Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 12, 2020 at 1:14 PM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    For anyone that bought the Princess Auto or the traction boards off of Amazon this is what I made up to mount mine. Super easy to make. If you have a 3rd gen like me you'll need to add a third tie down rail to the front of the box.
    Basically its 2 brackets that just drop into the OEM tie down cleats on the front rail. I mounted the boards on 3/8 threaded rod with clear fuel line over them. Then another piece of flat bar goes on top held on by wingnuts. I mount my shovel to the flat bar with a couple Quick fist clamps. No tools to required to put them in or take them out.
    Sloweburn, Atlas86, sorgon82 and 5 others like this.
  2. Jan 12, 2020 at 1:27 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
  3. Jan 12, 2020 at 6:40 PM
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    Joe23 likes this.
  4. Jan 12, 2020 at 6:42 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I ordered some as well. Under $30 I'll give it a try.
    See if it helps a little but most of the water I get is from the cover leaking not the tailgate
    Tridet167 likes this.
  5. Jan 12, 2020 at 6:45 PM
    Canadianguy91
    Sean
    2016 Limited
    ya I was thinking about it
    Same deal. Tonneau cover seals are crap
    Shveet, Tridet167 and Joe23[QUOTED] like this.
  6. Jan 12, 2020 at 7:10 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i got my t-shirt
    Sloweburn, Tridet167, Atlas86 and 5 others like this.
  7. Jan 12, 2020 at 8:33 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    You have a BakFlip MX4 right? Aside from the tailgate, where is yours leaking from? The mounting rails are supposed to act as drain channels right?
  8. Jan 12, 2020 at 8:41 PM
    Canadianguy91
    Sean
    2016 Limited
    Ya they are, the problem is the water goes under the rails that sit on the bed side. I went and got a thicker seal that was recommended, there was no way it would work as it lifted it too high. Got one that was thinner, it last a year then now leaks again
    3JOH22A[QUOTED] likes this.
  9. Jan 12, 2020 at 9:06 PM
    zuknewbie
    zuknewbie Well-Known Member
    2018 white off-road dcsb
    I’m Ed and the one usually behind the wheel when out running trails or out exploring but the truck is actually my wife’s daily.
  10. Jan 13, 2020 at 4:06 AM
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    I recently took my cap off, removed the bed rails, sealed under there, re-sealed the corners up by the cab and put a thicker gasket seal all the way around. Still leaks like a fucker all the way down and drips off my bed cleat closest to the tailgate. I gave up
  11. Jan 13, 2020 at 4:52 AM
    Canadianguy91
    Sean
    2016 Limited
    That’s brutal dude! I dono how some people just say use this or use that and there’s no issues, meanwhile you’ve tried like 10 things and none seem to work
    sorgon82[QUOTED] likes this.
  12. Jan 13, 2020 at 5:30 AM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    I'm there myself. I think it's the windows that leak though. I was looking at them and installation leaves a lot to ask for (I'd do it better blindfolded). Will take my cap off in the spring to reseal everything and protect the bed itself (paint rub on the top of the bed). Also, side windows have to be replaced for the opening ones.
    Time will tell...
  13. Jan 13, 2020 at 6:02 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i'll check my Ultraflip later on to see if i'm getting any water inside, i don't think i have leaking issues with it but then again i'm not worried about water in the bed as most of my stuff is inside the black box.
    @3JOH22A runs the same boxes but i have no idea what brand they are, rubbermaid maybe? have 2 that have been in the family for 20 years
    and its new life is inside my truck, the other is still a storage bin in the basement
    edit: it's this one https://www.rona.ca/en/storage-tote-0022003--1
    my only issues with the tonneau cover is that i just that it freezes to the tailgate... I slathered on some grease this year in hopes to stop it but it's more of a mess
    3JOH22A[QUOTED] and Snail81 like this.
  14. Jan 13, 2020 at 6:36 AM
    sorgon82
    Ont. Canada
    Your switching for windoors?
    Snail81[QUOTED] likes this.
  15. Jan 13, 2020 at 6:57 AM
    Snail81
    Igor
    Right here, Ontario
    Yes. Don't want to crawl every time i need something from the end..
  16. Jan 13, 2020 at 9:15 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    My rails have a similar design (Bak and Extang are the same company), but the panels have more overlap with the bedside so the seals have more pressure on them. When it gets warmer I'll set up a GoPro inside the bed and spray water with a garden hose.
    The tailgate seal will definitely keep sand and dust out though. When setting up camp at VMUTS last fall, I spent 15 minutes wiping away sand from the bed before laying down the sleeping pad. Hitting 100 kph on the "green" roads did that.
    I got my GSC storage boxes from Princess Auto, but PA stopped carrying them late last year: https://webcache.googleusercontent....+&cd=2&hl=en&ct=clnk&gl=ca&client=firefox-b-d
    It's better for the seals to use silicone spray: https://www.canadiantire.ca/en/pdp/3-in-one-professional-silicone-lubricant-311-g-0381562p.html (works for door seals, electrical connector O-rings, hoses, and exhaust hangar bushings, too)
  17. Jan 13, 2020 at 11:39 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    try liquid silicone on ALL weather stripping in the fall.....!!
    EDIT>>>>ya beat me...
  18. Jan 13, 2020 at 11:42 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  19. Jan 13, 2020 at 11:48 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Shveet[QUOTED] likes this.
  20. Jan 13, 2020 at 12:31 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :eek:
    20cm of blowing snow seems to funnel down my driveway and DIRECTLY into my dorkle
    Might get some sort of satchel to cover this thing while its not in use. Strange, I had a dream about this exact problem before I installed this thing.:cookiemonster:
    Sloweburn, Tridet167, Shveet and 2 others like this.
