Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Apr 24, 2020 at 3:29 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Buy a TuRD gen 4Runner...but you complained about the cable when you drove mine lol
    llamasmurf and Norilsk[QUOTED] like this.
  2. Apr 24, 2020 at 3:40 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    You've got 3.slow
    I have 3.Majestic
    Shveet and TeecoTaco[QUOTED] like this.
  3. Apr 24, 2020 at 3:43 PM
    TeecoTaco
    SW Ontario
    No, 2nd gen is 3.0...TuRD gen is 3.4
    Norilsk[QUOTED] likes this.
  4. Apr 24, 2020 at 4:05 PM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
  5. Apr 24, 2020 at 4:09 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    Yeah that's what i figured, where it's overkill and i'll most likely never actually pull a full 150A, the 100A, or even whatever enough to trigger a fuse. - maybe if i want to learn how to stick weld at Ardbeg because of a tie-rod just going bye-bye.
    :rolleyes: it's that or ratchet straps.
    But between the battery and the first set of breakers - I kinda want to get 1-2 feet (per breaker) of 1/0 cable for just the safety of isolating the weakest part of my system. It's like $5 a foot anyways so it's not breaking the bank, will only need 4-6 feet at the absolute most. Unless i put in the second battery on the passenger side, then i need a 7-8 foot cable to work with the system, but that's far in the future at this point.
    My thought process is as follows;
    By running the 1/0 cable, I am forcing a predictable chain of weakest links to occur within my system;
    • First link that i want to have fail are the fuses in the fuse box. They are easy to fix, easy to replace.
    God forbid something is to happen
    • Second link that i want to have fail are the 100A and 150A breakers. Easier to fix and reset the system, not easy to replace if it breaks.
    • Third link that i want to fail are the 2 terminal fuses. Easy enough to replace, not as easy to find replacement fuses.
    • Last link i want to have fail, are the cables. I've seen my fair share of Contractors using 200 foot extension cables across sites all nicely coiled at one end and running compressors, saws, lights, radios, fridges, chargers, etc etc etc. those coils can get HOT, seen one glow once - that was cool as heck. Granted, it will not be coiled and able to do that, but it doesn't mean i also want a pretty large LED to start under my hood...
    Anyways; If all of those fail, 2 things will probably have happened;
    1) my accessories no longer work
    2) i probably have a lightly used 3rd gen Tacoma TRD Offroad "Cement" Marshmallow edition for sale. Don't undercut me, I know what i got. As in it probably be burned to the ground:rofl:
    But yes 1/0 and even the #4 are waaaaaaaaaaaay overkill for my use-case.
    but i'll get the 1/0 wires between just the battery and breakers. And whenever i sit down and do the math between the breaker and fuse panel and i'll step down to either a #6 like @Canadianguy91 did, or the #10 as you recommend for the fuse box. Speaking of which, apparently the fuse box negative and positive buses are #10-32 studs, so that might be a better option if the math works out that way.
    Thank you so much for in insight on this, actually thank you.
    This is a solid Video, thanks Bud!
  6. Apr 24, 2020 at 4:17 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    doesn't the Turd Gen MT also have the MINIVAN engine?
    TeecoTaco likes this.
  7. Apr 24, 2020 at 4:40 PM
    Norilsk
    Eugene
    FIFY:luvya:
    Sloweburn and Shveet[QUOTED] like this.
  8. Apr 24, 2020 at 4:40 PM
    TeecoTaco
    SW Ontario
    Only the slush boxes, MTs got the Lexus version
    Norilsk and daks like this.
  9. Apr 24, 2020 at 5:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Why? If throttle response is an issue, flash with OVTune or get a pedal controller like iDrive or Pedal Commander.
    You lose cruise control with a cable throttle.
  10. Apr 24, 2020 at 5:37 PM
    Norilsk
    Eugene
    No, computers are the issue. Give me old school carburetor in this modern Tacoma:crapstorm:
    I kid, how can I live without adaptive cruise control:anonymous:
    Shveet likes this.
  11. Apr 24, 2020 at 5:40 PM
    TeecoTaco
    SW Ontario
    Wait wut? My 86 IROC has CC and a throttle cable
  12. Apr 24, 2020 at 5:55 PM
    tgelata
    Probably at work.
    Separate module. My old s10 and Silverado were the same
    2 throttle cables, 1 to the pedal and one to CC box
    llamasmurf and TeecoTaco[QUOTED] like this.
  13. Apr 24, 2020 at 5:58 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Well looks like I'd have to buy the whole 2020 mirror assembly at over $900 USF each just to get that little camera holder plastic piece...
    Nope...
    $600 USF for each mirror camera...
    Nope....
    Just not worth it for that much.
    Lol restoring old cars with factory parts is a cheaper hobby that adding toys to a modern vehicle...
    Sloweburn and llamasmurf like this.
  14. Apr 24, 2020 at 6:00 PM
    TeecoTaco
    SW Ontario
    So you had cable throttle and CC...we agree
    tgelata[QUOTED] likes this.
  15. Apr 24, 2020 at 6:02 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    You no need no wires for cruise control....
    Pfffft millennials....
    Just have to calibrate the right brick....
  16. Apr 24, 2020 at 6:16 PM
    tgelata
    Probably at work.
    Some more before n afters. almost done just gotta finish the turf around the bumper rails and new gasket between the carb and the intake manifold.
    Gotta find another project for after this now :yawn:
  17. Apr 24, 2020 at 6:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Yes those cars had cruise control as part of their design. Not so easy to add/restore cruise control if you convert a throttle by wire vehicle to cable.
    TeecoTaco[QUOTED] likes this.
  18. Apr 24, 2020 at 6:35 PM
    TeecoTaco
    SW Ontario
    Gotcha now...:thumbsup:
  19. Apr 24, 2020 at 6:37 PM
    TeecoTaco
    SW Ontario
    You like working on that stuff eh? Familiar with Kawasaki Wet Bike? That's where I started my riding fun
  20. Apr 24, 2020 at 6:49 PM
    tgelata
    Probably at work.
    Im pretty new to boats
    I like how simple the ones ive worked on are but man they are tight to work on. gotta be a damn contortionist sometimes.
    i like working on anything and everything though i find it relaxing. (Untill a bolt breaks)
    man those look fun as hell, but rare now. Even stand up jetskis are hard to find
