Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. May 7, 2020 at 12:57 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Oh, the days of being in an eastern block country...
    In a greasy basement beer hall under a government building...
    double shots of Vodka straight up, with beer chasers.
    The Vodka was ice cold and the beer was piss warm...
    Don't know what hurt the worst the next day...
    Head from drinking or your ribs from laughing. Crazy f#cks...
    I think I just felt my liver twitch! :itllbuffout: Poor thing.
    TeecoTaco likes this.
  2. May 7, 2020 at 2:31 PM
    Tridet167
    Tridet167 Not an Overlander, or am I?
    Tony
    Toronto, Canada
    2014 Tacoma SR5 DblCab
    Just finished up some bed stiffeners. Had to trim a bit off the slide on order to slide them in. Easier than removing the tray.
    Next up is the switch panel. Now I'll have to find stuff to fill the other empty spots.
  3. May 7, 2020 at 2:52 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    speaking of electrical...
    Out with the shitty spade connectors
    in with the weather proof ones.
    also a test fit
    what's the best way in feeding a cable from the battery to the bed of the truck? I'm debating on opening up a hole with a grommet and sneaking it in from the underside of the bed. that way the power cables for the lights can be yoinked off at the pod)
  4. May 7, 2020 at 2:55 PM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    run along the frame, and zip tie it. KISS:smack:
    Atlas86 likes this.
  5. May 7, 2020 at 2:57 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    figured that, but idk if Toyota made some special channel for aux cables :bananadead:
    i never owned a truck before this point
  6. May 7, 2020 at 3:07 PM
    Norilsk
    Eugene
    it's called run and zip along the brake lines.
    Atlas86 likes this.
  7. May 7, 2020 at 3:53 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    along the break lines it is :thumbsup:
    You are also the last person i'd expect the give someone electrical advice,
    Mr. Trying-to-remove-as-much-electrical-crap-out-of-the-truck
    but then again you know it better than anyone here as you've removed the most electrical
    Norilsk[QUOTED] likes this.
  8. May 7, 2020 at 3:57 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    +1 Even the factory bed light kit's instructions has you ziptie to existing wiring and brake lines from point a to b,
    If you saw how the techs do it the dealership you would start twitching.....
    Your PC mod background has given you master skilz for this.
    It's just a bigger, greasier Computer case... water cooled from the factory.... no turbo button though...
  9. May 7, 2020 at 4:02 PM
    Norilsk
    Eugene
    Oh I know this truck better than Mike Sweers by now :anonymous:
    TeecoTaco and Shveet[QUOTED] like this.
  10. May 7, 2020 at 4:23 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    What, you couldn't fit size 37 shoes on him ?
    :sawzall:
    Poor guy, I remember him as taller....
  11. May 7, 2020 at 5:12 PM
    Taco-Bell
    Taco-Bell Forestry Student, Tree Hugger, Naturalist
    Ethan
    Thunder Bay, Ontario
    03 F250 6.0
    An unreliable engine
    Made it to 'Berta and the truck did amazing! Cruise control fucking sucks on first gens though. Also Fuck Saskachewan.
  12. May 7, 2020 at 5:32 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    So as some in here know in really into knives and axes. So decided to try converting a full flat grind knife with a secondary bevel (basically common knife grind) into a convex edge. Convex are way better at holding an edge because of the added size behind the edge. Cut through wood for both feather sticks and batoning significantly better. Also way better for slicing, most high end Japanese kitchen knives are essentially convex ground but different term is used.
    Either way it's no easy task and not something there's really a guide for. This was all done freehand progressing through stones and about an hour of work. And oh man will it cut now.
    Original bevel
    220 grit knifewear chosera whetstone removing the shoulder of the bevel and blending the whole bevel grind into the edge
    600 grit naniwa professional chosera whetstone
    1000 grit knifewear chosera whetstone
    4000 grit knifewear chosera
    Final stropping on leather with 4micron CBN emulsion
    I do have an 8000 grit chosera as well but didn't feel like going that much of a polished edge.
    All I can say is this was a lot more work than I thought in terms of time but wasn't as hard as I actually expected.
    But holy shit is it ever sharp now.
    And for those wondering about whetstone just understand quality stones are expensive but worth it.
  13. May 7, 2020 at 6:03 PM
    Norilsk
    Eugene
    Don't worry, soon you'll hate 'Berta. Just wait :devil: The only escape from that flat hell was Jasper/Banff
    Anything between BC and ON is a pure :crapstorm:. I worked all across there :drunk:
    Taco-Bell[QUOTED] likes this.
  14. May 7, 2020 at 6:22 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Turns out the "Knight Rider" sequence runs when the DRLs are first powered on with these Alpharex headlights:
    Also installed the 2020 TRD grille and hard-mounted the Podofo front cam.
    Sloweburn, daks, llamasmurf and 7 others like this.
  15. May 7, 2020 at 7:10 PM
    Tridet167
    Tony
    Toronto, Canada
    Go down in the corner of the bed. Run it where ever you can along the frame.
    OOOOH! Very nice!
  16. May 7, 2020 at 7:11 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Cost more than the Apple monitor stand and Mac Pro wheels added together, but very nice indeed :anonymous:
  17. May 7, 2020 at 7:53 PM
    Norilsk
    Eugene
    all you need is a glowing toyota logo now to complete the looks :101010:
  18. May 8, 2020 at 5:28 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    As per your request comrade.
  19. May 8, 2020 at 6:23 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Lol i actually really liked Saskatchewan
    I kinda wish i spent more time there
    manitoba on the other hand... almost as flat but with trees
  20. May 8, 2020 at 8:54 AM
    Taco-Bell
    Ethan
    03 F250 6.0
    I think it’s because we went through sask diagonally, felt like the god damn place never ended
