Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 12, 2017 at 9:23 AM
    #2101
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I'll be on that same shit sometime this summer
  2. Jul 12, 2017 at 10:45 AM
    #2102
    69TACO16
    69TACO16 Well-Known Member
    Rick
    Caledon, Ontario
    16 MGM DCSB TRD 4x4 SPORT
    de-badged, tint front windows, led interior lights, door sill protectors, led b/up lights, 5" factory step rails, yellow turn signal bulbs, added 4 D ring tie downs. Took off the black vinyl stripes between the doors. Changed the grill - from Custom Car Grills, Finally got a tonneau cover put on. 31" light bar ( white & amber ), tailgate light bar, sunvisor covers ( to hide warning labels ), new bedside decals - still too cold to put them on tho. Flag decals to go on too, again too cold still. Got a 2 switch, switch plate to replace that useless cubby hole to the left of the steering wheel.. still to be installed ( hopefully this weekend ). Upgraded the tires to G/Y Duratracs... loving them, no plowing the driveway !!
    Is this a good winch?? SuperWinch LP10000 model # 1510200 ??
    Amazon sells for $782.25
    But I can get it for $450.00 ....
    Here's more info on the kit :
    New in box lower price
    Rated line pull = 10,000 lbs.
    Winch motor = 5.1 HP series wound
    Control = Rubber 12' hand held
    Gear train = 3 -Stage planetary
    Gear reduction ratio = 235:1
    Braking action = Mechanical, Automatic load holding
    Drum size = 2.5" (63.5mm) diameter x 8.8" (224mm) length
    Cable = 3/8" x 85' (9.5mm x 25.9m)
    Fairlead = 4-way roller
    Remote control = included
    Overall dimensions = (LxWxH) 21.3" L x 8.6" W x 8.6" H
    1-Superwinch 1510200 LP10000 series winch, 1-powder coated roller fairlead (mounting plate not included), color-coated leads for connection to battery, 1-85' length of 3/8 (25.9m x 9.5mm) steel rope, 1-heavy-duty latched hook with thimble, 1-rubber handheld remote with 12' cable, 1-4" handsaver strap, mounting hardware, 1-sealed solenoid, 1-circuit breaker component, 1-users manual.
  3. Jul 13, 2017 at 4:33 AM
    #2103
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Reviews:
    https://www.amazon.ca/Superwinch-15...s/B0030E067U/ref=dpx_acr_txt?showViewpoints=1
    http://winchreviews.blogspot.ca/2013/06/superwinch-lp10000-and-lp8500-review.html
    http://www.jkowners.com/forum/jk-general-discussion/22884-superwinch-lp10000-thoughts-comments.html
    Quote from the Jeep thread:
    "When I spoke with the Superwinch rep, he said that the LP10,000 was a solid winch and was designed mostly for the weekend wheeler as a budget-friendly entry-level winch. He said it was the same technology as the 8500, but that the EPi Series winches are an altogether different beast. I think if you went with an LP10,000 it'd be more than enough pulling power for most situations and should be ok. I was always sort of dead set on the EPi9.0 and when one came along, I ended up getting it. Some places are selling the EPi 9.0 for only about $40 more than the LP10,000 I think"
    ... but, remember that for the money, they are an economy winch. Bring marshmallows... and an extinguisher. ;)
    69TACO16[QUOTED] likes this.
  4. Jul 13, 2017 at 6:52 AM
    #2104
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    I got the auperwonch tiger shark series off Amazon. Still economy brand but has the sealed solonoid. So far so good going through two winters on the front of the truck. Got it for $400 shipping included for a 9500lb.
  5. Jul 13, 2017 at 6:57 AM
    #2105
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Arbdeg run July 27-28/29?
    People going so far
    1. @16yota
    2. @NorilskSever
    3. @SRC
    4. @Buffdeez (maybe if he skips beer fest for run fest if Jakes there :D)
    5. @Jake4848 (late Friday night)
    I have a family camping that weekend that I apparently forgot about. I'm out for arbdeg.
    I'll be in Bobcaygeon that weekend, and the of4wd is hosting a newbie run. If anyone is down to do that let me know. I'll be about 40mins out from Minden. Going to do a bit more research on the trails up there and the camping situation for guys coming from far.
