Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Aug 21, 2017 at 7:09 PM
    #2541
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    That's why you get All-Pro Hi-Lift mounts, the one I sold to @taczilla and now they are somewhere in Africa I guess...
    I am almost done building bed bars, so for me there are lots of mounting options :D
    llamasmurf and taczilla like this.
  2. Aug 21, 2017 at 7:11 PM
    #2542
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    wouldn't work lol.
    I tried that with the ones I made.
    between the treds and hilift it takes up a decent amount of space in the bed.
    Once i get my bed rack it will be fine but that's likely next year.
    all recovery gear and fuel will be mounted outside
  3. Aug 21, 2017 at 7:11 PM
    #2543
    Jake4848
    Jake4848 Well-Known Member
    Jake
    Petawawa, ON
    2017 Quicksand DCSB TRD Offroad
    6112/5160's,SPC UCA's,3 Leaf AAL, ECGS bushing, Extang Trifecta, 35% Tint, Rear diff breather mod, 285/75r16 K02, Clazzio's, RCI Sliders.
    I have the exact same ones. They fit fine under my tonneau. Not sure about storing them on there side, fill it with gas tip them over. If they don't leak you should be good to go. I love my short bed, I use plano storage boxes for my camping stuff, fits perfect.
  4. Aug 21, 2017 at 7:13 PM
    #2544
    Joe23
    i use the same.
    Honestly its fine just once I put the treds and hi lift in I lose a lot of space on one side.
    Like I said once i have the treds mounted on the bed rack and the hi lift mounted there I'm fine for space. Just until then between the woods roto moulded cooler, and my two plano totes with gear and cooking stuff plus water jugs its a PITA to fit everything.
  5. Aug 21, 2017 at 7:15 PM
    #2545
    Jake4848
    Jake
    Petawawa, ON
    What's wrong with the inside? Would varsol not work to clean the inside?
  6. Aug 21, 2017 at 7:16 PM
    #2546
    Joe23
    @Jake4848 do you have a bed mat as well?
    I wonder if thats what's stopping me from closing the cover or is it just certian spots you can fit it.
    I have found if I put it in the centre of the 2nd fold I can close it but it has to be in a certain spot and running the same way as the cover to fit in the little channel
  7. Aug 21, 2017 at 7:18 PM
    #2547
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Good question on the mat variable...i have same, fit right at the gate np. No bed mat tho...and extang 2.0.
  8. Aug 21, 2017 at 7:19 PM
    #2548
    Norilsk
    Eugene
    I only repainted it on the outside, haven't looked into how to clean on the inside, but will take a look at Varsol!
  9. Aug 21, 2017 at 7:19 PM
    #2549
    Jake4848
    Jake
    Petawawa, ON
    I have a bed mat. I always store mine as close to the tailgate as possible for easy access. My tonneau is a extang trifecta.
  10. Aug 21, 2017 at 7:30 PM
    #2550
    Joe23
    Must be the tonneau. Mines the OEM.
  11. Aug 21, 2017 at 7:33 PM
    #2551
    Joe23
    Must be the different covers. I'll have to try again with mine. Only place I found it fit was right in the front but just barely and it has about a 3 inch gap from the front.
    Or in the centre in a weird way.
    I'll have to experiment a bit more with it. See what I can figure out. Or just get the other Jerry
  12. Aug 21, 2017 at 7:36 PM
    #2552
    Jake4848
    Jake
    Petawawa, ON
    All that being said though, you wouldn't need to bring gas if you fill up in Parry Sound or somewhere near Ardbeg. Our truck's are pretty good on gas.
    Joe23[QUOTED] likes this.
  13. Aug 21, 2017 at 7:39 PM
    #2553
    Joe23
    True. I might bring it just in case dunno yet. I'm going to try experimenting with different set ups of storing everything. Currently had it with cooler being easily accessed on one side then recovery gear on the other
  14. Aug 21, 2017 at 7:42 PM
    #2554
    Joe23
    On another note I'll need to double check with ski tomorrow if my ARB recovery point came in. He sent me an email today saying he thinks it's in but needed to double check. So I'm guessing he just going a decent shipment in. Definitely want to know before making the drive to Mississauga.
    If any of you are interested in it let me know I'll be posting a review on the 3rd Gen section once I install it
  15. Aug 21, 2017 at 7:45 PM
    #2555
    Jake4848
    Jake
    Petawawa, ON
    Personally, I wouldn't worry to much about where your recovery gear is stored until we actually start wheeling. I know that for me, my bed is pretty much empty once I'm actually on the trails. Just have my jerry cans, tool kit, and strap/shackles in the bed when I'm on the trails in Ardbeg.
  16. Aug 21, 2017 at 7:47 PM
    #2556
    Joe23
    Word. I'm almost considering leaving the hi lift. Realistically the treds should do fine
    Jake4848[QUOTED] likes this.
  17. Aug 21, 2017 at 7:48 PM
    #2557
    Norilsk
    Eugene
    :anonymous:
    All I will say is that I did recovery for the recovery boards.
    llamasmurf and Jake4848 like this.
  18. Aug 21, 2017 at 7:56 PM
    #2558
    Jake4848
    Jake
    Petawawa, ON
    In my books, the best recovery gear is another truck with a strap. It's simple and usually gets you out fairly quickly. Right @NorilskSever?
  19. Aug 21, 2017 at 7:57 PM
    #2559
    Norilsk
    Eugene
    Yep, nothing will save you quick enough but another truck! Learned it the hard way.
  20. Aug 22, 2017 at 3:22 AM
    #2560
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Sounds good. I was going to get gas tank straps from budbuilt.
    SRC[QUOTED] likes this.
