Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Apr 5, 2020 at 8:15 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    I'm curious to know how much difference there is between a $100 Amazon light bar vs the $1000 to $1500 Rigid or Baja Designs light bars.
    Canadianguy91[QUOTED] and Shveet like this.
  2. Apr 5, 2020 at 8:51 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    If i recall correctly the major difference is the reflectors for each LED. Shaped differently to throw more light
  3. Apr 5, 2020 at 8:52 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    It's not 10x the performance and value... that's for sure..
    Cheaper lightbars MAY put out electrical noise from the LED drivers...
    Cheaper lighbars MAY have a thinner/cheaper paint on them that will allow corrosion on the cheap "pot metal" to start sooner.
    There are only about a 1/2 dozen LED manufacturers in the world, the 3-5W leds used in these bars are pretty generic, biggest diff is about 20% differnce in light output and the lens on the top of them for about another 20% in efficiency and designed dispersion.
    Cheaper lighbars MAY have a low end acrylic that will scratch a little easier or UV fade faster.
    Smaller wires used in cheaper lightbars to save copper,
    Smaller/cheaper connectors, may corrode sooner from water ingress.
    Smaller wires and connectors may get hot when used for long periods.
    Spend $100 see 500' might last one month, might last 10 years.
    Spend $1000 see 750-1000' and less glare, more focused. Might last 2 years, might mast 10 years.
    Spend $2000 see 1500', might last 5 years, might last 20 years.
  4. Apr 5, 2020 at 9:29 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    How many horsepower's do I get for the exhaust wrap? :burnrubber:
    Atlas86, Tridet167, Snail81 and 4 others like this.
  5. Apr 5, 2020 at 9:51 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    it doesn't give you horsepower, but if your truck make spooly boi noises then it acts as a 2x multiplier for each turbo you have.
    a turbo is like 150 horses, so 2 of them make 300 but because of the wrap; it's actually 600
    TWIN TURBO 3RDGEN TACO!
    llamasmurf and Norilsk[QUOTED] like this.
  6. Apr 5, 2020 at 9:52 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Another difference is IP waterproof rating. A lot of cheap led lights are not waterproof, some have no rating at all. When you go to all the trouble of installing a light, and sometimes bury it in hard to get at places, you don’t need something that will die prematurely when it gets wet. There are some good Canadian ones, I’ll try to find them.
    Atlas86, daks, tacoma16[OP] and 2 others like this.
  7. Apr 5, 2020 at 9:57 AM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    MTC Canada
    tacoma16[OP] and ODSC1 like this.
  8. Apr 5, 2020 at 12:17 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    Shveet and Norilsk[QUOTED] like this.
  9. Apr 5, 2020 at 12:23 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    where are you guys getting rims from? i want SCS but i might look at other stuff first
  10. Apr 5, 2020 at 12:25 PM
    Norilsk
    Eugene
    try 4wheel parts?
    https://wheelsco.ca/ they sell SCS wheels up in Vaughn.
  11. Apr 5, 2020 at 12:35 PM
    tgelata
    Probably at work.
    the only wheels i like from there are the methods and the procomps i already have. since the steelies dont fit our trucks without spacers :annoyed:
    thanks ill hit up wheelsco
    Norilsk[QUOTED] likes this.
  12. Apr 5, 2020 at 12:41 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Well my Trax-Racks is all installed. I cut down the studs holding the Trax on and just have to get a 3/8 wing nut for holding them down vs a regular nut, but this works great for now. Have to do a couple paint touch ups as I didn't wait for the paint to fully cure...
    Hidden when the bed cover is closed, so I don't look like an overlander, but exposed when I open the cover so I get 2x the points.
    Now to come up with some unistrut brackets to mount the high lift a little neater than it's current arrangement of bungee cords.
    Atlas86, Sloweburn and llamasmurf like this.
  13. Apr 5, 2020 at 12:54 PM
    tgelata
    Probably at work.
    YoU'rE gOnNa dIe uSiNg oNe oF tHoSe:duh:
  14. Apr 5, 2020 at 1:10 PM
    Ares
    Ares Well-Known Member
    Darek
    Hamilton , ON
    2015 LTD DCLB
    Bought Ray10s directly from SCS and shipped them to US address at Lewiston NY and buddy of mine brought them across. At the time it was the cheapest option
  15. Apr 5, 2020 at 1:16 PM
    Norilsk
    Eugene
    This^, we don't use them anymore. Much safer options available.
    Don't think US option is going to be available for the next couple of months :mad:
    My 12" relocation kit and hangers are still there :annoyed:
    At least fiberglass getting delivered this week. :bananadance:
  16. Apr 5, 2020 at 1:18 PM
    tgelata
    Probably at work.
    i don't think that's an option for at least a couple months right now. im going to see if i can get them through wheelsco.
    not in a rush since my current setup is working for me right now anyways
    tacoma16[OP] likes this.
  17. Apr 5, 2020 at 1:20 PM
    Norilsk
    Eugene
    are you looking for 16" F5s wheels , I may know a guy :spy:
  18. Apr 5, 2020 at 1:22 PM
    tgelata
    Probably at work.
    i was joking. I think its a good idea to have at least 1 on the trail for recovery purposes.
    Shouldn't be going under a vehicle without some sort of jack stand anyways. Doesn't matter what kind of jack it is.
    Atlas86, Joe23 and llamasmurf like this.
  19. Apr 5, 2020 at 1:22 PM
    tgelata
    Probably at work.
    17's. thanks though
  20. Apr 5, 2020 at 1:29 PM
    Ares
    Darek
    Hamilton , ON
    2015 LTD DCLB
    Transport trucks are still getting through. All you have to do is to find one willing to pick up this stuff for you :anonymous:
