Only so much gas goes in tank
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vince05Taco, Dec 12, 2019.
  1. Dec 19, 2019 at 9:08 AM
    #61
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Granted, but it can be done with a little effort; think, "Hold my beer and watch this!". Given that the previous owner was a young man and young men are stupid (Having been one once, I can say this with some authority), it's possible that the tank sustained damage. Based on the details, it certainly sounds like a case of "missing volume", and on balance, I have to say, I think a dented, plastic tank is more probable than a half-million dollars worth of cocaine inside the tank...
  2. Dec 19, 2019 at 9:11 AM
    #62
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Is it just me or does that sound like a fuel system related problem?
  3. Dec 19, 2019 at 9:14 AM
    #63
    Haslefre
    Haslefre Well-Known Member
    Brady
    TN
    2019 Tundra
    Some flags and center console divider... lots of things on the wanted list.
    Combustion, yes. But the gas cools the windings in the pump. When you start running low and more gas than air (read AIR, not oxygen) gets into the windings it can cause the pump to start heating up and melting the inside of the pumps. Ever ran your garbage disposal without water? Its the same principle. Your tank isn't a vacuum cylinder... so there will be some sort of air inside the tank no matter what kind of system you have. Airplanes just recently started adding a system called OBIGGS to help alleviate this which sends nitrogen into the tank to remove the vapors and the oxygen inside to keep from the exploding when the tank is shot by someone or something.
    Correct, engines tend to stop when there is no fuel. BUT, thats when there is no fuel. You can still have fuel in your tank and air getting into the system causing the initial hiccups of your engine, or sputtering, before you die. This allows air into the pump, causing the windings to burn up.
  4. Dec 19, 2019 at 9:20 AM
    #64
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    My 91 Camaro is like this. The fuel pump is activated two ways - during crank and by an oil pressure switch.
  5. Dec 19, 2019 at 9:22 AM
    #65
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    Hey OP, let me inspect your truck and maybe I can give you a nice offer for it.
    Muddinfun[QUOTED] likes this.
  6. Dec 19, 2019 at 9:30 AM
    #66
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Don't feel bad. I went to HS with a guy who had a hatred of oil. Any kind. Grossed him out. Finally killed his truck.
  7. Dec 19, 2019 at 10:04 AM
    #67
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    It was a gauge related problem that it had when I inherited it from an old lady. I'm insure if he ever ran it out of gas, but I doubt it. It was 5 years old at the time with only 5k miles on it. From talking to other ppl with Cavaliers, they all seemed to have a weird fuel gauge.
  8. Dec 19, 2019 at 10:06 AM
    #68
    jowybyo
    Joe
    Baltimore, MD
    Where are you going with this? Are you suggesting that your fuel tank is going to explode if you run out of gas?
  9. Dec 19, 2019 at 10:11 AM
    #69
    Haslefre
    Brady
    TN
    2019 Tundra
    Did I say explode? But heat + fuel = higher potential for fire. Add in the fact impurities in the fuel could get into the pump/lines you have an even higher chance with repeated abuses of your pump for things to go very wrong. That is why they created the 3-8 gallon (my tundra has 8 gallon reserve) reserve in vehicles to prevent unneeded repairs or to prevent a catastrophic failure.
    https://www.youtube.com/watch?v=WWDFAPXsk9s
    Link for those too lazy to research. I never said explode.
  10. Dec 19, 2019 at 10:11 AM
    #70
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You promised you wouldnt tell anyone! Its icky and doesnt wash off easily.
    Also, Go Mustangs.
    Gritto likes this.
  11. Dec 19, 2019 at 10:18 AM
    #71
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    Keeping a bike in your truck in case you run out of gas...:rofl:
    jowybyo[QUOTED] likes this.
  12. Dec 19, 2019 at 10:26 AM
    #72
    jowybyo
    Joe
    Baltimore, MD
    Haha ok. You are quite paranoid about this. I'd be interested to see a documented cause of a car fire caused by the fuel pump overheating because someone ran out of gas. I'm not saying it's impossible, it just seems unlikely.
  13. Dec 19, 2019 at 10:34 AM
    #73
    Haslefre
    Brady
    TN
    2019 Tundra
    No Paranoia. Just explaining WHY there was a safety reserve in the tanks of vehicles. People said it was stupid for them to have it, but they serve an actual purpose.
  14. Dec 19, 2019 at 11:42 AM
    #74
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The system returns about half the fuel it pumps back to the tank the fuel travels right through the pump motor and all when the truck stops from lack of fuel so does the pump. GM pumps had little issues where the plugin connector for the pump (also located in the tank) fried no fires no explosions. The tank is non vented that's why it has a screw on cap there is not enough O2 to support combustion.
    Sharpish likes this.
  15. Dec 19, 2019 at 11:49 AM
    #75
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I don't know about anyone else but when the gas pump reaches about 17 gals. on a empty tank it shuts off. After that I usually can put another 2 gallons in. You got a trip gauge fill it and reset it repeat and compute the mileage.
  16. Dec 19, 2019 at 12:43 PM
    #76
    Vince05Taco
    Vince05Taco [OP] Member
    Vincent
    05 Tacoma
    Gauge went to E at 110 miles. I’m at another 110 miles. Will fill up soon. Probably no drugs in the truck. Wa wa waaaa
    cruxofthebisquit and Muddinfun like this.
  17. Dec 19, 2019 at 12:47 PM
    #77
    Haslefre
    Brady
    TN
    2019 Tundra
    whatstcp likes this.
  18. Dec 19, 2019 at 12:51 PM
    #78
    TacomaMike37
    13' DCLB MGM
    What percentage of drivers actually run low or out of gas on a daily basis, I would assume a good amount Yet you rarely hear of a car fire, and on top of that, if this were such a deadly hazard ( running your tank low) the media would be all over it, there would be disclaimers in your manual, etc.
    Your entire premise is conjecture.
  19. Dec 19, 2019 at 12:57 PM
    #79
    Vince05Taco
    Vincent
    05 Tacoma
    Thank you much! I might just deal with it. I have a clock spring to handle next, and other small things I’m too embarrassed to mention since I didn’t notice them when I bought the truck.
    whatstcp and Haslefre like this.
  20. Dec 19, 2019 at 12:58 PM
    #80
    Haslefre
    Brady
    TN
    2019 Tundra
    You guys really need reading comprehension. I said THE REASON THAT MANUFACTURERS PUT IN THE FUEL RESERVE AFTER "E" IS TO PREVENT OR REDUCE THE POTENTIAL FOR A CATASTROPHIC FAILURE.
    This is nothing new. Every manufacturer of any type of mechanical equipment does it. A fail safe to reduce dummies from being dumb at least 9/10 times. This is how it has been since metal gas tanks.
    Done arguing though. Enjoy what you want to think. I don't plan on changing your minds on it.
