Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Feb 10, 2020 at 7:10 AM
    Sloweburn
    Sloweburn Well-Known Member
    Woodstock, ON
    25 Tacoma TRD Off Road
    Bone stock for now
    lol - I had a '73 Ford pickup that was "undercoated" with spray foam.
  2. Feb 10, 2020 at 7:15 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    :popcorn:
    Good ol WhistlinDiesel does not disappoint. I was wondering how long this truck would last, he is already putting it through its paces. :rofl:
    lol @ fixing the bumper
  3. Feb 10, 2020 at 7:32 AM
    honkonbobo
    honkonbobo Well-Known Member
    Eric
    SW Ontario
    2021 ACLB TRD OR 6MT
    i didn't read the above comment real close cause i am busy at work but i think it said something about the massive tire clearance @tgelata is gonna have with glass fenders/bedsides...
    tgelata likes this.
  4. Feb 10, 2020 at 7:33 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    that donk is such an eye sore but pretty awesome to see this guy making the truck work :rofl:
    llamasmurf[QUOTED] likes this.
  5. Feb 10, 2020 at 9:26 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Yeah the paints flaking and it hit the cubby on the inside of the bed and creased it so that bedside is toast
    Ill deal with it when its hc bumper time
  6. Feb 10, 2020 at 12:06 PM
    Ginger taco
    Ginger taco Well-Known Member
    Ontario
    07 Tacoma
    all this lift talk makes me want to start finally putting a lift together I've been thinking on 5100's with 887s over 885s i have about 150lbs on the front hoping for 2 inch lift will it be more than that or should i go 885s? I need to keep stock ucas. Very little "off roading" done.
    Shveet likes this.
  7. Feb 10, 2020 at 3:01 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    my head is still spinning because of the lift and suspension talk :rofl:
    i was thinking the 5100s originally, then i changed to 6112
    however i had been looking at the Icon stage 2 package now, @daks @Norilsk made me look at them and now i wanna spend some money.
    It'd be a great Christmas present for next year :D
    Canadian Joe likes this.
  8. Feb 10, 2020 at 3:03 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    speaking of Christmas.
    :boink: @tacoma16 about a crossbar
    The threaded track mounts finally came in from china
    :bananadance:
  9. Feb 10, 2020 at 3:28 PM
    Ginger taco
    Ontario
    07 Tacoma
    I've looked into the 6112 but think i'd rather go fox 2.0 instead then reconsidered and for the limited budget I have and my use of them i believe 5100s are probably good enough i'm confused on the springs and rates and don't want to buy twice.
    Shveet[QUOTED] likes this.
  10. Feb 10, 2020 at 3:42 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    me and you sit in the same boat
    :drunk:
    clueless and helpless!
    was thinking 6112 in the fronts with 5160 in the rear (as it seems to be a norm)
    then looked at icon 2.0
    and then saw the stage 2 kit which run the icon 2.5s... which i don't even know what 2.0 or 2.5 mean yet. but i'm assuming larger number = mo better
    :bananadead:
    there are so many options and combinations and opinions
  11. Feb 10, 2020 at 3:44 PM
    llamasmurf
    Wes
    Northern Ontario
    You should really think on what you need more than what you can just blow money on.
    I wheel my truck regularly and so far 5100's have been fine, I am just finding the weakness on them now. So :boink:
    Sloweburn, 3JOH22A and Shveet[QUOTED] like this.
  12. Feb 10, 2020 at 3:46 PM
    Ginger taco
    Ontario
    07 Tacoma
    I mostly just can't decide between 885s or 887s i think 886 is to much from what ive read for me
  13. Feb 10, 2020 at 4:10 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    The 2.0 vs 2.5 is the shock body diameter. The 2.0 is the standard shock body that most everyday shocks use whereas the 2.5 is larger. Larger is better if you're doing a lot more off road.
  14. Feb 10, 2020 at 4:33 PM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Looks sick. How much were the tie downs? I have to get more. Where did you end up getting them again?
  15. Feb 10, 2020 at 4:34 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    I'm thinking putting some on the floor of the bed.
    High tie downs aren't needed as much as low for me
    Shveet and tacoma16[QUOTED][OP] like this.
  16. Feb 10, 2020 at 4:37 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    If you order some from the states let me know. When you going to New York? Could just bolt down with stainless and big washers. Thats what I did for my flatbed
    Shveet and Joe23[QUOTED] like this.
  17. Feb 10, 2020 at 4:37 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    2" and Under no probs with stock UCA's .
    at 150Lbs you'll want the softer spring with more height so you can keep it on a lower notch if you're looking at 2".
    But check with others on the OME springs as I've not really played with them much.
  18. Feb 10, 2020 at 4:50 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    2.0" and 2.5" are shock body diameters. Larger diameter = more fluid. Stock yellow Bilstein and 5100 are basically 1.5" shocks. 6112s are 60mm so they are effectively 2.5" class.
    Don't worry about Icon "stages". There's no benefit in getting a package.
    2.5" rear shocks are overkill for the kind of trails in Ontario. Only reason I got them is for extra travel from the Icon RXT design.
    llamasmurf likes this.
  19. Feb 10, 2020 at 4:53 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    tie downs i got from Amazoom.
    pricey as sin but...
    $30 for 2 of the threaded mounts (so $60 for all 4), but at the time of searching, it was the cheapest i could find them. Other sites either didn't have them or didn't show them as an item.
    https://www.amazon.ca/gp/product/B07FBYBP2N/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    this one saves you $0.35 per tie-down
    https://www.amazon.ca/Threaded-Doub...ds=l-track+rail+fitting&qid=1581382475&sr=8-5
    when i say $60 is cheap for 4, those thieves at US cargo control will rob every penny from you. $15 for the fittings but $100 to ship a 0.88kg package (this is what my china amazoom package said it weighs)
    other than that. the track system is the super track rails, which came with 2 of the hooped tie-downs
    So far, spent $180 in total for the tracks and the mounts, plus $20 for the rivnuts and washers.
  20. Feb 10, 2020 at 8:30 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Can't be pricey as sin when your total cost is less than half of what I spent ($500) for a kb Voodoo crossbar :anonymous:
    llamasmurf and Shveet[QUOTED] like this.
