Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 7, 2020 at 3:22 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I don't think you realize the only thing that might be reliable to @Norilsk is a tank. And even then it's questionable
    Atlas86, tacoma16[OP] and Shveet like this.
  2. Feb 7, 2020 at 5:35 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    This is probably the most comprehensible list of what does what i've seen yet. Didn't know each brand had its own gimmick, because of my ignorance, i always assumed it's all the same :notsure:
    But now vaguely knowing what digressive, progressive, and linear are (which before your comment i never knew was a thing, i apparently suck at research)... i'm gonna need to go back into looking at things again. because as how you mentioned it, i don't know if the 6112s would be good now. Not saying this because i'm an indecisive cunt, it's because i am an indecisive cunt :p
    So from the sounds of things, Linear valvings and the similar stuff (apparently Elka has a switch or something that just changes the bias between progressive and digressive...) is sort of the best of both worlds then, where it'll eat most of the small stuff and the large stuff, but not as well as the other 2 spectrums, which i'd be generally fine with.
    BACK INTO THE RABBIT HOLE WE GO
    https://accutuneoffroad.com/articles/digressive-vs-linear-vs-progressive-pistons-shock-valving/
    only the mighty KAMAZ can satisfy him.
  3. Feb 7, 2020 at 5:37 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    Hey, it's not me it's Toyota (they don't make them like they used to:duh:)
    Fvicking keeps sending me busted solenoids for the locker, 2 in a row already and 3rd one coming up today. :facepalm:
    Fvicking leak detection pump is too exposed and sucks mud dirt, now I need new one and maybe canister too. :goingcrazy:
    Fvicking interior plastic worse than 20 year old Tercel after just being used 2 years, even 2nd gens were more durable.:argue:
    Fvicking e-actuators, haven't broke yet one :fingerscrossed:
    Fvicking TSS windshields prices :bananadead:
    Fvicking drum brakes... :annoyed:
    Fvicking Toyota :stirthepot:
    If they were selling Ladas here I would be on LadaWorld already.... :lalala:
    /end of rant
    It was carefully engineered luck :spy:, suspension wise it worked very well :bikewhoops:
  4. Feb 7, 2020 at 6:25 AM
    Toms2Yotas
    Toms2Yotas Well-Known Member
    Tom
    Southern Ontario
    2013 Tacoma TRD Sport 6-spd, 1986 4Runner, 1985 4Runner
    Thanks @Joe23 Heading to my favourite store (Princess Auto) today, without my kids! Might as well be an early Christmas.
    Joe23[QUOTED] and tacoma16[OP] like this.
  5. Feb 7, 2020 at 7:04 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    honestly I have been running old man emu shocks for over 100k. Is the ride the best out there? No, not even close. Can I do fast stuff?No. Were they decently priced and do everything I want? Yes.
    Things to consider.
    -Don't waste money on a spacer
    -try to stay away from preloading a shock, get the proper spring
    -bumpstops will do allot for your ride.
    -consider our winters. If you have a shock that is adjustable, you better be doing maintenance on it so you'll be able to do your adjustments.
    -Consider your use-more clearance/travel for offroad, better ride....If its go fast dessert stuff, are you beefing up the rest of the components so the rest of the truck can keep up with the suspension?
  6. Feb 7, 2020 at 7:39 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    6112s don't work with factory springs. They need springs with closed and ground ends like all the 2.5" coilovers available for our trucks.
    Get 6112s with 700 lb King springs and run them at whatever snapring setting that gives you the desired height (there are 6 grooves for fine tuning). Start with the lowest setting on the pass side and 2nd lowest on the driver's side.
    tacoma16[OP] likes this.
  7. Feb 7, 2020 at 7:41 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    any reason for the king 700 over the eibach 700? going to be swapping 700lb coils onto a fox 2.0 in a bit.
    Fun fact, the fox 2.0 use springs meant for a 2.5 shock. The more you know.
    3JOH22A[QUOTED] likes this.
  8. Feb 7, 2020 at 7:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Either is fine. My Icons came with 700lb Eibachs. King springs appeared more widely available.
    tacoma16[QUOTED][OP] likes this.
  9. Feb 7, 2020 at 7:49 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    noted. I haven't had to do research in a while, so just making sure I am up to date. Fox 2.0's with 700lb coils are what's going to be happening soon.
  10. Feb 7, 2020 at 7:51 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    All the talk about springs .....
    Let me just say anyone getting raid of their heavier than stock please let me know.
    Thanks.
  11. Feb 7, 2020 at 8:05 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’ll have 650lb springs soon from the foxes.
  12. Feb 7, 2020 at 8:09 AM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    25 Tacoma TRD Off Road
    Bone stock for now
    @Shveet I have a spring compressor if you'd like to go that route (although I almost lost a finger using it, so @tgelata method likely better).
  13. Feb 7, 2020 at 8:55 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i know i can go and rent one out at the part source right beside my house. the zip-tie thing was an absolute joke. :p
    whenever i do decide on something in terms of suspension, i'll bug you for one if i can't find one :thumbsup:
    Sloweburn[QUOTED] likes this.
  14. Feb 7, 2020 at 9:20 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    @Shveet weighing in his options
    Sloweburn, daks, tacoma16[OP] and 3 others like this.
  15. Feb 7, 2020 at 9:46 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    i feel personally attacked at how close this is to being true...
    Could get this
    Could get that
    Could get that kit that's $3000
    Oh fuck it, what's another 2months of work just for a suspension kit? $6000 it is!
    tgelata[QUOTED] likes this.
  16. Feb 7, 2020 at 10:04 AM
    tgelata
    Probably at work.
    Ah shocks wear out over time so you’ll probably be revisiting it in a couple years anyways.
    Do a u-bolt flip while your in there.
  17. Feb 7, 2020 at 10:53 AM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    Actually with us involved, it turned into this
    @Shveet
    I live my life in gifs
  18. Feb 7, 2020 at 11:16 AM
    Sloweburn
    Woodstock, ON
    Bone stock for now
    I'm sure my (free) rental fee is much cheaper.
    Manfred likes this.
  19. Feb 7, 2020 at 11:25 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Shocks shouldn't fail THAT quickly. The Icons in my old truck went almost 8 years and counting with no maintenance.
    Manfred and Shveet like this.
  20. Feb 7, 2020 at 11:25 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    but i need to take into consideration the gas and time it would take me to drive to Toronto and back o_O
    if that cost outweighs the cost of renting one here on my end, then it no longer is cheaper.
    Nothing in the world is more expensive than free
    -Melvin Williams
    Unless we somehow meet up whenever is most convenient for the both of us like on Feb 22nd/23rd, 2020 for a possible TEQ group meet up with everyone, then yes - it will be cheaper than renting it out at some box store :D
    :boink: @Norilsk
    NOW IS WHERE YOU ADVERTISE LIKE SHAMELESS WHORE TO WHERE THIS MEET UP WILL BE THIS MONTH.
    3JOH22A, TeecoTaco and Norilsk like this.
