only one headlight coming on, but brights work?
Discussion in 'Technical Chat' started by desert kidd, Nov 5, 2010.
  1. Nov 5, 2010 at 2:30 PM
    desert kidd
    desert kidd [OP] Member
    Andrew
    so cal.
    stock besides modded airbox in process: 3" lift along with some beefy tires. headers/exhaust.
    title says it all, both lights turn on when i use the brights but only one comes on for the headlights :eek: if it helps last night i took my grill off.
    thanks!
  2. Nov 5, 2010 at 2:38 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
    Low beam is burned out. Replace the bulb.
  3. Nov 5, 2010 at 2:39 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    x2
    Remember to change them both.
  4. Nov 5, 2010 at 3:27 PM
    desert kidd
    Andrew
    so cal.
    duh. thanks
  5. Nov 5, 2010 at 4:29 PM
    Vidman
    Vidman Protected by Sig
    Rick
    central Mass
    2024 Trailhunter
    Not Enough
    Check the fuse first..It happened to me the other day so i changed the bulb...no workie, put another bulb in it still no workie...then i found out that the taco has 4 fuses. 2 for right and left low, 2 for right and left high. weird
  6. Nov 7, 2010 at 5:08 PM
    radioactivemint
    radioactivemint Well-Known Member
    Oregon
    2011 Reg. Cab 4x4
    Didn't know that...good information.