  6. Jul 13, 2017 at 7:21 PM
    #2106
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    As long as somebody knows that trail (around the lake) or has a map I am down to go to Ardbeg on those days. Can hit the place on Thursday evening and take that beach spot that was taken by others last time. I need to test my setup one more time before the Burning Man trip in August (If I am lucky to score the tickets at the end of this month) and MOAB trip on the way there. Fingers crossed.
    tacoma16[QUOTED][OP] likes this.
  7. Jul 13, 2017 at 7:45 PM
    #2107
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Dood, if you do Burning Man, promise there will be a thread yeah?
    Norilsk[QUOTED] and tacoma16[OP] like this.
  8. Jul 13, 2017 at 7:46 PM
    #2108
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I agree @NorilskSever especially details about MOAB
    Norilsk likes this.
  9. Jul 13, 2017 at 7:55 PM
    #2109
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Also, If you guys want the OF4WD is hosting the newbie run on that weekend. Don't know what the camping situation is like though. Ill see to get details. I believe the trail is in Minden. A tad closer.
    Edit: never mind that event is full and sold out already....
    Joe23 likes this.
  10. Jul 13, 2017 at 7:56 PM
    #2110
    taczilla
    Marc
    2016 RAM Rebel
  11. Jul 13, 2017 at 8:00 PM
    #2111
    taczilla
    Marc
    2016 RAM Rebel
    What do you mean by sold out? Is it a private trail?
  12. Jul 13, 2017 at 8:07 PM
    #2112
    Jake4848
    Jake4848 Well-Known Member
    Jake
    Petawawa, ON
    2017 Quicksand DCSB TRD Offroad
    6112/5160's,SPC UCA's,3 Leaf AAL, ECGS bushing, Extang Trifecta, 35% Tint, Rear diff breather mod, 285/75r16 K02, Clazzio's, RCI Sliders.
    I know the trail around the lake, but for anyone that wants to do it. You WILL use your skids if you run it stock.
  13. Jul 13, 2017 at 8:21 PM
    #2113
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Not a private trail but if you were thinking of running with the newbie run then yes that is a private event. Also with all the people running around on the trail that weekend it would be mighty crowded.
    taczilla[QUOTED] likes this.
  14. Jul 13, 2017 at 9:04 PM
    #2114
    Norilsk
    Eugene
    IF I get the ticket I will definitely write a full report on Burning Man and MOAB for you guys. lol
    My skids are painted and ready to be abused again if anything, but with 5100 and your tires I should do better this time around.
  15. Jul 16, 2017 at 5:50 PM
    #2115
    taczilla
    Marc
    2016 RAM Rebel
    I was asking if you have to pay to do the run.
    ... and what is Burning Man?
    (Though I will look it up.)
    Edit: I looked it up. They make it sound like a cult and some existential experience in CA. I'll rather save the money and take a logging road in Canada to go speckled trout fishing.
  16. Jul 16, 2017 at 6:00 PM
    #2116
    Norilsk
    Eugene
    Yeah, its one of those things that you never talk about after in your life, but its worth visiting in my age at least ;)
    p.s. you get a chance to burn shit and make huge fires there
    69TACO16 likes this.
  17. Jul 16, 2017 at 6:03 PM
    #2117
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    My bad hard to tell peoples tones while reading. It is not a private trail. It's just that the of4wd will be hosting a large run that day and it will be busy. Sorry for the misunderstanding.
  18. Jul 16, 2017 at 6:04 PM
    #2118
    taczilla
    Marc
    2016 RAM Rebel
    Fill your boots, dude... and empty your wallet. CA is a trek. You can do that shit in your back yard.
    For that matter... I do that in my back yard, but I have 50 acres.
    Kemosabe and tacoma16[OP] like this.
  19. Jul 16, 2017 at 6:31 PM
    #2119
    Norilsk
    Eugene
    Well my backyard is only good to look at, it's a corner lot, can't do shit... city By-Laws etc.
    tacoma16[OP] likes this.
  20. Jul 17, 2017 at 2:58 AM
    #2120
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    If you guys ever want to come East to Minden area that's much easier for me lol.
    But anyways how many of you are running a CB radio?
