Ontario BS Thread
Discussion in 'Ontario, Canada' started by tacoma16, Nov 20, 2012.
  1. Jun 15, 2020 at 9:31 AM
    tgelata
    tgelata Primus sucks
    Probably at work.
    2014 Tacoma Crawler & 2008 Tacoma Daily
    Kinda
    But then i realized the stroke length on a tundra rack isnt the same as a tacoma so i never really looked into it much more
    Norilsk[QUOTED] likes this.
  2. Jun 15, 2020 at 9:42 AM
    Norilsk
    Norilsk Well-Known Member
    Eugene
    J100 (Bougie) & UZN215 (Spartan)
    When you on 37s it's not noticeable :boink:
  3. Jun 15, 2020 at 9:53 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Cut and reweld the steering arm on the spindle? :devil: I imagine a lot of mockup and trial fits will be required.
  4. Jun 15, 2020 at 10:03 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Is that a stirrup hanging from the bumper swing-out arm?
  5. Jun 15, 2020 at 10:28 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Doesn't every sleeping area require stirrups?
  6. Jun 15, 2020 at 10:28 AM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    No idea, 2nd image deosn't show anything but go talk with the Xoverland guys, they might now
    Manfred likes this.
  7. Jun 15, 2020 at 12:05 PM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    haha
    Not even a rear shackle flip? Very Xoverland.
    :duh:
    Shveet[QUOTED] and Snail81 like this.
  8. Jun 15, 2020 at 3:48 PM
    Manfred
    Manfred Well-Known Member
    Manfred
    Great White North
    2010 DCLB
    All of them
    will have to triple check the driveshaft, I know that the u joints are all still in their prime as well. so I have eliminated that possibility. @Atlas86 sat passenger while I was showing him the vibes, post ECGS install. CVs have a bit of an angle, but i don't want to diff drop.
    For some reason they seem to be slightly worse in 2wd as opposed to 4wd, which given that i just installed the ECGS bushing should have remedied that. Now I wont suggest that its shacking the space shuttle challenger on re entry, but I notice them, and they only seem to exist on takeoffs.
    I love the help, will have to check it out tonight.
    Atlas86 likes this.
  9. Jun 15, 2020 at 5:16 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    How many hp is a hood skewp worth again? What if said hood is FRP? :confused::D
    hc5w-fHSWLdvk6UuhPIWQDxZWk8Zt1oCgJ8dNpLg_8755af5a0bcd893e58bba9fdcf1751746ab46195.jpg
    Extreme Dimensions P/N 115392 purchased from Extreme Parts.
    Atlas86, pete37, TeecoTaco and 3 others like this.
  10. Jun 15, 2020 at 5:22 PM
    Snail81
    Snail81 persona non grata
    Igor
    Right here, Ontario
    19 AC TRD OR 6A, work truck white
    Power stickers and chipped paint
    27HP
    +2 coolness
    +1 style
    -3 ruggedness
    daks, Shveet and 3JOH22A[QUOTED] like this.
  11. Jun 15, 2020 at 5:24 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Skewp will slow you down when you're driving through downtown...
    All those women's panties and phone numbers being tossed in your path can really clog up the wipers....
    Make sure you wax the truck as those women can get clingy!
  12. Jun 15, 2020 at 5:25 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    If he adds the hood lightbar, you can add in another 3+coolness and +1 ruggedness
  13. Jun 15, 2020 at 5:26 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Nope, +3 ruggedness, Us Sporty guys don't blow our glue and flutter in the wind like the OR guys do...
    o_O
    Snail81[QUOTED] and Shveet like this.
  14. Jun 15, 2020 at 5:32 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    WHY DID I DO THIS
    :annoyed:
    Snail81 and daks like this.
  15. Jun 15, 2020 at 5:33 PM
    Shveet
    Shveet joe-shmo
    Own-tario
    2018 shitbox
    this is also true, i would know. i have an OR...
    +3 coolness, and +3 ruggedness
  16. Jun 15, 2020 at 6:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Now you can build a single harness assembly for the rack- and bed lights. Be sure to create a bill of materials and give the harness a part number in SAP...
    Shveet[QUOTED] and TeecoTaco like this.
  17. Jun 15, 2020 at 6:21 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Why?
    Well since you asked...
    hmmmm...
    Masochism?
    OCD?
    Anal Retentive?
    Someone put mushrooms in your tea, handed you an etch a sketch and left the room?
    Looks good, but, it didn't show it in that relay picture, but the other side of the switch (positive trigger source) goes back to the positive side of the battery (after a fuse of course)
    When you close the switch power goes through a coil in the relay, the coil creates a magnetic field that pulls down a set of electrical contacts, (that is just essentially a switch) that allows power to go through the other side of the relay (from contact and Armature in this pic)
    Low amperage flows though the coil, so you can use low amperage switches etc, but the other side of the relay can take the high amperage.
    The Switch and coil of the relay is one circuit, that just controls (a switch) for another circuit.
    Pins 86 and 85 are the coil on the relay, 85 goes to Gnd
    So when you put 12V + to pin 86
    Pin 30 closes onto 87 to allow power to flow on the other half of the relay.
    Pin 87A is a NC (normally closed) pin, that means that power would flow from pin 30 to pin 87a UNTIL the coil was energized....
    This pic may help....
    When current flows through 86-85 it pushes the lever over to close the switch on 30 to 87
  18. Jun 15, 2020 at 6:23 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    You actually wet yourself a little when you hit the purchase button...dincha
    Wanna see final application. Despite my stable, AC stance is my favorite. I'd like to see ACLB with sport hood in the wild...is only a US model.
    Noice
    Shveet, daks and Snail81 like this.
  19. Jun 15, 2020 at 6:23 PM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Oh,
    The Horror
    The Horror
    Shveet, weight and 3JOH22A[QUOTED] like this.
  20. Jun 15, 2020 at 6:26 PM
    TeecoTaco
    SW Ontario
    Wait, the MMEW, MBEH...those acronym tables...
    Sorry, carry on
