Only one turn signal working
Discussion in '1st Gen. Tacomas (1995-2004)' started by PreLander4x2, Nov 7, 2020.
  1. Nov 7, 2020 at 10:41 AM
    PreLander4x2
    PreLander4x2 [OP] New Member
    1999 Tacoma SR5 and 2016 Tacoma SR5 Longbed 4x2
    2in Nitro Suspension Lift, BFG Ko2s
    Hey guys, I recently have been working on my new 1999 taco which is a pre-runner build and only one of the turn signals functions. I have replaced all the bulbs and housings and this hasn’t fixed the problem, i’m going to replace the flasher relay next which I doubt will solve anything because one of the signals still works. Thoughts?
  2. Nov 7, 2020 at 10:45 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Have you cleaned the leads?
  3. Nov 7, 2020 at 11:05 AM
    mcl77
    mcl77 Well-Known Member
    check the wiring at where you put the bulb in. Salt will corrode it and break it apart. At least thats what happened with mine.
  4. Nov 7, 2020 at 2:03 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Do the emergency flasher lights work??
    You have only one bulb working or one side??
    You say you replaced the housings did you mean sockets they tend to corrode
    TnShooter likes this.
  5. Nov 7, 2020 at 3:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    This is an important question, if they both work.
    The problem probably isn’t the flasher relay.
    You say only one of the Turn Signals function?
    Can you elaborate on which one?
    One side (Right/Left)?
    One bulb?
