Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jan 30, 2020 at 6:09 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Thanks man, you answered all the questions. In a way I can understand. With the exact gauge wire I should be using for what length runs. :hattip:
    Appreciate your input :rolleyes:
    Joe23[QUOTED] and TeecoTaco like this.
  2. Jan 30, 2020 at 6:33 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    This is why we keep peeps like this on retainer
    Joe23, llamasmurf[QUOTED] and Manfred like this.
  3. Jan 30, 2020 at 9:13 PM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    yep. still got it but problem is I gave up my ram for a Tacoma...
    aparently the tow rating on the tacoma is around 6500lbs.
    well that set up is around 7500lbs and I thought the tacoma would be able to tow it.
    I took the the runner and trailer to the scales with the tacoma and and it did do it but it did not like it one bit.
    I was actually afraid that the tacoma would break.
    so now she just sits there.... its rally to bad...
    as for yours it looks mint..
    hear is a tip the guy i got mine from coated the frame with a paint brush and some kind of grease. and that frame to this day will all the abuse is still excellent surface rust but solid
    this summer i want to do that with my Tacoma
  4. Jan 31, 2020 at 4:54 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    An excellent cosmoline based product is called CorrosionX HD .
    It's like a grease, so you can brush it on or use an undercoating gun.
    You just need a 1mm or less thickness.
    Unlike Fluid Film and ACF-50 it does not come off with a pressure washer. You need to use a solvent/degreaser and manual scrubbing to get it off.
    Cosmoline is what is used for Military weapons storage btw.
    Like Fluid film it does collect a layer of dirt, but that will come off with a pressure washer.
    Reapply every 10years depending on useage.
    It's expensive though, over $100 a gallon but a gallon could do 3-4 trucks.
    I use ACF-50 also, in the engine compartment and exhaust and inside body panels. It protects Aluminum and Zinc parts and electrical components.
    I get both products from
    https://www.aircraftspruce.ca/
    If you want something cheap and off the shelf for a brush-able grease, just get any Marine grade grease from Canadian Tire or whatever.
    Less/No Soaps in the grease so it will not wash away as easy as regular automotive grease.
    Manfred, Atlas86, Sloweburn and 3 others like this.
  5. Jan 31, 2020 at 6:25 AM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    @Windigo don’t be afraid to stretch out that Taco. They make GREAT.... acceptable tow rigs. I can’t speak on behalf of the auto trans, but I just kept the 6-sod outta OD and cruised. No groans, no fuss, no excessive speed. Only a couple uphill starts made me feel a little remorse for my clutch.
    I dragged that grey 4Runner to Ardbeg, and it was fully built (not by me) with tons of added weight. Bumpers, sliders, skids, winch, cage. Also a weekends worth of camping gear, and plenty of ice.
    The red 4Runner was nearly the opposite with hardly any extra weight. Only had to drag it to Wasaga beach, and my fuel mileage IMPROVED very slightly. Kept it to 80ish, and some extra momentum on the downhills.
    I didn’t weigh either setup, though I had fully intended to, but the grey one was MUCH heavier than Redee. Not sure how much weight my neighbours mostly aluminum trailer saves over your steel one.
    Grey 4Runner sold, Redee is self-powered now, so no forseeable towing coming up.478981E0-4B2B-4D65-B266-C079DE9BE90B.jpg273788F0-B62E-400F-B338-9EC6D82F36E9.jpg09E65168-F357-44CC-B85C-8AB49F8707E4.jpg
    Atlas86, Sloweburn, tgelata and 3 others like this.
  6. Jan 31, 2020 at 6:58 AM
    Windigo
    Farook
    '14 Acess Cab
    Thanks for the info on the rust control.
    As for towing I'll try again this summer.
    Thanks.
  7. Jan 31, 2020 at 7:32 AM
    Toms2Yotas
    Tom
    Southern Ontario
    For towing, a Weight distribution hitch made a huge difference. Did not have it for the grey 4Runner, did have it for the red one. It felt like axle wrap came way down since the suspension wasn’t pre-loading nearly as much on takeoff.
    I hope you do get out again this summer, it’d be a shame to let that wicked 4Runner sit. That’s why I sold that grey one, drove it once in 15-months. Couldn’t justify the parking space or investment (to my wife).
    Sloweburn likes this.
  8. Jan 31, 2020 at 8:23 AM
    Windigo
    Farook
    '14 Acess Cab
    Thanks.
