Only one reverse light works
Discussion in 'Lighting' started by goldentaco03, Nov 2, 2020.
  1. Nov 2, 2020 at 6:39 PM
    goldentaco03
    goldentaco03 [OP] Well-Known Member
    Liam
    NJ
    03 Tacoma Xtra Cab 4x4 SR5
    3in lift (Bilstein 5100, AAL), Bull Bar with halogen Hella Fogs and High Beams
    As the title states, only one of my reverse lights works. I replaced the bulb, still doesn't work and I checked voltage at the bulb socket and there is 0V when in reverse. So this is obviously a problem with the wiring harness. My question is, does the passenger side reverse light wire get spliced into the main harness by the drivers side taillight or does the wire run all the way back to the fuse block? Any other suggestions are welcome
  2. Nov 3, 2020 at 5:49 AM
    goldentaco03
    Liam
    NJ
    Bump, anyone?
  3. Nov 3, 2020 at 5:52 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I bet it’s a probably with corrosion in the wires on the back of the taillight housing
    Tacospike likes this.
  4. Nov 3, 2020 at 6:10 AM
    Tacospike
    Two Trucks
    That was my first thought too
  5. Nov 3, 2020 at 6:34 AM
    goldentaco03
    Liam
    NJ
    Yeahhhh they’re pretty crusty alright, I’ll try and get a voltage reading on the back of the house if I can. Might have to strip back the wires a bit
  6. Nov 3, 2020 at 6:41 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    >90% of electrical issues like this relate to a bad ground. Get an incandescent bulb style test light and check your grounds.
  7. Nov 9, 2020 at 12:10 PM
    goldentaco03
    Liam
    NJ
    Update: took apart the tail light and there was voltage at the pigtail connector... so I plugged it back in and it worked. Before reassembling I sprayed the connectors down with electronic contact cleaner and then packed dielectric grease around the connectors after plugging back in.
    Too Stroked, Tacospike and tirediron like this.
