the issue. At first yes then went back and checked them all and fixed the ones that needed fixing.
  4. Mar 20, 2016 at 7:55 AM
    3coma
    rob
    Set your meter to diode and test them in both directions. If you shorted across them they will have 0 ohms across both ways. You probably already know this though.
    Tueton[OP] likes this.
  5. Mar 20, 2016 at 7:57 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Did you blow a fuse? I remember when I was installing my trailer lights, half of my speedo didn't light up. It ended up being a fuse. Just throwing it out there...
  6. Mar 20, 2016 at 7:59 AM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    I didnt know that. And im gonna have to get schooled on how to use a meter as well. Damn. NBD. I got this. I hope
  7. Mar 20, 2016 at 7:59 AM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    Thank you btw. I appreciate your help, brother!
  8. Mar 20, 2016 at 8:01 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    No problem. Good luck.
  9. Mar 20, 2016 at 8:01 AM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    I sure as hell could of. Can you show me where the fuse you blew was??
  10. Mar 20, 2016 at 12:42 PM
    Tueton
    Tueton [OP] Member
    NOR♤CAL
    Yo duststorm4x4 can you tell me which fuse it was that blew?? Or would blow if it was my fuse that blew?..
  11. Mar 20, 2016 at 1:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I would think that a fuse would kill all the LEDs not just half.
    Seriously doubt it is a fuse.
  12. Mar 20, 2016 at 2:24 PM
    DustStorm4x4
    U S A
    04 Jeep LJ
    I can't remember what exact fuse it was. I'd just remember it was a little red 10v. I'd check all of them. They're not that hard to check.
    Well it could be different for second gens, but it did happen to my first gen. Half of my speedometer lit up, the other didn't. Replaced the fuse and !tadaa! Back on.
  13. Mar 20, 2016 at 7:41 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Pretty sure it would be the 7.5 Amp Gauge Fuse to the left of the steering wheel behind the pocket.
