Only so much gas goes in tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vince05Taco, Dec 12, 2019.
  1. Dec 12, 2019 at 1:47 PM
    Vince05Taco
    Vince05Taco [OP] Member
    Vincent
    05 Tacoma
    I have an 05 Tacoma 4 door. I just bought it. The guy I bought it from sold it for his son that just went to boot camp so I can’t get any answers when I have an issue. I thought I had a gas mileage problem at first, but I let the truck go to empty and then I refilled the tank to full. Only 10.5 gallons went in. Any thoughts as to why this is a thing? I looked under the truck, and the tank definitely looks like it carries way more than 11 gallons. Is it the float?
    Also when I filled the tank it went to Full on the gauge.
    grrck and Gunshot-6A like this.
  2. Dec 12, 2019 at 1:51 PM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    05 tacoma has a 21 gallon tank. Really couldn't be the float as it would either defy the laws of buoyancy or gravity to go from full to empty.
    Honest question, how did you determine it was empty? Maybe a bad gauge? Or there is an 11 gallon something in the tank.
    cruxofthebisquit and whatstcp like this.
  3. Dec 12, 2019 at 1:54 PM
    Muddinfun
    Muddinfun Well-Known Member
    Drug mule truck?
  4. Dec 12, 2019 at 1:56 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    Very interesting. Sounds like it's showing empty on the gauge when the tank is actually about half full. Did you take it all the way down to the gas light coming on?
    Kolter45 likes this.
  5. Dec 12, 2019 at 2:21 PM
    Vince05Taco
    Vincent
    05 Tacoma
    That’s what I was thinking. The light did come on.
  6. Dec 12, 2019 at 2:23 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    This would be interesting
  7. Dec 12, 2019 at 2:26 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Can you slide a dip stick down the filler neck? Get an idea how much is left in the tank.
    boston23 likes this.
  8. Dec 12, 2019 at 2:32 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    my gauge does the same thing, well sort of. Gas light comes on fill it up and only takes 50 liters. ive just lived with it.
  9. Dec 12, 2019 at 3:02 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    The rheostat on the float is bad, it's only reading the top half of the tank.
    To test get a gas can and put it in box then run truck out of gas, add gas can and go fill it up.
    Stop at ten gals check gauge see if it's still on E then continue filling and watch gauge move.
    Sharpish and cruxofthebisquit like this.
  10. Dec 12, 2019 at 3:03 PM
    andrew61987
    I do not recommend intentionally running your truck out of gas for any reason
  11. Dec 13, 2019 at 12:02 AM
    grrck
    grrck Reluctant Wizard
    Garrick
    Woodbridge, VA
    2015 Super White SR 2.7 5SPD 4WD
    So much cocaine.
  12. Dec 13, 2019 at 4:03 AM
    Muddinfun
    By doing some basic math, we can determine that 10 gallons of coke weighs 23 kilos. With a wholesale value of $25K per kilo, that’s $575,000. Wouldn’t it be nice to buy a truck for $10K and find $575K worth of coke in a hidden compartment?
  13. Dec 13, 2019 at 8:40 AM
    Vince05Taco
    Vincent
    05 Tacoma
    I mean maybe. Need to find a way to sell.
  14. Dec 13, 2019 at 9:02 AM
    Gunshot-6A
    Conner
    Everett, WA
    I was trying to avoid that accusation when I said "11 gallon something in the tank" but it was implied as a possibility
    Siphon screen would block that.
  15. Dec 13, 2019 at 9:19 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    My fuel gauge sending unit went bad in my old 4runner and it will show full on a full tank but by half tank it would show empty. I just had to learn to fill up by mileage.
    Kolter45 and Bodyguard89 like this.
  16. Dec 13, 2019 at 9:52 AM
    96carboard
    96carboard Well-Known Member
    For what imaginary reason would that be?
    tacotunner06 likes this.
  17. Dec 13, 2019 at 9:59 AM
    theick
    theick Well-Known Member
    Eric
    Las Vegas
    Its bad for pretty much every part of your fuel system. There is always a bunch of sediment in the bottom of the tank. When you run the tank empty it is possible to pick that sediment up and push it all the way through the system. Theoretically, there should be some fuel in the tank even when you run it out to make that not happen but it's better to not chance it.
    PzTank, Marc70, Dye22 and 1 other person like this.
  18. Dec 13, 2019 at 10:12 AM
    weeksz
    weeksz Well-Known Member
    Adam
    Traverse City, MI
    2017 DCLB Limited
    Stickers mostly
    I'm not sure its true that "there is always a bunch of sediment in the bottom of the tank". The tank is always swishing around and mixing during driving. There is a fuel filter. People run their vehicles out of fuel all the time. If I were you OP I'd put a jerry can in the back and see how far she goes.
    DGXR, Anderson, Marc70 and 2 others like this.
  19. Dec 13, 2019 at 10:15 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
  20. Dec 13, 2019 at 10:17 AM
    coopcooper
    alberta canada
    Pam stop eating all the god damn cocaine
