Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jul 12, 2019 at 9:05 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    @Norilsk i may have found a solution to your exhaust sound dilemma
    Bocsy44, Manfred, Tridet167 and 2 others like this.
  2. Jul 12, 2019 at 9:12 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    well i know what i'm doing with the truck
    Time to swap the minivan engine for a 2JZ
    :spending:
    the best of both worlds, offroading and boost-life.
    Bocsy44, tgelata[QUOTED] and Norilsk like this.
  3. Jul 12, 2019 at 9:12 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    well, now I need this:drool:
    tgelata[QUOTED] and Shveet like this.
  4. Jul 12, 2019 at 9:17 PM
    tgelata
    Probably at work.
    https://www.instagram.com/p/BqyWayUlCAq/
    heres some more motivation
  5. Jul 12, 2019 at 9:21 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  6. Jul 12, 2019 at 9:24 PM
    tgelata
    Probably at work.
    starting point yes. but 10/10 would sound way better with the needle in the red area:boink::sawzall:
    llamasmurf likes this.
  7. Jul 13, 2019 at 3:30 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Crazy I had no idea you can record with a straight up potato, in 2019.
    What is the data plan cost on the fuzzy, blurry, starchy thing?
    Atlas86, tacoma16[OP], Shveet and 2 others like this.
  8. Jul 13, 2019 at 7:29 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :bananadead:
    after 3 revisions, template with the 3rd gen holes is done. just gotta cut out my stuff and i can send it along
  9. Jul 13, 2019 at 9:25 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    :bananadead:so much work, but i'll be plotting out a 1:1 PDF for you guys come Monday, that way if you have the sanity to print it out and work on it, at least we'll be able to.
    Atlas86, SRC, tacoma16[OP] and 4 others like this.
  10. Jul 13, 2019 at 9:49 AM
    llamasmurf
    Wes
    Northern Ontario
    Very nice work :thumbsup:
    Shveet[QUOTED] likes this.
  11. Jul 13, 2019 at 10:13 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Send me a copy of the new template for the second gen :p
  12. Jul 13, 2019 at 2:02 PM
    weight
    weight Well-Known Member
    Kevin
    Ontario, Canada
    2018 Manual Double Cab Short Box
    tgelata and tacoma16[OP] like this.
  13. Jul 13, 2019 at 2:03 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    I'm sending it to @sorgon82 first whenever we decide to do the hand off for it.
    Though the template i got from @honkonbobo only had some holes for the bottom half for what i assume is the the 2nd gen layout, so you'll need some finesse to find the other holes up top.
    I did fuck up a little but but noted it in the template that i'm going to scan, but on the 3rd gen there is an electrical cable (right of the first photo) that needs a notch cut into it to allow for it. I did the driver side first and ended up cutting the notch on both sides:bananadead:
    driver side;
    passenger side;
    the factory clips in the earlier photos i posted are only holding them (just barely) to show off everything assembled, but the actual fartsners that i used are GM Radiator fasteners from Part Source (Part# 247-411)
    (there are 2 that look very similar; one that's a little thicker and with a smooth shell, and the other is thinner but ribbed for her pleasure - the ribbed one is too thing and won't hold, you want the thicker smoother one)
    wanted to give a different clip a try just to add to the knowledge that we as a group have:hattip: i took the dive of paying $25 for 20 of these bastards
  14. Jul 13, 2019 at 4:38 PM
    Canadian Joe
    Canadian Joe Well-Known Member
    Joe
    Ontario
    2016 Tacoma trd off-road ,access cab,MT
    SCS rims 285's OME lift
    Last nights campsite,
    Atlas86, Dabone, Joe23 and 12 others like this.
  15. Jul 13, 2019 at 7:12 PM
    Therby
    Therby Well-Known Member
    Kitchener
    Jeep JL
    Is that the ardbeg?
    Manfred likes this.
  16. Jul 14, 2019 at 3:18 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  17. Jul 14, 2019 at 5:05 AM
    Canadian Joe
    Joe
    Ontario
    Yes,
    I knew someone would know where that was .
    Joe23, 3JOH22A, Norilsk and 2 others like this.
  18. Jul 14, 2019 at 5:54 AM
    weight
    Kevin
    Ontario, Canada
    Yeah, they built travel vans and trailers for years. It’s too bad they went bankrupt.
    tacoma16[QUOTED][OP] likes this.
  19. Jul 14, 2019 at 8:01 AM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Ok... Truck developed a whine sounding an awful lot like the power steering pump. I swapped it out yesterday. Fluid was purple. I'll be doing a flush today. Still have that fucking whine though. What else could it be? I've sprayed all be idler pullies with silicone lube to see if it'll help.
    Manfred and llamasmurf like this.
  20. Jul 14, 2019 at 9:00 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I think @Manfred had a similar issue that turned out to be the alternator and possibly the idler bearings if I remember correctly.
