Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 8, 2019 at 8:23 PM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
  2. Jul 8, 2019 at 9:21 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    All I ever wanted was I've cream Pete. Plus with that 62 qt I can whip up some more concoctions. I'm thinking of a field poutine with pulled pork.
    In time lol. Put it on my wish list in case Santa is watching
  3. Jul 8, 2019 at 9:25 PM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
    It's good to see that it's been passed around more than my ex! And also some good R and D
  4. Jul 9, 2019 at 1:51 AM
    Manfred
    Manfred
    Great White North
    2010 DCLB
    All of them
  5. Jul 9, 2019 at 3:34 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    You lazy fucks.... Grab a piece of cardboard and a pair of skizzors.
    Manfred and Norilsk like this.
  6. Jul 9, 2019 at 3:39 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    I revised it to look more like this...
  7. Jul 9, 2019 at 5:39 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :rofl:don't worry, it hasn't beat my ex yet. Couldn't keep her legs closed
    THAT'S HIGH QUALITY 30LB PAPER TO YOU, BOY.
    and you couldn't send me that template? :rofl:
    i kid i kid. it seems that you're planning on using the clips up at the top where that same inner fender that i mentioned. Mine was rough only since i was a bit lazy :anonymous: i'll take another shot at it today to get something nicer (probably copy your design, but alter it enough that it fits on one of those home depot rolls) before sending the template out again.
  8. Jul 9, 2019 at 5:53 AM
    honkonbobo
    Eric
    SW Ontario
    ha sorry i mailed the template to you before i had a chance to revise it and do the install. it follows the fender along the top so i could use the existing holes for more push clips. that little tab with the hole on the end is folded in and tywraped though a hole in the bumper mount so its attached at the front. i still got both sides out of a $14 home depot roll even with the larger template but it was tight.
  9. Jul 9, 2019 at 5:58 AM
    honkonbobo
    Eric
    SW Ontario
    once i had the template made i had enough space in the wheel well to do the other side without taking the tire off. pretty sure that means i need bigger tires.
    Tridet167, llamasmurf and Shveet like this.
  10. Jul 9, 2019 at 6:21 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    If your still getting lower than 12L/100km, they aint big enough lol
    Or be @Norilsk and run pizza cutters
    honkonbobo[QUOTED] likes this.
  11. Jul 9, 2019 at 6:30 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I got 9.9l/100 this morning....:anonymous:
    what size do i need?
    Thyces likes this.
  12. Jul 9, 2019 at 6:47 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    there could only be one with 235s! Camel Trophy guys used to run that size btw.
    pics for example
    you don’t want to get into the battle that you can’t win!
    Shveet[QUOTED] likes this.
  13. Jul 9, 2019 at 7:00 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Holy cheezits... those are thin, i'd love to try those out some time but what are they?
    Currently I'm running a set of 265/70/R16 BFG KO2s at 40 PSI, since i haven't swapped them out since the Mazinaw trail, Tank average says closer to 11.2l/100k by the time i'm done (get around 620km from a tank)
    the lowest i've seen on mine was an 8.6L/100k and that was on the stock goodyears.maybe i can sell the old TRD OR rims, tread, and sensors from my 18 and get my hands on those 235s. want me some good mileage and something that looks good
    there is no way i can win against you:bananadead:
    Norilsk[QUOTED] likes this.
  14. Jul 9, 2019 at 7:15 AM
    Norilsk
    Eugene
    There are plenty options in that size 235/85/16
    Yokos
    https://www.kaltire.com/en/tires/geolandar-at-g015/218626.html?cgid=tires
    KO2s
    https://www.kaltire.com/en/tires/all-terrain-ta-ko2/166741.html?cgid=tires
    KO3s
    https://www.kaltire.com/en/tires/mud-terrain-ta-km3/305770.html?cgid=tires
    Nokians - my next tyres
    https://www.kaltire.com/en/tires/rotiiva-at/144061.html?cgid=tires
    For 95% of application it's plenty of a tyre, and for 5% you will need 35s anyways at minimum.
    Here some good read
    https://www.tacomaworld.com/threads/diet-taco-trying-to-keep-things-light.409330/#post-11522572
    https://www.tacomaworld.com/threads...eep-things-light.409330/page-50#post-18580118
  15. Jul 9, 2019 at 7:33 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I'll take a look through and see if i could find something i'd be happy with.
    I'm enjoying the KO2s since they were great over the winter but with the current width of them the truck feels heavy. Didn't know there was a thinner set since the guys at 4wheelparts recommended the 265s as a starting point, i'll take a look into them as well as those Nokians! Cheers!
  16. Jul 9, 2019 at 7:37 AM
    Norilsk
    Eugene
    you can read more about nokians here:
    https://www.tacomaworld.com/threads/nokian-rotiiva-at.609346/#post-21036734
    :cheers:
  17. Jul 9, 2019 at 7:37 AM
    honkonbobo
    Eric
    SW Ontario
    620km per tank? :drool:
    i can still get 500km with the giant air scoop that is my camper but thats with 265/70/R16s and taking my time to get to the speed limit.
    i thought 255/85/16s were a good idea until Leo told me he was getting 350 to a tank :eek:.
    pete37 likes this.
  18. Jul 9, 2019 at 7:48 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    most of that is longer distance highway driving and me doing everything i can to avoid Toronto/Niagara traffic, because fuck that :spy:
    stop n go around the Idiot corner in Burlington, i find myself close to 500 as well.
    Norilsk likes this.
  19. Jul 9, 2019 at 9:17 AM
    tgelata
    Probably at work.
    40’s would look nice :thumbsup:
    Im on 285’s and mines all over the place
    7 min drive to work every day in the winter im lucky to get 300km to a tank
    Driving the 401 im around the 400 km mark
    Driving all country roads with a dirtbike in the back i can usually get a little over 500.
    Shveet[QUOTED], llamasmurf and Joe23 like this.
  20. Jul 9, 2019 at 1:30 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Any chance I may get to use the template as well? Is there a list?
    pete37, Shveet[QUOTED] and llamasmurf like this.