    I've towed around 7000 lbs with my moms grand cherokee, my 2nd gen cummins and my 3rd gen cummins.
    so far the tacoma is the worst, I'm sorry to say. The grand cherokee had a 5.9 v8 and literately hauled, also the trucks.
    Maybe I just have to get used to tacoma.
    another possiable problem I have now a trailgear rear bumper, advertized to have a towing capicity of 10k. so no more factory hitch or bumper..
    well see how that works out.
    thanks and yes i get the selling of the runner. I tried to sell mine but no one wants a runner with 60/14bolt discs all around locked , trailgear doubler, w56,22re oba, with trailer.
    had it on kijiji for 5k and no takers.... I have to work on the weight, maybe cut off the back half of the body or tow dolly instead of trailer I don't know... we'll see..
    Toms2Yotas, Sloweburn and llamasmurf like this.
  9. Jan 31, 2020 at 8:23 AM
    llamasmurf
    Wes
    Northern Ontario
    After not having a kinetic rope in my recovery kit last weekend. I decided that is the LAST time I am using a snatch strap for recovery. F that shiz.:annoyed:
    Broke down and purchased one, my heep buddy has this exact one and it has last him over 2 years recovering us. Figured that is good enough for me.
    https://www.amazon.ca/dp/B06Y26MBRD/ref=pe_3034960_233709270_TE_item
    Atlas86, daks and Sloweburn like this.
  10. Jan 31, 2020 at 8:27 AM
    Windigo
    Farook
    '14 Acess Cab
    Inspect it very carefully
    after buying their winch rope and taking the time to spool in on i fund a fray right at the end.
    Ranger/ Amazon who ever it was sent me a new one after I returned the old one...
    llamasmurf[QUOTED] likes this.
  11. Jan 31, 2020 at 8:41 AM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    25 Tacoma TRD Off Road
    Bone stock for now
    That's a great price. I was looking at Bubba Rope after using one in Bobcaygeon - it was amazing!
  12. Jan 31, 2020 at 8:45 AM
    llamasmurf
    Wes
    Northern Ontario
    Yea I have bubba rope soft shackles 'Gator jaws'
    I decided to go the cheaper route for the rope since I have seen it work. He actually used it to pull out a F-150 with trailer, no issues. It was a lighter recovery no hard pull. Still worked.
    Sloweburn[QUOTED] likes this.
  13. Jan 31, 2020 at 8:56 AM
    Sloweburn
    Woodstock, ON
    Bone stock for now
    Now that I have an operational winch, I'll hold off on the kinetic rope (now that I'm retired, can't go blowing $$ like I used to). I will pick up a snatch block or 2 though...
  14. Jan 31, 2020 at 9:10 AM
    Toms2Yotas
    Tom
    Southern Ontario
    Nice former fleet. Yea the Taco won’t tow anywhere near as well as those, that’s Literally the sole purpose for a cummins haha. But if the options were A) stay home or B) tow it with the taco.
    That 4Runner sounds like a weapon! All the good stuff, and a trailer for 5k? Perhaps you need marketting help, that’s a solid deal for “Arrive and Drive” offroading package.
  15. Jan 31, 2020 at 9:30 AM
    Windigo
    Farook
    '14 Acess Cab
    thanks Toms2Yotas.
    As i get older i understand the meaning of old becoming new again.
    I'm sure after my Tacoma Faze Ill be back to the wheeling I'm used to so i decided to keep it for as long as the wife can stand. lol.
    TeecoTaco and Toms2Yotas like this.
  16. Jan 31, 2020 at 10:11 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    That's the same size as the KingCord kinetic rope I got at a local CT store on clearance. Pulled me out of the mud once. Don't want to go any larger/stronger because the rope will be less elastic.
  17. Jan 31, 2020 at 10:50 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I bought 3 of those King Cord kinetic ropes when CT was clearing them out for $20 a piece. 7/8 x 20 ft. I used it once and it worked great. Never felt anything in my truck and the other one was out.
  18. Jan 31, 2020 at 10:52 AM
    TeecoTaco
    SW Ontario
    It's fun getting old...you can relive your youth when you couldn't afford such things...old IS new again
  19. Jan 31, 2020 at 12:40 PM
    Windigo
    Farook
    '14 Acess Cab
    very nice toys.
    daily driver Tacoma
    Family driver Runner
    and boys night out IROC...
    over60, Canadian Joe and TeecoTaco like this.
  20. Jan 31, 2020 at 1:03 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    5K with a trailer?
    sounds like a steal! I would've been over it if I seen it before, but now #projectTaco40s is in full swing, so a bit late :(
    Sloweburn and Atlas86 like this.
