Only measured 1/2” factory rake on 22 TRD Sport DC LB
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dc101, Mar 22, 2023.
  1. Mar 22, 2023 at 4:12 AM
    Dc101
    Dc101 [OP] Member
    I measure rake and only found 1/2”. I really thought it would be at least an 1”. Should my lift maintain this same rake ? Probably 2/1” or 3/2 is what I was thinking I don’t want mess up TSS either
    98_3RZ_NIC likes this.
  2. Mar 22, 2023 at 5:44 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Go with 2/1. These truck don't like anything much over that. Many problems start arise over 2" I'm at 2/2
    andthen and 98_3RZ_NIC like this.
  3. Mar 22, 2023 at 6:11 AM
    Dc101
    Dc101 [OP] Member
    2” was my first choice although they have a lot of 3/2” kits Although I really don’t want get involved in swapping UCA etc. What setup up do you have? I plan on putting 265/70/17s.
  4. Mar 22, 2023 at 6:18 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    TSS is fairly forgiving on nose angle.
    If you want to maintain the rake, lift the same height on all four corners. 2/1 or 3/2 are levelling kits - I personally find the level look to be an obvious billboard that says "I dont use my truck to do truck stuff", but several others prefer it over the raked look.
  5. Mar 22, 2023 at 6:21 AM
    Dc101
    Dc101 [OP] Member
    Makes sense so if the entire truck goes up same the angle remains same ?
  6. Mar 22, 2023 at 6:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    The first question to ask yourself is 'why lift?'
    In the hands of a good driver with good tires the truck is quite capable as it sits.
    petethemeat and 98_3RZ_NIC like this.
  7. Mar 22, 2023 at 6:26 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Correct, more or less. I found that the leaves settled at a slightly different rate than the coils, but the end result was fairly close to the same angle on all 4.
    Jeffch, na8rboy and Dc101[QUOTED][OP] like this.
  8. Mar 22, 2023 at 6:45 AM
    na8rboy
    WI
    My set up is not available anymore. But you can get similar set-up. I have 2nd gen pro suspension, with rtx leaf pack ( stage 2) So, similar set-up would be 6112 in front, 5160 back with rtx leafs. Stock UCA's carrier bearing drop, 2 degree shim in back.
    71tattooguy and 98_3RZ_NIC like this.
  9. Mar 22, 2023 at 8:24 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Rake is good
    petethemeat and na8rboy like this.
  10. Mar 22, 2023 at 9:14 AM
    jeepinmike
    jeepinmike Taco. On a stiiiick.
    Buffalo
    22 AG DCSB 6MT Prem Sport
    Full tank of gas
    interesting... I feel my 22 DCSB Sport looks like it does not have alot of rake, but I have yet to measure. It got it in Sept, so I have not gotten serious about what I want to do lift wise, if at all.
    98_3RZ_NIC and xp0nex like this.
  11. Mar 22, 2023 at 9:18 AM
    na8rboy
    WI
    OP did you measure from ground or center of hub?
  12. Mar 22, 2023 at 9:45 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Haha that’s me!
    If it’s dirty the wife can use her Subaru to haul it!
  13. Mar 22, 2023 at 9:54 AM
    xp0nex
    xp0nex Taco Noob
    2022 MGM TRD Off-Road DCSB 4x4
    I have a DCSB OR and I measured it from center of hub to fender and got 1.5" of rake and is actually very noticeable. I actually want to lift the front at least half an inch as I don't mind the factory height. Currently I have all factory suspension and a constant 75lbs or so in the bed from my retractable cover.
  14. Mar 22, 2023 at 9:56 AM
    Dc101
    Dc101 [OP] Member
    Center of hub
  15. Mar 22, 2023 at 10:02 AM
    Dc101
    Dc101 [OP] Member
    I didn’t even think about the cover. Mines a roll up type but that definitely adds weight to it. Didn’t think it would drop it an inch tho
  16. Mar 22, 2023 at 10:45 AM
    jeepinmike
    Buffalo
    Full tank of gas
    good point, I put a Diamondback cover on it right after I got it, so there is a little weight over the rear. Now I'll have to measure and see what it really is.. add it to the "things I read on TacoWorld and need to look into" list... :)
