Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Apr 12, 2020 at 6:06 AM
    tacoma16
    tacoma16 [OP] Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Well there is only about 20k on the front diff gear setup. Other concern is it will be full time 4x4 (everything spinning except at the Tcase) once I do my swap. So if the gears aren’t setup it could potentially get damaged.
    Was trying to avoid dropping the diff but thinking I’ll have to....
  2. Apr 12, 2020 at 6:16 AM
    Windigo
    Windigo Well-Known Member
    Farook
    Toronto Ontario Canada
    '14 Acess Cab
    Full timen4wd. If that's what the fj case does
    Me no want....
  3. Apr 12, 2020 at 6:31 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    I’m doing the ADD delete. So the driveshaft for the front will be spinning but The tcase will be in neutral. if you decide to not do the add delete you will have to engage the front diff ADD with a switch.
    right now the diff doesn’t spin with the ADD on our trucks. Helps on fuel and is why you have to engage 4x4 every month to ensure the bearings get lubricated.
  4. Apr 12, 2020 at 6:42 AM
    Windigo
    Farook
    '14 Acess Cab
    OK i get it... I think you diff will be just fine...
    tacoma16[OP] likes this.
  5. Apr 12, 2020 at 6:53 AM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Interesting, Peter, and just following this now. So what is the advantage? Which vehicle uses this in stock form? Thanks.
  6. Apr 12, 2020 at 7:18 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    So right now I am using a tcase from an auto fj and the diff tube out of a manual fj.
    The auto fj has the manual t-case But uses the same add in the front diff as us on the taco. The manual fj cruiser has awd but has a center diff lock.
    the reason I am using the fj tcase is it gets rid of the 4wd actuator. The fj tube on the front diff gets rid of the add actuator. This simplifies the system as no computers or actuators are being used. My 4wd ecu is gone. Dash lights still work as it’s just two sensors on the shift forks that go straight to the dash lights. Additionally it makes it stronger as the add tubes have been known to break with larger tires. Also no expensive actuators that could fail.
  7. Apr 12, 2020 at 7:23 AM
    pete37
    pete37 Well-Known Member
    peter
    Toronto Canada
    2008 trd offroad aclb 2016 trd sport stolen 2019 TRDORSB
    thanks for posting all the repairs and mods you guys do. Found the nerve to try and got it done
  8. Apr 12, 2020 at 9:26 AM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    so pete37, is that to correct taco lean from a suspension mod?
    Shveet likes this.
  9. Apr 12, 2020 at 9:58 AM
    pete37
    peter
    Toronto Canada
    not sure but I think 1/4 is the fix ...but I did both sides . I have Falcon shocks cant change the springs they were made for stock springs. with the spacers I now have just under 3 in in the front end
    oldtoyotaguy and Tridet167 like this.
  10. Apr 12, 2020 at 10:07 AM
    ODSC1
    ODSC1 Well-Known Member
    London ON
    2017 DCSB Sport MT
    How do you like the Falcons? Would you recommend them? Can you PM a price for the tow/haul model?
  11. Apr 12, 2020 at 10:36 AM
    pete37
    peter
    Toronto Canada
    love the Falcons I had 5100s on the blue 3rd gen.these seem to hold the road and ruff stuff way better
    :mudding:
    ODSC1 likes this.
  12. Apr 12, 2020 at 10:39 AM
    pete37
    peter
    Toronto Canada
  13. Apr 12, 2020 at 2:00 PM
    pete37
    peter
    Toronto Canada
    gotta add 5hp :D what do yah think
    I have a bag of blue loom no use if someone else wants it?
  14. Apr 12, 2020 at 2:27 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    looks like a Honda civic
    :spy:
    Do you have any yellow loom?
    i kinda like how it turned out, but i need to get something to match the reinforcement bars and horns
  15. Apr 12, 2020 at 4:24 PM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    https://youtu.be/VXEHr56Og6Q
    Molly Hogan trail splice for any of you guys who are still using cables on your winches. Something to practice in the garage with a cold one to pass the time.
    Shveet and tacoma16[OP] like this.
  16. Apr 12, 2020 at 4:34 PM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Watched this and it doesn’t seem overly complicated. Think carrying some bolt clasps may be helpful in the case of a break.
    oldtoyotaguy[QUOTED] likes this.
  17. Apr 12, 2020 at 8:34 PM
    oldtoyotaguy
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    The guy in the video said even electrical tape will do the job when the wires are properly braided.
  18. Apr 12, 2020 at 8:34 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    No more CEL!
    For now...
  19. Apr 13, 2020 at 4:52 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
  20. Apr 13, 2020 at 8:16 AM
    Windigo
    Farook
    '14 Acess Cab
